Old Aug 05, 2011, 07:13 AM
Mictronics is offline
Find More Posts by Mictronics
Joined Dec 2009
Mictronics is offline Find More Posts by Mictronics
Last edited by Mictronics; Jul 02, 2012 at 01:48 AM. Reason: Tired of RCG - Quality can be found at FVLAB
Old Aug 05, 2011, 08:26 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by patricklupo View Post
Anyone forsee any issues with soldering a skew planar or clover leaf to a flange type SMA connector?
That looks like a great fit for a skew wheel! I'm going to order a few of those connectors and see if they are easier than my BluBeams.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Aug 05, 2011, 11:18 AM
Nettraptor is offline
Find More Posts by Nettraptor
MK Addict
Nettraptor's Avatar
Hellas
Joined Jun 2009
just finish my antennas for 1.2 and looks like this...
i tested them and they are super..
Originally Posted by Mictronics View Post
Both antennas must have the same polarization. So either both LH or both RH.
For skew-planar and cloverleaf, when you look from the side on the antenna, and the element you look on leans to the right, then it's RH polarization.
Leaning to the left is therefore LH polarization.
For comparison, this is RH:
http://www.rcgroups.com/forums/attac...mentid=3978043
Nettraptor is offline Find More Posts by Nettraptor
Old Aug 05, 2011, 10:31 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Welcome to the world of circular polarization. You can now put your old antennas in a box and tuck it away.... forever
-Alex
Old Aug 08, 2011, 03:23 PM
jhtitan is offline
Find More Posts by jhtitan
jhtitan's Avatar
Washington MO
Joined Jul 2008
a couple pics of my CL and SPW 1280mHz antenna set I just finished.
easy build, PITA to solder up lol, Thanks IBCrazy I can't wait to test them.
I have one question tho, will switching to circular polarization help eliminate interference on my 2.4G rc tx/rx since they are linear? and could you add a 2.4G CL and SPW to you rc tx/rx in the other polarity or would that hinder your radio link?
Jon
jhtitan is offline Find More Posts by jhtitan
Old Aug 08, 2011, 10:27 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Jon
Unfortunately, no. Frequency and polarization are two completely different things.
Also if you check my youtube page you'll see that I bend little hooks on the ends of the wire the exact same length as the feedpoint gap. this makes it much easier to solder and makes it much stronger as well.
-Alex
Old Aug 09, 2011, 01:31 AM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
Thanks Alex. I got a chance to briefly test out my SPW and CL antennas today and it was clear signal all the way with no drop-outs. Previously I'd always get dropouts and lots of static using omni antennas when flying the same route.
patricklupo is offline Find More Posts by patricklupo
Old Aug 09, 2011, 01:57 AM
jkarnacki is offline
Find More Posts by jkarnacki
USA, CA, San Carlos
Joined Nov 2007
WOW patrick those look great. What kind of wire did you use? Looks pretty thick.
I know you mostly fly low altitude with your quad, but watch out if you ever decide to punch the throttle and get some altitude - looks like the body of the quad could block your signal some. But with 1.3ghz you probably won't even notice it unless you venture further out. Just noticed that and thought I should give a warning
- Jeff
jkarnacki is offline Find More Posts by jkarnacki
Old Aug 09, 2011, 02:27 AM
Joined Jul 2009
Hi Jeff, thanks. I used 1.6mm brass wire sold at OSH hardware as 25ft spools in the welding/tools section and flange SMA connectors.
Yep, the CF base will block signal if the copter's directly overhead but not when out a ways. I flew out half mile with omni antennas on video Tx & Rx last weekend to test my FRSky. R/C link RSSI stayed pretty much 100% the whole way but video started to get fuzzy toward the end. Gonna retest with the CP antennas when I get the chance. I'm not looking for range past 1/2 mile but better reception quality and it looks like CP delivers.
Old Aug 09, 2011, 07:09 AM
jhtitan is offline
jhtitan's Avatar
Washington MO
Joined Jul 2008
-Alex
thanks for the tip. not sure what my issue was the last 2 attempts at flying FPV. I am using 2.4G FrSky tx/rx system and range testing on the ground was fine. On the first day, my 5th flight with all my FPV gear mounted was going great when I lost radio link completely. fixed up the plane and swapped cameras (lost my good camera in the crash) Took it back out and again everything was going fine and then boom, no radio link. I didn't lose video link til about 5-10' from impact both times. plane was pointed away from me and a bit behind me. both crashes where in about the same area of my flying field, but its an area I have flown in a lot under normal conditions (no FPV) with no problems at all. and the link was lost at about 100' away from me after flying much further than that in other directions. My video system is the Range Video 1.3G 300mW TX and RX with 5dB whips until now.
Jon
oh and I have added the 60cm antennas to my FrSky rx and have them routed to the tail about 6" apart from each other, with about 22" between them and the vid tx.
Jon
Old Aug 09, 2011, 10:41 AM
evvaldis is offline
Find More Posts by evvaldis
evvaldis's Avatar
Lithuania
Joined Jan 2007
Hello, which measurement is correct?
From the corner to the center(green) or to the soldering place(yellow)?
Also I have to measure to the corner of bending(blue) or to the center of wire(red)? Thanks
evvaldis is offline Find More Posts by evvaldis
Old Aug 09, 2011, 11:49 AM
Peter Seddon is offline
Find More Posts by Peter Seddon
Solihull, England
Joined Jun 2004
So are you suggesting that you add the length of the feedpoint gap to make the hook or that the hook is equal to the feedpoint gap and subtracted from the quarter wavelength wire arm?
I want to build a pair of antenna for 5.8GHz and I am guessing that build accuracy gets more critical at these wavelengths?
Peter
-Alex
Peter Seddon is offline Find More Posts by Peter Seddon
Old Aug 09, 2011, 12:48 PM
Nobert is offline
Find More Posts by Nobert
Nobert's Avatar
Tucson Avra Valley, Arizona, United States
Joined Jul 2002
Alex
Grips is flying his Quad in Canada. Wants 500-700 feet of clear video. I recommended a Range Video on 5.8GHz 200mW system with an IB Crazy SP and CL setup. Your thoughts would be appreciated.
Neal
Nobert is offline Find More Posts by Nobert
Old Aug 10, 2011, 11:05 AM
starjet is offline
Find More Posts by starjet
Joined Jun 2009
600mw 5.8ghz inerference
Hi I recently changed to 5.8ghz from 1.2ghz, I am using the airwaves rc and immersionrc Tx. I found that when powering the Tx using 12v 3 cell lipo I was getting herringbone lines on my monitor but reducing the voltage to 6v solved the issue (6v Ubec). I tested the system but range was rubbish using the omni antennas. I made a set of cp antennas but still getting dropouts at 200m! My question is has the power has been reduced in the Tx by reducing the input voltage? And has anyone else had the same switching interference issues with 12v?
starjet is offline Find More Posts by starjet
Old Aug 10, 2011, 07:51 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by Nobert View Post
Alex
Neal
That will do 1000+ feet with ease.
-Alex
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 06:11 AM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 09:54 AM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 04:59 PM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 05:00 PM
