Old Mar 31, 2012, 01:41 PM
photronix is offline
Find More Posts by photronix
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
Potential GPS performance enhancement
We believe we have found a potential reason for the GPS position hold poor performance seen by some users.
We are working to make this process better and easier for you. But for now we believe you will see improved PH performance by repeating your accelerometer calibration. Here is what you should be aware of. The pro/gps boards must be level to each axis when going through the calibration. BUT level must also be parallel to the crafts level. This may be confusing. Level for the craft is when you switch on autolevel, without wind, and the craft does not drift in any direction.
Performing the trim during autolevel will not affect the PH hold performance.
Please try the following:
Start by zeroing out your trims for ail/elev. Now repeat the accelerometer calibration. Fly once again and try autolevel. If the craft drifts then the calibration was not done properly. During the calibration the positions you used must be off from the crafts level during flight. We believe if you repeat this process untill you do not have drift in autolevel then PH performance should improve. Try slightly different angles.
If autolevel drifts with zero trims then the PH performance will be poor.
If autolevel does not drift then we believe you PH performance should be good.
Once again. We are working to make this easier for you. But for now if you can try this and try to report back your results.
I would like to know.... If you have no drift in AL after calibration is your PH performance good? If you do drift is PH performance poor.
photronix is offline Find More Posts by photronix
Old Mar 31, 2012, 02:12 PM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Looks like I need to get out my big carpenter’s level for this one.
RC Man is online now Find More Posts by RC Man
Old Mar 31, 2012, 05:31 PM
Fastlane66 is offline
Find More Posts by Fastlane66
Crash & Carry..
Fastlane66's Avatar
Norway
Joined Jan 2012
This is interesting, good news!!
This means that later FW versions will make PH check the AL trim?
Fastlane66 is offline Find More Posts by Fastlane66
Old Mar 31, 2012, 05:36 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
Yes hopefully they can get this to be a simpler setup process in the future.
Good to see they found something!
Adidas4275 is offline Find More Posts by Adidas4275
Old Mar 31, 2012, 06:29 PM
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
Yes. Right now PH depends completely on your accelerometer calibration. We will make it much easier for you.
A small 5 degree error in one axis will give you a lateral PH error in that axis and lead to the circling effect with wind.
Old Mar 31, 2012, 06:56 PM
Crash & Carry..
Fastlane66's Avatar
Norway
Joined Jan 2012
Sounds great, this explains the different behaviour of the different aircrafts..
Looking forward to try out the next FW release..!!
Any chance of speeding up the RTH a bit at the same time?
(Or add an "expert mode setup" with possibility to change this)
Old Mar 31, 2012, 08:05 PM
mspencer is offline
Find More Posts by mspencer
Flight Instructor
Chico, CA
Joined Jun 2008
Advanced Settings
No one is ever going to agree on every performance characteristic so advanced settings would be nice!
mspencer is offline Find More Posts by mspencer
Old Mar 31, 2012, 08:43 PM
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
We need to make sure everyone is having a good experience with PH first. Then we can add more variables.
We are trying to make sure that basic functions are working as well as possible. There seems to be alot of FC's chasing features but first just normal flight mode should provide good stable, not robitically jerky, video. Just my two cents worth.
Old Apr 01, 2012, 06:36 AM
ross_badger is offline
Find More Posts by ross_badger
SuperX Hex and X8 Flyer
ross_badger's Avatar
Columbus, IN
Joined Jul 2009
I've been using a home-made calibration fixture for more accurate accelerometer and compass calibrations. It cost me about $20 from parts at the local hardware store. While calibrating, I use a bubble level so I am sure that the boards are perpendicular to the ground, in all directions. My PH and AL have been very good after using this setup.
The full post can be found here:
http://www.rcgroups.com/forums/showthread.php?t=1570188
ross_badger is offline Find More Posts by ross_badger
Old Apr 02, 2012, 10:45 PM
IconFlyer is offline
Find More Posts by IconFlyer
Joined May 2011
Hi Al, I believe this actually may be it...looking at the logs and comparing them to the flying experience it seems like after trimming autolevel and switching on PH, the copter just starts drifting in the direction it was drifting in before PH and trimming. So you're basically saying that PH ignores the trims at the moment and essentially the TBE effect is because the PH algorithm is fighting against the information it gets from the ACCs?
IconFlyer is offline Find More Posts by IconFlyer
Old Apr 03, 2012, 05:39 AM
Krzysiek is offline
Find More Posts by Krzysiek
Joined May 2011
I have a question. If we perform ACC calibration correctly, why do we need to trim? Is it necessary at all?
Krzysiek is offline Find More Posts by Krzysiek
Old Apr 03, 2012, 07:23 AM
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
Because board level may not be craft level in the air. Unless everything is mechanically spot on.
The opposite is true (I believe...still testing). If you trim in AL, why do we need accel calibration. If this is correct then we will removing the accel calibration from the setup client.
Old Apr 03, 2012, 08:39 AM
Dbasileccim is offline
Find More Posts by Dbasileccim
United States, FL, Melbourne
Joined Mar 2011
Been following this thread and I always wondered about how to confirm your board was perfectly "level" with your air frame. I realized that the trim function solved the issue in non-gps auto level mode and stopped thinking about it.
Does it make any sense to zero trim on a windless day, look for any drift, and then "shim" the board until the drift goes away? If I understand correctly that would make the board and the craft functionally level with each other and make all other calibrations more accurate.
Am I thinking correctly?
Dbasileccim is offline Find More Posts by Dbasileccim
Old Apr 03, 2012, 10:11 AM
Wayno Complaino is online now
Find More Posts by Wayno Complaino
Rain Rain Go Away!
Wayno Complaino's Avatar
United Kingdom, England, Milton Keynes
Joined Aug 2011
I did wonder
Wayno Complaino is online now Find More Posts by Wayno Complaino
Old Apr 03, 2012, 07:23 PM
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
Made a lot of progress today with George and we will be rolling the changes into the next firmware release which I know is going to make us all very happy.
There are a whole "slew" of changes and improvements in the next release (wink wink).
Discussion Enhancing transferable skills Anatomist Simulators 3 Feb 29, 2012 11:01 AM
Mini-HowTo skyangel F86 performance enhancing surgery madingle Foamy EDFs 0 Dec 26, 2011 10:52 AM
Discussion GPS Performance mspencer Hoverfly Technologies 61 Dec 23, 2011 09:04 PM
Discussion Excellent GPS Performance! mspencer Hoverfly Technologies 17 Dec 11, 2011 12:12 PM
Discussion GPS performance nickwad Hoverfly Technologies 9 Oct 23, 2011 07:27 PM
