Old Oct 11, 2012, 02:46 PM
rplucky1 is offline
Find More Posts by rplucky1
Joined Oct 2011
Parkzone p51 BL 3 blade prop upgrade
I was planning on changing the stock prop to a Parkzone 3 blade Prop 8.7 x 6
part number PKZ1015. I'm interested in knowing if anyone has tried this specific change and how the outcome was. It seems to sound louder and in hand has more pull, but I've not launched yet. I also was planning on upgrading the ESC to a 30A. My hope is to really gain more thrust, not necessarily more speed.
Comments on this subject appreciated.
rplucky1 is offline Find More Posts by rplucky1
Old Oct 11, 2012, 03:35 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
If thrust is what you are after, your best bet is to to a "larger than stock" diameter two-blade prop (if it will fit!)....3-blade props tend to be less efficient than 2-blade, and 3-4 blades are typically only used when you have clearance issues.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 11, 2012, 04:57 PM
rplucky1 is offline
Joined Oct 2011
Interesting... so a 3 blade doesn't buy me thrust, what about speed? Clearance is not really an issue, I have retracts installed so plenty of height. If I do go with the bigger 2 blade, is it still appropriate to increase the ESC rating as well? Most of the threads and videos I seen seem to indicate that the bigger 2 blade makes it go faster.
Old Oct 11, 2012, 11:32 PM
erikc641 is offline
Find More Posts by erikc641
United States, NM, Las Cruces
Joined Jul 2012
A bigger esc tho possibly uneeded will never hurt. The only draw back is the added size, weight and cost. 2 blades are more efficient than 3 and 4 blades. 3 blades will get you thrust but you can get more for the same amount of amps you r pulling with a 2 blade. The first number on the prop is the diameter, and the second is the pitch. The second number is where your speed comes in. The stock prop is a 9x6, and you want a 8.7x6x3. So you are going to be pulling more A and getting about the same as the stock prop anyways. If speed is what you are after, try the 9x7.5
erikc641 is offline Find More Posts by erikc641
Old Oct 11, 2012, 11:33 PM
erikc641 is offline
Joined Jul 2012
and if you are going to mess around with different props, the 30A is a must, as I can only guess it runs pretty close to 18A stock anyways. Whatever you do, always check it with a wattmeter before flight.
Old Oct 12, 2012, 09:54 AM
rplucky1 is offline
Joined Oct 2011
Actually I was wrong, the bag was miss marked. The pkz1015 is a 9 x 7.5. I'm picking up
the 30A ESC today. Anxious to try some tests. I'm thinking about making some sort
of strain gauge to actually measure if one pulls more than the other. If anyone has an idea on an easy way to measure that, fire away.
Old Oct 12, 2012, 10:05 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
The image shows the vertical arrangement for planes without landing gear. If you have landing gear it can be used horizontally. I got the hanging scale on eBay for a nominal cost.
Jack
jackerbes is offline Find More Posts by jackerbes
Discussion Parkzone p-51 bl motor upgrade. wigsw001 Power Systems 14 Feb 15, 2015 01:17 PM
Discussion Parkzone P51 BL Rudder Control Throw drumgod007 Electric Plane Talk 3 Aug 10, 2012 09:59 AM
Sold Parkzone p51 bl airframe JM66 Aircraft - Electric - Airplanes (FS/W) 3 Jun 28, 2012 07:43 PM
Sold Parkzone Bf-109 3-blade prop and spinner - NEW Hemikiller Aircraft - General - Miscellaneous (FS/W) 2 Jun 22, 2012 10:09 AM
Wanted Parkzone 3-Blade Prop, 9 x 7.5: F4U Corsair, T-28 Trojan Timewarp Aircraft - General - Miscellaneous (FS/W) 1 Apr 02, 2012 02:35 AM
