Old Jan 22, 2016, 12:57 PM
canyon is offline
Find More Posts by canyon
Joined Feb 2009
bind plugs
sorry nigel won't do it again, just trying to learn
canyon is offline Find More Posts by canyon
Old Jan 22, 2016, 01:00 PM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Not good idea to multiple post on same forum.
Nigel
solentlife is online now Find More Posts by solentlife
Old Jan 22, 2016, 01:31 PM
vollrathd is offline
Find More Posts by vollrathd
vollrathd's Avatar
Joined Jan 2007
Originally Posted by canyon View Post
Ijust bought a new piper pawnee from E-flite and it comes with a bind plug, also bought a new spectrum AR400 receiver and it comes with a bind plug. Can someone educate me on these things? I noticed you can't bind a plane without them. Do they stay in the receiver once binding has occurred?
Don't know where else you posted this question.
If you read the Spektrum manual, it tells you to plug in the binding plug to bind this specific model to a model programmed into your transmitter. Once binding is complete, remove the binding plug.
Do note that the transmitter should be located 10 feet or more from the receiver when the transmitter is turned on while in the binding command.
For another model, be sure to program in a second model in your transmitter, and repeat the binding process for the second model.
For me, I store the binding plug in the battery compartment of the transmitter.
vollrathd is offline Find More Posts by vollrathd
Old Jan 22, 2016, 01:33 PM
solentlife's Avatar
Joined Jan 2010
He posted it here also :
http://www.rcgroups.com/forums/showthread.php?t=2587658
Nigel
Old Jan 22, 2016, 05:37 PM
Mr_SMO is offline
Find More Posts by Mr_SMO
United Kingdom, England, Suffk
Joined Apr 2015
My understanding of bind plugs is that they short the +ve and -ve terminals, and in doing so, it's telling the rx to 'listen' out for a tx with the bind button pushed in. Once it's heard it, then it locks on to that code, and only responds to that tx.
You can make a bind plug from an old servo connection, and connect the -ve and +ve wires together. This is what I've read elsewhere on these blogs.
Mr_SMO is offline Find More Posts by Mr_SMO
Old Jan 22, 2016, 05:56 PM
vollrathd's Avatar
Joined Jan 2007
Just to verify, the bind plug shorts out the two outside pins of the receiver binding connector.
Old Jan 22, 2016, 07:18 PM
canyon is offline
Joined Feb 2009
Thanks guys I appreciate the help, and sorry Nigel, I'm new to electric stuff and trying to learn. Here's another problem I have, the Ar 400 has a short wire coming out the top, and a second out the upper right side that is maybe six inches long, it has a piece of heat shrink tubing about an inch or two back. Is the one on the upper right the antennae? I'm having problems with no throttle response. Tail section works fine, but nothing as far as the throttle goes. On the esc two wires go to the battery, a third which I suppose is the throttle connection I plugged into the throttle port on the receiver, but no throttle. What am I doing wrong, I checked my solder joints with my volt meter and it was fine. Sure will appreciate more help. Thanks a lot folks.
Old Jan 22, 2016, 07:32 PM
vollrathd's Avatar
Joined Jan 2007
Which ESC mfg, and how many cells on your LiPo battery pack?
Do you have the motor hooked up to the ESC. Just checking If so, there should be some sort of beeping from the motor when the ESC is powered up. FYI, do this sort of testing with the propeller removed from the motor. Even an accidental start up of a "little" motor with a little prop can send you to the emergency room.
The two wires coming out of the receiver are the receiver antennas. Only the last 1 1/3 inches of the longer antenna is effective. The rest of that longer antenna has a shield around it. This allows locating the second antenna a few inches away from the short antenna, just in case during flight the short antenna gets behind the battery pack or other item that blocks the 2.4 Ghz signal.
Old Jan 22, 2016, 07:47 PM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
This is mostly correct. The text (above) in bold is incorrect.
The bind plug shorts the ground pin and the signal pin (the two outer pins), NOT the positive pin (center pin). You do not want to short the +ve and the -ve pins. If you do, you will usually end up with a dead RX and/or ESC.
Make sure you have the ESC connector to the RX (throttle) is inserted in the correct way. You may have connected it upside down.
KC is offline Find More Posts by KC
Old Jan 22, 2016, 09:09 PM
canyon is offline
Joined Feb 2009
The motor is hooked up to the esc and receiver, I tested all the connections and they have power going through them. There's no prop on the motor, so that's not an issue. The esc is an E-flite 20 Amp brushless ESC with dual BEC and Advanced programming. Reciever is a spectrum AR 400 as my transmitter is a spectrum DX6I. There is two wires coming out of the esc , and one that I assume is the throttle center set of three wires with a receiver servo type plug. I plugged that into the throttle port on the receiver. Elevator and the rudder both work fine, but, the throttle does not.
Old Jan 23, 2016, 05:21 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
... I'm new to electric stuff and trying to learn. ...
Some reading and tips for rainy/windy days. Will save you, and us , a lot of questions.
Will also prevent you from burning up several controllers and/or motors and/or battery:
E-RC primer(s) and tools
Prettig weekend Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jan 23, 2016, 03:46 PM
Mr_SMO is offline
Joined Apr 2015
Thanks every one for correcting my error. I shall be more vigilant in checking in future.
At least I had roughly the right concept.
Old Jan 24, 2016, 03:05 AM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Thanks guys I appreciate the help, and sorry Nigel, I'm new to electric stuff and trying to learn. Here's another problem I have, the Ar400 has a short wire coming out the top, and a second out the upper right side that is maybe six inches long, it has a piece of heat shrink tubing about an inch or two back. Is the one on the upper right the antennae?
Both are antennas. When installed in the plane they should be positioned at right angles to each other if possible.
On some ESC's you must have the throttle trim on the transmitter all the way down before the ESC will arm the motor. On others you have to move the throttle to full and back to off to arm the motor. Have you tried both of those?
It always helps when you include links to the equipment you have. It cuts down on the speculation when everyone knows exactly what you are working with.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Discussion When is a bind plug a bind plug? king1522 Beginner Training Area (Aircraft-Electric) 12 Jun 02, 2015 03:26 PM
Discussion DS-16 binds with NO Bind Plug? JetiFXJ Jeti USA 7 May 19, 2014 07:38 AM
Discussion Problem binding Spektrum TX and RC - no bind plug Nate0624 Multirotor Electronics 0 Apr 29, 2014 07:51 PM
Discussion How do i bind a new rx to a dx6i without bind plug lightningmcnul Beginner Training Area (Aircraft-Electric) 5 Jul 13, 2010 02:11 PM
Discussion Bind plug needed to bind a CX2? crash331 Coaxial Helicopters 4 Jan 18, 2009 01:40 AM
