Old Apr 28, 2015, 05:23 AM
Krissychef is online now
Find More Posts by Krissychef
Joined Apr 2015
Help!
Habao pirate mt with mach 28 won't start
Hi.
I have just brought a second hand pirate mt. It won't start. I have checked the glow plug out of the engine and it glows hot. The pull start seemed stiff so I checked the engine to see if it was flooded. Tipped upside down and no fuel came out. When glow plug is out pull start pulls freely. When glow plug is in pull start is tight.
Fuel lines, tank and filter cleaned. Air filter is fucked so took it off just to start it. New one on its was.
Any ideas?
Krissychef is online now Find More Posts by Krissychef
Old Apr 29, 2015, 03:49 PM
txt killer is offline
Find More Posts by txt killer
Joined Apr 2008
Put a couple drops of after run oil in the engine and spin it over a few times and put the plug back in but leave it 1/4 turn loose and try to start it again. If it doesn't fire after several tries put your finger over the exhaust hole to prime the engine. If should fire? If not then you will need to rebuild the carb.
txt killer is offline Find More Posts by txt killer
Old Apr 30, 2015, 05:00 AM
Joined Apr 2015
Cheers for that. I rebuilt the carb last night and charged the starter fully to try it later. I have seen loosing the glow plug helps with starting it, why is that? It has new glow plug, air filter and starter so really baffled as to why is doesn't start lol
Old Apr 30, 2015, 04:25 PM
Joined Apr 2008
The compression is lower.
Help! Ask your congress critter to read the 28 classified pages,it won't hurt BACKEMFNRG Life, The Universe, and Politics 18 Apr 30, 2015 11:11 PM
Discussion Quad with naze32 won't start Toasterz Multirotor Electronics 7 Apr 21, 2015 08:35 PM
Discussion J Power T-28 Trojan mini. Won't fly! Alotoffoamies Micro Ready-to-Fly 2 Mar 01, 2015 06:04 PM
Discussion 350QX V2.0 won't start rvlevy7 Multirotor Talk 1 Dec 08, 2014 02:30 PM
Discussion My UM T-28 Won't Go Up! Bob6831 Beginner Training Area (Aircraft-Electric) 7 Apr 13, 2014 03:07 PM
