Old Jul 12, 2014, 01:45 AM
coolein is offline
Find More Posts by coolein
Joined Jul 2014
Help find this charger
I use this charger to charge my lights (used for dentistry). The company wants to charge me $100 to replace the charger. Figured I would find this online for $10. I am not sure where to get started though. Appreciate all the help. Attached is an image.
coolein is offline Find More Posts by coolein
Old Jul 12, 2014, 10:08 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Here's a reddit from someone with a similar problem, they didn't get anywhere either:
http://www.reddit.com/r/electronics/...m_ion_charger/
For some reason that style just seems to be expensive. Here's a similar one, though only 1A instead of 1.8A and it is $70:
http://www.mouser.com/ProductDetail/...e9gbUXILH3M%3d
grimbeaver is offline Find More Posts by grimbeaver
Old Jul 12, 2014, 11:27 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Check eBay or Amazon for any of the various 8.4v bike light chargers. These have similar (if not identical) plug and have 8.4v output. Only thing you might have to do is swap the plug or simply change polarity on the supplied plug.
edit: Here's a 1A, 8.4V charger for <$4, including shipping: http://www.ebay.com/itm/8-4V-Charger...item20e7321fce
One would simply need to swap the connector. Yes, it'll take longer than the 1.8A charger but it'll get the job done.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Jul 12, 2014, 02:48 PM
coolein is offline
Joined Jul 2014
That ebay link looks like it'll do the trick. Forgive my ignorance on the subject but when you say "swap the connectors" I am assuming you are talking about the tip, right? So the connector from ebay doesn't exactly match the connector I have (I assume one is bigger than the other?) I charge my lights overnight anyways so time wouldn't be an issue. Swapping the connectors is an easy process I assume because it looks complicated to me, haha (I feel like a child on this subject matter). Thanks again
Old Jul 12, 2014, 03:18 PM
So. Cal.
Yes, the connector on the $4 charger is a 5.5mm OD with tip positive. From the photos, yours certainly appears smaller than this and has a negative center contact. This would need to be rectified in order to be useful in your application.
Incidentally, is your charger defective or are you seeking a spare? Reason I ask is that the demise of a battery is far more likely than the demise of a charger and you'll want to make sure that your charger is indeed defective prior to harvesting the connector.
Old Jul 12, 2014, 03:43 PM
coolein is offline
Joined Jul 2014
Yes it's the charger (it better be). The battery was just replaced less than a month ago.
Is the switching of connectors pretty simple? Trying to find a site to see how it's done
Old Jul 12, 2014, 03:57 PM
camoy is offline
Find More Posts by camoy
I can't fly
camoy's Avatar
United States, CO, Parker
Joined Dec 2006
You will need to cut off the original one and solder it in place of the one you found on eBay.
camoy is offline Find More Posts by camoy
Discussion Whales are fascinating to me . I cant help but find this funny DLGjunkyard Life, The Universe, and Politics 18 May 01, 2014 09:11 AM
Help! I need to find out the name of this song!!! HELP :) BlinkguY Life, The Universe, and Politics 73 Apr 14, 2014 10:43 PM
Discussion Need help finding this motor 3864kv 700 mensite Electric Plane Talk 4 Mar 11, 2014 11:54 AM
Help! Help finding this plane foamie crasher Balsa Builders 4 Feb 01, 2014 10:12 AM
Discussion Thrift store find: please help ID this engine Dnadnnoid Engines 34 Nov 21, 2013 07:35 PM
