Old Feb 23, 2013, 01:50 PM
v00d0o is offline
Find More Posts by v00d0o
v00d0o's Avatar
United States, VA, Fairfax
Joined Dec 2012
Thanks for the advice!
I think my other issue was having the NAZA hanging off the back edge of the quad. I'm designing a new frame with it smack dab in the middle
v00d0o is offline Find More Posts by v00d0o
Old Feb 23, 2013, 03:17 PM
Olivier_C is online now
Find More Posts by Olivier_C
Since 1902. Maybe.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
These Naza drifts are quite a mystery, I had my 1st build of the quad constantly drifting to the right after take-off, in GPS mode. In ATTI it was less noticable, maybe half the drift. I had to trim left 10 clicks. And for both modes it would stop after like 1 minute, then I'd trim back right to zero. So I speculated it was either a funky feature in the software, or accels or gyros heating up or something. The Naza was mounted with the stock tape, dead center, perfectly aligned (and when I say perfectly, it is, I'm a psychopath , I went with 2 long aluminium rulers, the off-angle was less than 2 millimeters over 500)
Then it went for a swim in the river, I rebuilt the whole frame, mounted the Naza with the same accuracy, same place, with this tape, and... no more drift, ever. I can even put different sizes of props between front and rear and its stuck at the same place if there's no wind, ATTI or GPS.
Now, I cannot say its the new tape, it'd make no sense...
Black magic, I tell you.
Olivier_C is online now Find More Posts by Olivier_C
Old Feb 23, 2013, 03:55 PM
sidneyw is offline
Find More Posts by sidneyw
Lake Zurich, IL
GPS & INS, fly the aircraft and do a couple figure 8, do a couple pirouette left/right; drift no more.
Still windy; but I did take it out on the driveway for a test drive.
All I need is to add some expo to aileron; raised the gain similar to F550.
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Feb 23, 2013, 11:38 PM
jaredstanley is offline
Find More Posts by jaredstanley
United States, CA, SF
Joined Dec 2012
naza assistant software issue? CANNOT UPGRADE FIRMWARE to 2.02
Hey guys,
the assistant software tells me i must upgrade to 2.02 from 2.01.
in this video:
http://youtu.be/SF7NokjeNws?t=1m47s
I can see that the 'upgrade' button is in step 2, but i cannot get to step 2.
the attached screenshots are what I'm seeing. the text etc is all wonky, none of the buttons work in the menu except for 'try again' which just runs step 1 again (second screenshot).
anyone know why? I'm guessing this is a computer issue - i'm on win7 via VMWare Fusion on a retina mbp.
FYI I've tried rebooting windows as well as my machine, and have reinstalled about 20 times.
If anyone knows a workaround that would be awesome.
thanks!
UPDATE: solved the problem - it was just a windows issue...the text was displaying too large.
Right-click the desktop, screen resolution. in there there's a link that says 'make text larger or smaller'. make it 100% and re-open the program and it works.
updated the firmware and ready for the next step!
jaredstanley is offline Find More Posts by jaredstanley
Old Feb 23, 2013, 11:47 PM
sidneyw is offline
Lake Zurich, IL
The screen shots showed you are in Fail-Safe.
Site Sponsor
Old Feb 24, 2013, 12:08 AM
Joined Dec 2012
thanks!
1)...what is failsafe mode?
2)how do I control it? ie what do i want it on and how do i get it there?
EDIT: i have the Spektrum dx6i tx and the Spektrum ar600 rx
Old Feb 24, 2013, 12:18 AM
mark_q is online now
Find More Posts by mark_q
Seattle, WA & Las Vegas, NV
mark_q's Avatar
Joined Sep 2003
Originally Posted by jaredstanley View Post
thanks!
Hey jaredstanley,
Please,
DO NOT APPLY POWER OR ATTACH PROPS UNTIL YOU HAVE READ THE MANUAL ENOUGH TIMES THAT YOU DON'T NEED TO ASK SUCH A QUESTION. ADDITIONALLY, READ THIS THREAD STARTING AT PAGE 1.
If this sounds cold or harsh, sorry. I'm just trying to stop the bleeding before it starts.
