Old Jan 29, 2004, 01:16 PM
fga is offline
fga
Find More Posts by fga
fga
fga's Avatar
Staten Island NYC
Joined Dec 2003
formosa prop ?
I postes this in the GWS forum, maybe more will see it here...
http://www.rcgroups.com/forums/showt...hreadid=194092
fga is offline Find More Posts by fga
Old Jan 29, 2004, 02:07 PM
Ralph_D is offline
Find More Posts by Ralph_D
Registered Boozer
Ralph_D's Avatar
United States, CA, Tustin
Joined Sep 2003
I think...emphasis on think...that the direct drive prop(the one with the larger hole in the middle) is put in the package in the event you purchase the Formosa with the 400 motor. The slowflyer props don't really fit the drive shaft and nut on the 400.
That's my best guess.
-Dujara-
Ralph_D is offline Find More Posts by Ralph_D
Old Jan 29, 2004, 02:10 PM
larsy87 is offline
Find More Posts by larsy87
Lookin' Good. Real Good.
larsy87's Avatar
London, Canada
Joined Aug 2002
The thicker one is a HD(hyper drive) prop. It draws less amps then the 9x7 SF(slowfly) and puts out more thrust. But the SF has it's advatanges, I can't remember them though
I put HD props on like so
Nut > Washer > Prop > Washer > Nut
Hold on good.
You can also use fuel tubing but I have never tried it. Good luck with your formosa!
larsy87 is offline Find More Posts by larsy87
Old Jan 29, 2004, 02:40 PM
edkoz is offline
Find More Posts by edkoz
Watch This !!!
edkoz's Avatar
Rochester, MI
Joined Apr 2003
Formosa Packaging
The extra prop is in there because it's cheaper to standardize the packaging to fit a number of different models than to try and only include items for specific models. You have probably noticed that there are also extra trees and plastic parts icluded that are not used on the Formosa.
Ed
edkoz is offline Find More Posts by edkoz
Old Jan 29, 2004, 03:27 PM
Dax is offline
Dax
Find More Posts by Dax
Dax
There is no spoon
Dax's Avatar
Vancouver BC Canada
Joined Aug 2002
The HS prop is WAY better than the slowflyer prop. Just use two washers instead of one. My 'seat of the pants' testing with my formosa shows that the HD prop performs better than the APC prop I was using and WAY better than he slowflyer prop
Dax is offline Find More Posts by Dax
Old Jan 29, 2004, 04:11 PM
TooTall is offline
Find More Posts by TooTall
victim of the system
TooTall's Avatar
Home of the Toledo RC show
Joined Jul 2003
Hi Dax...was this with the stock 350?.....I have found the APC props the best for the brushless set up ....I am working on something that I will use a 350 in ...could be a chance to use my HD props .....I had tried it once in my stock formosa with fuel tubing but went back to a 9x7
TooTall is offline Find More Posts by TooTall
Question Formosa prop query? Sab-Fan Foamies (Kits) 10 Mar 11, 2004 10:27 PM
Formosa prop questions flyboy324 GWS (Grand Wing Servo) 1 Mar 08, 2004 10:54 PM
Formosa prop ? fga GWS (Grand Wing Servo) 4 Jan 30, 2004 04:08 PM
Formosa Prop - Help ErikU Parkflyers 5 Jan 26, 2004 02:31 AM
Help With Heavy Formosa ?prop txfly Power Systems 2 Nov 25, 2003 09:38 PM
