Old Jul 08, 2014, 02:57 PM
tymrunner is offline
Find More Posts by tymrunner
Joined Mar 2014
Prop Balance issue
Have a look at the video below and explain to me please how a prop can be heavy and light on the same side?
I have 6 of these cf props and cannot balance them.
The balancer is magnetic with an air gap.
I bought the props from Range video http://www.rangevideo.com/en/
propb (0 min 14 sec)
tymrunner is offline Find More Posts by tymrunner
Old Jul 08, 2014, 03:13 PM
MrMikeMartin is offline
Find More Posts by MrMikeMartin
Multirotors, Planes, LOS, FPV
United States, MO, Moscow Mills
Joined Oct 2013
I would have no issues flying with that prop.
I think the issue here is the hole is ever so slightly offset which could be causing this slight movement.
If you spin that up do you notice any vibration? If not, go ahead and use it.
MrMikeMartin is offline Find More Posts by MrMikeMartin
Old Jul 08, 2014, 03:27 PM
Joined Mar 2014
I have significant jello in my video so I am checking motors and props. I want to understand the dynamics of this. They balance horizontal but not @ 45. I am suspected the center hole being off and checked it with my dial indicator and it seems to be centered.
Old Jul 08, 2014, 03:54 PM
PatR is online now
Find More Posts by PatR
United States, OR, Mt Hood
Joined May 2014
Simply balancing blades is not all of propeller balancing. One also needs to balance the hubs, which is a separate activity.
PatR is online now Find More Posts by PatR
Old Jul 08, 2014, 03:55 PM
waltr is offline
Find More Posts by waltr
Team WarpSquad
United States, PA, Doylestown
Joined Jan 2014
The 'hub' is considered out of balance.
Add drops of CA the the light side of the hub until balanced.
waltr is offline Find More Posts by waltr
Old Jul 09, 2014, 02:19 AM
Joined Mar 2014
Well, that is what I did to the prop and it didn't work. As you can see from the video it is both heavy above horizontal and light below it?
Old Jul 09, 2014, 04:33 PM
Joined Mar 2014
I have balanced the props from Range Video. 3 are pretty good just needing a little blade tweaking but the other 3 are way off in the hub area. My guess is the holes are off.
I rebuilt the balance rig to make sure it wasn't the issue. I am now getting repetitive results so I know it is good.
Range Video has looked at the picture below and is sending me 3 new props. They have not mentioned whether they want the bad ones back or not after seeing the pics. I hope not, that will be expensive. I have been pretty happy with the service from those guys so far. Will see how this turns out.
For Sale Readytoflyquads 1050 kv motors, prop balancer, misc props, misc picknuppieces Aircraft - Electric - Multirotor (FS/W) 8 Jan 29, 2014 08:12 PM
Discussion gas/ glow balance and prop shaft issues bob_goes_gas Engines 5 Aug 07, 2009 01:00 AM
Discussion Balance issues on Butterfly Carbon Prop ifxmnfly Scratchbuilt Indoor and Micro Models 3 Jan 01, 2006 02:41 PM
APC SF 9x7.5 prop balance/mount issues? sbmon Power Systems 12 Oct 03, 2005 10:50 AM
