Old Apr 30, 2015, 09:28 AM
magee8578 is online now
Find More Posts by magee8578
United States, CO, Evergreen
Joined Jul 2007
Twisted Hobbys 32" MXS-C...more backyard insanity is here!
First flight last night, wow! The MXS is rock solid at slow speeds and very precise thru all speed ranges. I can't believe foam can fly so good.
magee8578 is online now Find More Posts by magee8578
Old Apr 30, 2015, 10:20 PM
ROLLING CIRCLE is offline
Find More Posts by ROLLING CIRCLE
TEAM TWISTED
ROLLING CIRCLE's Avatar
United States, MD, Middle River
Joined Dec 2011
Great news, Magee! Ballistic power and sweet slow handling. That's ideal!
I'm probably a little tail heavy but my packs are usually a 360mah pack. With the 450 I'm neutral or slightly foreward. Slot for the pack is about 1/2" in front of the ail servo. Batt sits longways down the fuse.
ROLLING CIRCLE is offline Find More Posts by ROLLING CIRCLE
Latest blog entry: Big Cement Pizza Guy - NEW
Old May 01, 2015, 10:27 AM
chickenx5 is offline
Find More Posts by chickenx5
United States, WA, Tacoma
Joined Dec 2006
Hey guys, just built my first MXS-C and had a couple of questions
1 - The pieces of foam that brace the frame ( The long skinny pieces ) "or trusses" I cut the last 3 inches off, and put that up near the motor mount, and i put the rest from the tail forward. However, on other builds ive been looking at i noticed no one else did that.
2 - the manual says to put the clear special tape on stress spots of the aircraft. Where exactly do i put this? It says at the ends of control surfaces so is it basically saying the wing tips to prevent the foam from getting damaged?
thanks for the help!
chickenx5 is offline Find More Posts by chickenx5
Old May 01, 2015, 11:16 AM
ombudsman is online now
Find More Posts by ombudsman
Oklahoma
Joined Sep 2010
Here's what I did (see pic.) I omitted the nose bracing on the upper side where the battery goes.
The tape reinforcement goes at the outboard ends of the control surface hinge lines. I used blenderm over Welder smeared where the tape goes.
ombudsman is online now Find More Posts by ombudsman
Old May 01, 2015, 11:31 AM
Joined Dec 2006
nice thank you for the help! Mine looks very similar but i used a bit more length
Old May 01, 2015, 09:38 PM
TEAM TWISTED
Joined Dec 2011
Sorry late to the party but my 2 cents...
I always use the trusses and in general keep them at the front of the fuse. The side of the plane that has no wires allows me to use the whole piece. The side of the plane that get the receiver and esc usually causes me to leave a break in the truss in the middle of the plane. I end the one that cut at the same point where the one that's mounted continuously ends. That leaves me an extra piece about 4 inches long or so. I've experimented with the last piece; using it as an extra truss on top behind the motor mount on top in two pieces or at the tail in four small pieces but I discard sometimes as well.
There's a lot of threads with the Blenderm technique in them ... but in general you need it on rudder, elevator and the ails at both ends of each hinge on the non-beveled side. Apply Welder, Bend the surface slightly. Apply Blenderm and smooth out the glue that's under the tape until it reaches the edges of the tape. Not too much glue and not too little...
Old May 01, 2015, 11:02 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Just finished building my MXS-C about an hour ago.
As usual, I couldn't wait to fly my new twisted plane and out to the cul-de-sac I go at 10:30 pm.
TX on > Connect battery > LED lights on > Throttle up > It's airborne > trim rudder and elevator > Feels pretty good at recommended CG.
Success - another fantastic flying Twisted plane!
Charging ten (10) 3S 460 packs and looking forward to tomorrow.
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Today, 02:41 AM
benz11 is offline
Find More Posts by benz11
Australia, WA, North Perth
Joined Jan 2014
Hi guys, can anyone tell me what these are? They were included with the control horns. Are they the rudder/elevator servo control arm extensions? Or something else? I cant seem to see them in the .pdf instructions...
Thanks, Ben.
benz11 is offline Find More Posts by benz11
Old Today, 03:58 AM
jasonille is offline
Find More Posts by jasonille
jasonille's Avatar
Germany, RP, KL
Joined Aug 2012
Yes you are right they are the rudder/elevator extensions just use welders or CA and glue them on the top of the servo horn. I used welders and mine have held well over 200+ flights with no problem.
jasonille is offline Find More Posts by jasonille
Old Today, 04:34 AM
benz11 is offline
Joined Jan 2014
Thanks Jasonille! I thought they were, but I didnt want to glue them on now, then find I needed them for something else later in the build!!
Discussion Th 32" epp mxs-c cw flydynamics 3D Foamies 2 Apr 25, 2014 10:30 PM
Wanted Twisted Hobbys 32" EPP Crack Laser byoung Aircraft - Electric - Airplanes (FS/W) 2 Mar 04, 2014 12:11 PM
Poll Twisted Hobbys: 32" Crack Yak or Edge 540 enracer 3D Foamies 3 Dec 16, 2013 07:32 PM
Sold Twisted hobbies 32" laser lite with good equipment! Walker986 Aircraft - Electric - Airplanes (FS/W) 0 Dec 14, 2013 06:26 PM
Sold Twisted Hobbies Edge 540 32" EPP (LPU) Rich215 Aircraft - Electric - Airplanes (FS/W) 5 Oct 23, 2013 07:07 AM