Thank you.
mark_q is online now Find More Posts by mark_q
Latest blog entry: $65 Mobile Launcher
Old Feb 24, 2013, 01:13 AM
sidneyw is offline
Lake Zurich, IL
jaredstanley, like Mark said don't attach the props.
DX6 and AR600 are not fail-safe ready. You have to understand the setup first. Using Dx6 or any 6-ch receivers likely Fail-safe is out of the question. It seems your radio of the U-Channel is programmed to Fail-Safe. You can activate gyro gain channel (5) to setup the flight mode; since that is no 3-position switch on you radio you can only use two flight modes instead of 3 - Manual, Atti and GPS. Use Heli mode and the normal, Idle up 1 and 2 to set the flight mode, so that it is out of Fail Safe in the assistant slider.
Another way is not to hook up anything but the Naza controller; use flight pack 4.8v battery to power the controller.
Site Sponsor
Old Feb 24, 2013, 03:09 AM
vtolpaul is offline
Find More Posts by vtolpaul
Joined Feb 2013
Hi everybody! I just finished up my naza f450 kit. nice kit, easy build. The only problem popped up when I first armed the motors to check rotation. They surged and revved when in atti mode but responded fine while in manual.
Upon further investigation, the accelerometer (g) does not reset to zero in tools/calibration- the numbers are stuck. Z is stuck to -15.6g which explains the revving symptom, I guess it thinks it's falling. It gives me an abnormal lmu alarm on the calibrate screen.
Is this a common issue? Do I have a DOA Naza?, and how difficult is this going to be to get resolved
Thanks in advance.
vtolpaul is offline Find More Posts by vtolpaul
Old Feb 24, 2013, 06:33 AM
Since 1902. Maybe.
Olivier_C's Avatar
Joined Dec 2004
It stays at -15.6 even after you press the IMU calibration button ?
Also if you throttle more than 50% in ATTI mode without the props, it's normal for the motors to rev up, because the Naza will "try to climb" and will rev up to 100%, because without props its not going anywhere but it will try to
Old Feb 24, 2013, 11:21 AM
Glenstr is offline
Find More Posts by Glenstr
Glenstr's Avatar
Canada, AB, Lac La Biche
Joined Aug 2010
Just having a look at the new naza with gps I picked up last week and have a couple of questions:
Pretty sure my first one came with 4 little tabs of 3M, one for each corner. The new one has 2, should I mount it with 2, one on each end, or cut them to make 4? It seems that the tape and how it holds the FC on is pretty important, so I want to get it right.
Is is imperative to have the FC dead center on the frame/board when using the GPS? I mounted my other one dead center but have seen where others have it on one of the side tabs.
thanks
Glenstr is offline Find More Posts by Glenstr
Old Feb 24, 2013, 01:23 PM
kallend is offline
Find More Posts by kallend
Flying R/C since 1964
kallend's Avatar
United States, IL, Chicago
Joined Sep 2004
thanks
If you don't have the FC on the CG the x and y accelerometers will pick up movement when you yaw (pirouette), and the FC will try to correct that. The net result is that you won't pirouette about the center, but will make a circle around the center. The bigger the offset the more likely you are to encounter the dreaded TBE.
kallend is offline Find More Posts by kallend
Latest blog entry: Using a DX9 to "strobe" LED...
Old Feb 24, 2013, 02:28 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Not related entirely to naza...but I'm getting some CF boom arms for the future. Do I want a round circle in the center or just a regular square with 1.5mm walls. The square version is 50% cheaper than the circle center squared tube.
Old Feb 24, 2013, 02:58 PM
kallend is offline
kallend's Avatar
Joined Sep 2004
I have a list of Spektrum receivers known to have the appropriate failsafe for use with a NAZA on my blog.
Old Feb 24, 2013, 06:31 PM
Stumptownflier is offline
Find More Posts by Stumptownflier
United States, OR, Portland
Joined Jan 2012
What would cause a constant right yaw? I cant decide if maybe a boom got slightly askew after a crash last fall or if I somehow something in the Naza is not calibrated correctly. I've attached a few photos
Stumptownflier is offline Find More Posts by Stumptownflier
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20194 Jul 25, 2015 08:40 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
