Old Dec 09, 2013, 04:07 PM
mcfast is offline
Find More Posts by mcfast
Canada, QC
Joined Nov 2012
Hughes 500E Gasser
I am going to build a Hughes 500E Gasser 1/7 scale Funky, with a 5 blade head, I would to know if any buddy here has a set-up for one, like head speed and blade size.
mcfast is offline Find More Posts by mcfast
Old Dec 09, 2013, 08:01 PM
Keyrigger is offline
Find More Posts by Keyrigger
Love my scale Whirlybirds
Keyrigger's Avatar
Mississauga, Ont., Can.
Joined Sep 2009
Questions to ask:
Is this your first scale helicopter?
What is your budget?
What heads have you looked at so far?
What blades have you looked at so far?
What is your chassis and can you get reduced size main gears, pinions, or intermediate gears?
The body kit is good and comes with enough hardware for most installations. You can spend large or small but be careful when spending really small as there will be repercussions felt later, especially in a crash. I don't have a gasser but I do have a Fun-Key 500MD TOW Defender with a five blade head that has gone through many changes and on its second head and trial blades. There is precious little difference in setup aside from a slightly bigger rotor head and blade diameter. Let's here what you've got. Take care.
Don
Keyrigger is offline Find More Posts by Keyrigger
Old Dec 10, 2013, 10:45 PM
mcfast is offline
Canada, QC
Joined Nov 2012
Is this your first scale helicopter? YES
What is your budget? LOTS
What heads have you looked at so far? DIAMOND V2 5-BLADE 600-700 SIZE ALL METAL
or Aerodyne SUPER SCALE FIVE-BLADE ROTOR HEAD (700-SIZE)
What blades have you looked at so far? Aerodyne SPINBLADES MATTE BLACK SCALE 5 BLADE SET 600MM
What is your chassis Radikal G30 V2
can you get reduced size main gears, pinions, or intermediate gears? the lowest they make is 6.9, a little to fast, need a motor with good torque.
Old Dec 11, 2013, 12:26 AM
Keyrigger's Avatar
Joined Sep 2009
My experiences do not include working with gas or nitro motor systems so that is why I asked about the availability of gearing. In a perfect world, you would need something to spin the head at about 1350 to 1500 rpm. The Century heads are worth every penny and make a great choice for a first scale build. They can easily be mechanically phased or you can do that with a number of 3 axis gyros on the market. I have used Century semi-symmetrical blades with great results and for the first time on my multi-blade helicopters, I am trying out a set of Spin Blades scale 600mm blades. So far, they do have some getting used to from the pitch curves I had set up for the Century blades and that is not a bad thing. They are very different in profile and thickness so their performance is very different but I will get a better idea of what is going on once I get the body I am rebuilding back onto the chassis.
I am not a fan of the "Plug n Play heads out there because in my opinion, the links are a compromise in performance. In a perfect world, you would have the pitch links go straight up from the swash plate to the blade grip. It is my preference to set the mechanics up like the original full size helicopter or to use the timing in the software of the gyro to set the phasing of the blades. It is also possible to use a combination of mechanical and electronic phasing to set the link rods perfectly vertical. I have an unusual way to set the phasing and when pilots look at my swash plate in operation, most scratch their heads.
Good luck with the build and hope it goes smoothly. I am sure that you will be able to get the gearing you need to reduce the rotor speed and still keep the motor in its sweet spot. Take care.
Don
Discussion Scale Hughes 500E into mini titan Grunta5 Electric Heli Talk 22 Dec 05, 2013 09:15 AM
Discussion My Hughes 500E / Mini Titan Grunta5 Scale Helicopters 2 Oct 30, 2013 04:35 AM
F/S; Darkth Hughes 500E for Corona 120 Fred Bronk Aircraft - Electric - Helis (FS/W) 0 May 13, 2005 01:46 AM
Fs - Nib Robbe/schluter Hughes 500e Fuse David A Ramsey Aircraft - Fuel - Helis (FS/W) 0 Jan 28, 2005 05:18 PM
Hughes 500E for Litemachines heli Gas or Elect darthdrk Aircraft - Electric - Helis (FS/W) 0 Jan 31, 2004 08:41 PM
