Old Apr 25, 2015, 03:44 AM
NoLimitRC is offline
Find More Posts by NoLimitRC
I have a degree in crashing!
NoLimitRC's Avatar
United Arab Emirates
Joined Dec 2014
Help!
what foam is this?
After a long search for foamboard for a scratchbuilt plane, I finally found a supplier, They are fairly inexpensive and I want to use them to make my first plane, I have attached pics, please state whether this is the infamous dollar tree foam or depron...... Thanks
NoLimitRC is offline Find More Posts by NoLimitRC
Old Apr 25, 2015, 06:31 AM
insomaniac45 is offline
Find More Posts by insomaniac45
Not always grumpy!!
insomaniac45's Avatar
UK, Eastleigh, Eastleigh
Joined Jul 2010
a few things would help,
Like Where you bought it?
The weight?
how easy does the paper come off?
It looks a bit funky, as in pic 2, you can clearly see a seem running through the middle of the foam.
and plus, its pink. not white. (I dont live in the US, im UK) i think DTFB only comes in white i believe (from what ive seen)
insomaniac45 is offline Find More Posts by insomaniac45
Old Apr 25, 2015, 07:41 AM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
No limit, from what i can see it doesn't look like beadboard, which is the least desireable foam (although for guys who can only get it, they make do and produce some nice planes which only reinforces the "use what ya got".) If it is DTF, it will have a sticker on one side like shown.
More info will help. Where are you located, where did you get the foam, and how big and thick is the sheet? Os there paper or plastic film on one or both sides?
springer is online now Find More Posts by springer
Old Apr 25, 2015, 10:01 AM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
epilot's Avatar
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
Certainly not Depron as Depron does not have paper attached to it.
epilot is offline Find More Posts by epilot
Old Apr 25, 2015, 10:26 AM
NoLimitRC's Avatar
Joined Dec 2014
It has no name on its barcode, but it says Paper-FoamBoard, I found it in a stationary shop,it is available in several colors, I live in the UAE, So chances of me finding a good material is pretty low, If I am not mistaken the foam board is around 4-6mm without the paper.
Old Apr 25, 2015, 10:47 AM
Krashlnd is offline
Find More Posts by Krashlnd
Who Put that Tree There?
Krashlnd's Avatar
Athens, Tennessee
Joined Jun 2003
This is the same foam board that Hobby Lobby craft stores sell. Its good for plane making. Looks like you bought the tri-fold style which is used for art displays. It is double layered to make somewhere around 6mm. I have split them using a hot wire foam cutter set to 3mm. Only problem is the glue in the center tends to remelt and glue the foam back together.
Krashlnd is offline Find More Posts by Krashlnd
Old Apr 25, 2015, 11:22 AM
NoLimitRC's Avatar
Joined Dec 2014
So is it as good as dollar tree foam board, will it be good enough after covering with packing tape?
Old Apr 25, 2015, 01:28 PM
Not always grumpy!!
Joined Jul 2010
The only thing i can say, is watch for weight, I know my foam (westfoam) is around 250g per sheet (A1) and DTF is around 180 (please correct if wrong)
If it is on the heavier side then you will be better off removing some of the paper on parts that dont need the extra strength,
I have built 4 Flite Test planes, and all fly great, but i have had to remove paper sections to get the weight under control
Tony.
Old Apr 25, 2015, 07:02 PM
treefinder
springer's Avatar
SE MI
Adams readiboard (aka DTF) is almost exactly 4 oz per sheet and almost exactly half of that is paper. That is the reason, Flitetest plans and directions notwithstanding, I remove all paper all the time. Here in south east Michigan, it will come off all by itself without any encouragement. The only thing holding the kraft paper to the foam are paper fibers embedded in the foam when it is applied. With paper off, the foam can be curved and rolled into lots of neat shapes.
Nolimit, try peeling the paper off from a corner. If it comes off easily, it is best to go ahead and remove it. If it is hard to peel, then it may be worth leaving on. Just remember "lighter fly's better"!
Old Apr 25, 2015, 10:07 PM
NoLimitRC's Avatar
Joined Dec 2014
Oh ok, Thanks, I tried peeling it off, it comes off without a problem. The Max size I found was 100*70cm, the plane need 155*65cm.... Is there a probelm in using two foamsheets for just one part?
Old Apr 26, 2015, 02:42 AM
rockin' roller is offline
Find More Posts by rockin' roller
United States, TX, Dallas
It shouldn't be a problem. you can edge-glue sheets together as necessary.
rockin' roller is offline Find More Posts by rockin' roller
Old Apr 26, 2015, 04:00 AM
NoLimitRC's Avatar
Joined Dec 2014
Ok Thanks, BtW some people call it thermocol...
Old Apr 26, 2015, 07:12 AM
treefinder
springer's Avatar
SE MI
Thermocol... Sounds like the foam that guys from India have talked about as the only foam they can get. From what i recall of their posts on several threads, it is ok for foamies.
The paper on vs paper off controversy is like Pepsi vs Coke. Everyone has their preference, and reasons to pick it. But in the end they both work! We each have to try both and pick the way that works best for us.
Old Apr 26, 2015, 07:36 AM
NoLimitRC's Avatar
Joined Dec 2014
Thanks!, I will make two and see if there is any significant weight difference.
Old Apr 26, 2015, 07:48 AM
treefinder
springer's Avatar
SE MI
Other things to evaluate are how the plane flys, how it survives crashes, and how it builds i.e. how glue joints set up, etc.
Doing it yourself is the best way to know what works for you, and hey, it's only foam! Compared to the tedium of building up a traditional balsa/monocote plane, building a foamie is nearly instantaneous!
Link This may be of interest to anyone wanting to cut foam cores and bag wings. Steve Bailey Sailplane Talk 0 Mar 29, 2015 12:37 PM
Link This may be of interest to anyone wanting to cut foam cores and bag wings. Steve Bailey Sailplane Talk 0 Mar 29, 2015 12:29 PM
Question How would you go about this? Plastic on Foam - Help! mjgravina Beginner Training Area (Aircraft-Electric) 7 Dec 24, 2014 05:09 PM
Discussion Say what? I`m not sure what to think about this story DLGjunkyard Life, The Universe, and Politics 12 Dec 22, 2014 11:49 AM
Discussion FT Crusier Speed Build? What kind of FOAM is this? mhx Electric Plane Talk 2 Feb 27, 2014 11:16 AM
