Old Jul 23, 2006, 08:56 PM
wattsup_kz is offline
Find More Posts by wattsup_kz
Frequent Flyer
wattsup_kz's Avatar
Kalamazoo, MI USA
Joined Aug 2003
Speed 400 can - Too hot for CA?
I have a 6v speed 400 with a 6X3 prop running on a 2S pack in my Terry. On hot days the can gets hot enough to soften the foam around it, and even soften the epoxy that holds it in place. I want to glue some flat CF strips to the motor to further secure it.
Can CA withstand the heat?
This is one plane where the stock power arrangement gives fine performance when using a lighter (lipo) battery.
Brian
wattsup_kz is offline Find More Posts by wattsup_kz
Old Jul 23, 2006, 10:45 PM
icrashrc is offline
Find More Posts by icrashrc
icrashrc's Avatar
Indiana
Joined Jul 2003
CA can take heat but it's very brittle. Sounds like a good place for a #64 rubber band to me. Oh, and better airflow around the motor!!!
icrashrc is offline Find More Posts by icrashrc
Old Jul 24, 2006, 05:34 AM
BeavrdamElectric is offline
Find More Posts by BeavrdamElectric
Beaverdam Creek, VA
Joined Aug 2005
The Terry uses a push-it-into-the-foam motor mount so you won't get any air around the can. I was a little dismayed at the mounting, I was planning on an outrunner so I had to install a firewall.
Is foam safe CA brittle?
Good Luck!
BeavrdamElectric is offline Find More Posts by BeavrdamElectric
Old Jul 24, 2006, 07:19 AM
Frequent Flyer
wattsup_kz's Avatar
Kalamazoo, MI USA
Joined Aug 2003
Thanks for the responses.
I have melted air channels around the motor with a soldering iron, so there is some ventilation. I like the idea of flat CF sticks because it leaves more surface area exposed to dissipate heat. I will test the CA on those, and if it breaks easily from a "pull and twist" test, I will try JB Weld. I just don't want it breaking loose in flight as it heats up.
Old Jul 24, 2006, 07:25 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I've CA'ed cans into stuff and never had a problem. Notably a picojet.
Question How hot is too hot for a can motor? roosevelt Power Systems 7 May 21, 2006 09:33 AM
Question Lipo For Speed 400 Can Motor Dog Flyer Batteries and Chargers 5 Mar 12, 2004 02:43 AM
EBAY F117ish speed 400 Stealth Fanfold Plans for sale jdbusyguy Aircraft - Electric - Airplanes (FS/W) 0 Jul 18, 2002 10:58 PM
Battery temperature: How hot is too hot for LMR sailplanes jshelton Power Systems 8 Nov 02, 2001 06:48 PM
How hot is too hot for a SP400 motor? Steve Fehr Electric Plane Talk 4 Oct 22, 2001 03:56 PM
