Old Mar 24, 2010, 11:36 PM
Cabledawg1 is online now
Find More Posts by Cabledawg1
Cabledawg1's Avatar
USA, VA, Newport News
Joined Jan 2010
Which servo wires are common?
Ive got a plane with removable wings. In each wing will be 4 lights and 2 servos. Im running all the wires to 1 molex type connector. Which servo wires are common....ie: which ones can i tie together.
Cabledawg1 is online now Find More Posts by Cabledawg1
Old Mar 25, 2010, 01:40 AM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
Depends on the brand, JR red is +ve, brown is-ve, orange is signal. Futaba is red , black and white. Hitec is red , black and yellow. You can put the +ve together, -ve together and run the signals separate. You will need a 4 pins(conductors) connector for the servos. And the lights require a two pins connector. I would not run the lights with the servo power.
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
Old Mar 25, 2010, 09:55 AM
electrotor is offline
Find More Posts by electrotor
Bonnie Scotland
Joined Jun 2004
You really need to supply more information.
Will each wing have a separate molex connector or will both wings have only one molex connector?
Will you be using a separate power source for the lights?
Will you want to control the lights (on/off) independently?
What is the function of each servo in each wing?
Each servo (regardless of brand) has 3 wires : signal, +ve & -ve (also called common).
The lights (parallel or series) will have 2 wires : +ve & -ve
The +ve and -ve for the servos and the lights could be tied together. The signal wires for the servos could be tied together if you are simply using all the servos to do the same thing (eg, 2 aileron servos per wing). So the minimum number of pins on the molex could be 3.
However if each servo in each wing is for a different function the minimum number of pins on a single molex for both wings would be 6.
A diagram would make it easier to understand.
electrotor is offline Find More Posts by electrotor
Discussion What are the common RC gliding performances? jaron Electric Sailplanes 7 Mar 22, 2010 05:20 PM
Discussion Which wires are + and - ???? bpeltzer Power Systems 7 Nov 13, 2008 02:51 PM
Discussion OK, what are those wires that run from the servo to the control surface called... jrhyne Beginner Training Area (Aircraft-Electric) 6 Jun 02, 2007 05:15 PM
Razor 300 motor how do you tell which wires are which steve ypsi mi Power Systems 3 May 28, 2004 06:25 PM
What are the three servo wires for? djiskra Electric Plane Talk 6 Oct 27, 2001 08:22 AM
