Old Aug 11, 2013, 09:15 PM
InvalidUsername is offline
Find More Posts by InvalidUsername
RC = Empty wallet
InvalidUsername's Avatar
Australia, VIC, Melbourne
Joined Jan 2005
Help!
Motor squeal issue *Solved*
I have a HK YEP 30A esc, controlling a 2830-1130kv motor. Going just past half throttle causes the motor to suddenly jerk and then omit a rough sounding squeal. As that happens it also has a reduction in power, I've tried swapping motors, same problem, so it has to be ESC related?
I've tried all different timing percentages and frequency settings but to no avail
Anyone know of a cure or had any experience with this type of esc?
InvalidUsername is offline Find More Posts by InvalidUsername
Old Aug 11, 2013, 10:07 PM
Joe Blow is online now
Find More Posts by Joe Blow
High on Nitro, Lithium and Air
Joe Blow's Avatar
Joined Jul 2011
I've have the same problem on two different models , changing the ESC timing from low (default setting it came with) to medium completely cured it (using program card).
The sound can be very similar to a dry bearing squeal but with a electronic tone to it.
EDIT: my ESCs was Turnigy plush and only did it on quick accelerations from low to high, so may or may not be the same problem.
Joe Blow is online now Find More Posts by Joe Blow
Old Aug 11, 2013, 10:18 PM
cynr100 is online now
Find More Posts by cynr100
Biomass processor
cynr100's Avatar
Australia, QLD, Cairns
Joined Sep 2012
Also check that you do not have it in any form of Governor Mode.
cynr100 is online now Find More Posts by cynr100
Latest blog entry: KK tuning, props & Yaw
Old Aug 12, 2013, 01:58 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
I had the same issue with my motors in my Phoenix2000 and nothing but changing the ESC could fix it. I think you'll need to bite the bullet and get a new one.
Teamsherman is offline Find More Posts by Teamsherman
Help! Tricopter with KK2 board, squealing motors causing crashes cmanley_nl Multirotor Talk 1 Jun 05, 2013 07:24 PM
Discussion Motor Squeal On Start / Programming Card Witterings Electric Plane Talk 4 Mar 24, 2013 06:47 PM
Discussion motor squealing kenh3497 Power Systems 6 Feb 19, 2013 10:05 AM
Question Phoenix10 & CDR motors, squeals at 100% darkith Castle Creations 2 Jul 08, 2004 03:14 PM
Motor sounds like a squealing pig. Balin Power Systems 4 May 04, 2001 11:27 PM
