Old Apr 02, 2013, 07:35 PM
85miles is offline
Find More Posts by 85miles
Canada, NL, Corner Brook
Joined May 2011
C rating on batteries, does it matter if the c rating is way above the amp draw?
Does it matter what C rating your battery is? I mean i know most esc's require 20-30c
My question is can i Run my Turnigy 9xr with a 1300mah 25c 3 cell?
If the esc or motor isnt drawing over 20c current, than using say a 40c battery wouldnt make any difference because it only draws at 20 c, but this battery can handle up to 40c with say a 80c burst?
Basically will the C rating hurt my electronics if its rated way higher than what is suggested.
85miles is offline Find More Posts by 85miles
Old Apr 02, 2013, 07:50 PM
typeRA is offline
Find More Posts by typeRA
Zero Expo
typeRA's Avatar
San Diego, CA
Joined Mar 2009
The idea that an ESC requires a certain C-rating is nonsense.
Higher C-rated batteries are usually larger, heavier, more expensive, and tend to not tolerate storage as well.
In a transmitter, lower C-rated batteries are much better; using a NiMH battery is almost always the best option.
typeRA is offline Find More Posts by typeRA
Old Apr 02, 2013, 11:02 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
ESC's are rated in amps. C ratings apply to batteries. The C rating of a battery specifies the maximum current the battery can safely supply. Your 1300mah 25c 3 cell will deliver 32.5 amps. If your ESC is rated higher than 35 amps you are safe.
I suggest you read this for a good explaination of RC electrics.
https://sites.google.com/site/tjingu...arging-how-tos
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Apr 02, 2013, 11:37 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Adding to Glen's comments.....
The rating of the ESC just has to be about 25% higher than the max current draw of your motor.
Doesn't matter if the battery can supply 1000A, if the motor only draws 12A max, you only need a 15A ESC.
hoppy is offline Find More Posts by hoppy
Old Apr 03, 2013, 01:09 AM
85miles is offline
Joined May 2011
Thanks guys I get it now
Old Apr 03, 2013, 03:59 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Like hoppy has said, doesn't matter if your battery can supply more amps than the motor wants ... in fact it's good because the battery is less stressed. The only downside is that bigger battery (more amps capability) will cost more and weigh more.
When you're talking about the battery's amps capability, it's good to remember that it's Ah multiplied by C rating, so increasing Ah capacity, instead of or as well as C, will also increase the amps capability, with the added benefit that it also increases flight duration.
abenn is offline Find More Posts by abenn
Old Apr 03, 2013, 11:08 AM
Rodney is online now
Find More Posts by Rodney
Florida
Joined Aug 2004
The higher the C rating, the lower the internal resistance of the battery is where low internal resistance is desireable. Your ESC could not care less about what the C rating is as long as it can get the current required.
Rodney is online now Find More Posts by Rodney
Discussion Battery C rating/ Esc AMP draw. rene21 Electric Power Cars 39 Dec 05, 2015 08:06 PM
Question Does it matter if I use an E or EP prop with my sky surfer plane? janibgud Power Systems 1 Mar 09, 2013 08:24 AM
Discussion Need Advise on what C rating for this system set up! chopper52 Electric Ducted Fan Jet Talk 1 Jan 12, 2013 02:09 PM
Discussion Need advice on amps,watts,volts,draw,C rated,etc Ebolavoodoo Electric Plane Talk 12 Apr 25, 2007 07:09 AM
Discussion How does "C" rating and amp draw work with battery packs? TheDustyPagan Batteries and Chargers 8 Jan 31, 2007 02:22 PM
