Old Sep 09, 2013, 07:01 AM
investigator is offline
Find More Posts by investigator
Joined Sep 2013
Question
Running in the engine OS MAX .21 TM. temperature
Engine OS MAX .21 TM
Driven around for instructions http://www.rcmotors.ru/pages/breakinengine/
Put telemetry: RPM, temperature
Has started is easy
Fuel Byron nitromethane 16%, 9% oil
Speed ​​from 10 000 to 13 000
I measure between the radiator and the block.
The temperature rises rapidly from 90 to 120 and beyond.
Very quickly comes to 130.140. I further off the beaten path and wait until cool down to 90 degrees and then start.
The carburetor is open to the factory settings. 3 turns.
Increased to 3.5 turns but the temperature fell.
Whether the situation is normal?
And I can not understand the words of the manual:
COMMENTS: Needle Settings:
- High Speed ​​Needle (Needle Valve) 2-1/2 turns out from close.
To break-in close approximately 30 after running one tank
of fuel through vehicle, repeat five times
- Mid Range Needle (Mixture Control Valve) Screw head is exactly
1/2 turn in from flush with the carb body
- Low Speed ​​Needle (Metering Needle) Turn 30 clockwise to lean
mixture or counter-clockwise to richen mixture
It turns out that the factory setting 2.5 turns. and the first 5 tanks have to close to 30 degrees each time? I mean, just on these sex trafficking? And the mixture is significantly poorer than 3 turns. And the engine will warm up even more.
What is normal for the number of turns of idling?
investigator is offline Find More Posts by investigator
Old Sep 10, 2013, 03:25 AM
Joined Sep 2013
Last night, on the advice of the above:
https://docs.google.com/spreadsheet/...kcFhWWXc#gid=0
Unscrew the needle low speed until until it became deaf. 1.5 turns left
Turnover fell to 6-8 thousand
The temperature went to the Range 80-90
Oil tank with about nateklo 1 cube. This nabryzgalo, and then emerged from vyhlopushki. By the way about the nozzle. The collective farms of shrinking. Skills can temporarily because there is no way to come up with something else.
From the graph shows that 16% of fuel 100ml Byron developed a in 13.5 minutes
The temperature was 85-95 in the second half after enrichment baseman.
Results of the second tank
https://docs.google.com/spreadsheet/...pSjdVVnc#gid=0
Open the gas valve chutchut that would not stalling and warming up. In the second half of the schedule after warming up a little damper closed. But the temperature still barely reached 90.
Discussion Running in the engine OS MAX .21 TM. temperature investigator Car Talk 0 Sep 09, 2013 02:25 AM
