Old Jun 29, 2013, 05:31 PM
Pasco Tri Cities, Washington, United States
Joined Aug 2004
Question
Kontronik power system
I have a Kontronik FUN480-33 motor and Smile 40-6-12 ESC. I used it several years ago with a 10cell NiMH battery pack. I'd like to use a 3S lipo battery instaed to save a bunch of weight. Will this work, or am I asking for trouble? The power system powers a 2 meter glider with R-E- Ailerons and throttle. The wing is built up, and the fuse is fiberglass.
LRFitch is offline Find More Posts by LRFitch
Old Jun 29, 2013, 05:57 PM
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Is the ESC rated for lipo cells? If not, I would hesitate to use it as you will not have the correct low voltage sensing/cut-off which would allow you to over-discharge the lipos and possible ruin the pack.
tkallev is offline Find More Posts by tkallev
Old Jul 01, 2013, 11:16 AM
gasbag's Avatar
whitestone NY
Joined Mar 2002
I have the same setup. I have recently upgraded to Lipos ( 1320ma 11.1v 3s)
I measured the amp draw with the prop I am using. If I were able to drain the batt to zero I would get 3 min. full throttle. I use a safety margin of 50% that gives me seven 10 second full throttle Bursts. When I re charge the batt it only takes 800 ma
You can use your existing equipment "But" you have to monitor your consumption.
Just like the old days of fuel ( You never land with an empty tank) If you recharge your batt after every flight & as long as you only putting 50% of the batt capacity you should be fine.
gasbag is offline Find More Posts by gasbag
Old Jul 01, 2013, 11:15 PM
Joined Aug 2004
Thanks`
Guys,
Thanks for the advice and information. I emailed Kontronik, and they sent me a manual for the Smile ESC so I can set it to LiPo battery. Gasbag, what prop are you using on your setup? I currently have a CAM 13X8 folder on it, but haven't run it with a watt meter hooked up.
Old Jul 08, 2013, 04:32 PM
Now fortified with carbon
DLGjunkyard's Avatar
Canada, ON, Cambridge
Joined Apr 2010
The OP makes no mention of a gearbox. I have the same motor running on 3 cells. 12/6 PROP
I think the gearbox is around 4/1 or something like that. I figured if the controller is rated for 16 cells or something silly like that then Im fine so long as I dont run the cells down below 3.7 each. Its been fine for 2 dozen cycles now
I will have a look for my motor rating. I think it can handle 16 cells [1.4 volt]
DLGjunkyard is offline Find More Posts by DLGjunkyard
Old Jul 08, 2013, 04:55 PM
Joined Apr 2010
Sorry , my bad. 12 cells max sooo 16 volts. Still under the max voltage of a 3 cell lipo pack.
Anyways, just land long before running the cells down and never go below 3.7 per cell and you will be fine. You can even by a cheap low voltage alarm if you want to be sure your not damaging the pack
Discussion Removable arm plug system Cinestar 6/8 frame's and other power systems. holco Multirotor Power Systems 0 May 30, 2013 11:25 AM
Discussion kontronik power system painly Power Systems 4 Jun 21, 2006 01:55 PM
WTT - D-99 w. Hacker power system for F5B power system Meneer Aircraft - Electric - Airplanes (FS/W) 5 Jan 20, 2005 04:01 PM
FS: Fredy Hotliner w/Kontronik power system ClayH Aircraft - Sailplanes (FS/W) 7 Nov 15, 2004 11:59 AM
FS: Graupner/Kontronik brushed 2M Sailplane power system Ben Diss Aircraft - Electric - Airplanes (FS/W) 6 Jul 01, 2004 03:37 PM
