Old Mar 01, 2014, 09:14 PM
FieldofDreamsFlyer is online now
Find More Posts by FieldofDreamsFlyer
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
United States, CA, LA
Joined Sep 2004
Check this out
http://www.micro-flight.com/Durafly%...20Upgrades.htm
FieldofDreamsFlyer is online now Find More Posts by FieldofDreamsFlyer
Old Mar 20, 2014, 11:11 AM
nagromnewo is offline
Find More Posts by nagromnewo
umop apisdn - downside up
nagromnewo's Avatar
United States, NC, Wilmington
Joined Sep 2012
Hi
I had some credit at HK burning a hole in my virtual pocket, so I just ordered one of these. I see they recommend 3S 1300mAh batteries. I have some 3S 1600mAh nano-techs that i use in a couple of other aircraft. Do you guys think those will work, or do I need to order batteries for this?
Owen
nagromnewo is offline Find More Posts by nagromnewo
Old Aug 04, 2014, 06:08 PM
Xnaron is offline
Find More Posts by Xnaron
Xnaron's Avatar
Joined Feb 2003
Thanks for posting this info joseico90. My first 2 attempts at flying before reading this ended in quick crashes. I did your mod and drilled out the head for 3mm bolts and used toothpicks. I double checked my rotor and I wasn't getting full movement on right. I was able to correct it on the radio. The wind was pretty calm today and I started the pre-rotater and got the main blades moving. The auto g2 tracked straight ahead. I waited a bit longer than on my first attempts to get more speed up. It took off and this time I actually felt like I had control. I did some turns and noticed that orientation was hard to maintain with the white craft and blades - especially today with the white overcast sky. I used the ailerons and rudders together to make the turns. I flew a few circuits and then performed a landing. The key was keeping the throttle up. Next flights I'll work on trimming it out. Time to take a closer look now at your other mods!
thanks,
Brendin
Xnaron is offline Find More Posts by Xnaron
Old Sep 30, 2014, 11:21 AM
joseico90 is offline
Find More Posts by joseico90
Lets break some props :D
joseico90's Avatar
United Kingdom, Liverpool
Joined Jun 2008
I'm not monitoring this thread at the moment so please inbox me if you need to.
Here is how I made this thing fly like a dream, by making my own blades..
http://www.rcgroups.com/forums/showp...postcount=1307
joseico90 is offline Find More Posts by joseico90
Old Sep 30, 2014, 11:25 AM
joseico90's Avatar
Joined Jun 2008
proof
Durafly Auto G with home made 2" balsa blades !!SUPERB!! (9 min 32 sec)
Old Sep 30, 2014, 10:30 PM
Greywuuf is offline
Find More Posts by Greywuuf
Joined Sep 2014
Does smashing into the ground and breaking the fuse in half and bending the prop shaft constitute a mod ?
Greywuuf is offline Find More Posts by Greywuuf
Old Sep 30, 2014, 11:54 PM
rainerm is offline
Find More Posts by rainerm
south germany
Joined May 2009
O yeah - this is the "final mod " - very well known to the friends of HKs Autogyro.
rainerm is offline Find More Posts by rainerm
Old Oct 01, 2014, 12:03 AM
Greywuuf is offline
Joined Sep 2014
"meh" the fuse and boom are all ready repaired....going to go with a "standard" prop shaft and prop adaptor ( since I smashed the original prop into a fruit dish in the house while trying to center the servo's on original build... I all ready have large hole props ) pretty much my own fault... I was just kinda seeing if it would track straight and spin up ....never should have taken off in the road had no place to go ..panicked and packed it in.... next time I hook up a battery I will be at a flying field ;-)
Old Dec 24, 2014, 07:23 PM
joseico90's Avatar
Joined Jun 2008
Any videos?
Old Dec 25, 2014, 07:49 AM
Tom Wright is offline
Find More Posts by Tom Wright
Tom Wright's Avatar
Joined Feb 2012
Hi Joseico
Glad to see you are still flying gyros Your video is a great example of how a lightly loaded trainer should fly .
Kind regards and best wishes
Tom.
Tom Wright is offline Find More Posts by Tom Wright
Old Sep 27, 2015, 03:12 AM
john4565 is offline
Find More Posts by john4565
john4565's Avatar
Australia, QLD, Noosa Heads
Joined Dec 2012
Oops, wrong thread.
john4565 is offline Find More Posts by john4565
New Product Durafly AUTO-G Gyrocopter Sammy70 Auto Gyros 2446 Apr 10, 2016 11:21 PM
Discussion Pusher Auto G Jockadopolus Auto Gyros 31 Feb 27, 2013 11:45 AM
Sold Durafly Auto-G Gyro and my HK horror story porcia83 Aircraft - Electric - Airplanes (FS/W) 7 Jan 09, 2013 12:38 AM
Sold Durafly AUTO-G Gyrocopter luvmykids2 Aircraft - Electric - Airplanes (FS/W) 3 Dec 17, 2012 02:30 PM
