Old Jan 12, 2013, 09:58 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Originally Posted by Weed89 View Post
perfect would be.....throttle lever off <all the way down> timer off...move the throttle like 1/16" timer starts...but where i have it will work ok for me..the setting is 25%...i tried like 10%...but if the radio was on the timer was going..so that will not work for me
It shouldn't be like that. I have mine at 10% and it works fine. Timer starts above 10% and stops below 10%.
DamonH is offline Find More Posts by DamonH
Old Jan 12, 2013, 10:16 PM
daft pilot is offline
Find More Posts by daft pilot
#14 royal wulf
daft pilot's Avatar
bluegrass state
Joined Dec 2009
Just got home and checked my radio. Didn't realize there was 3 throttle options.
Throttle, throttle 1 time, throttle out.
Weed89 make sure u are on throttle. I set it at %10 and it works perfectly.
daft pilot is offline Find More Posts by daft pilot
Old Jan 12, 2013, 10:50 PM
freechip is online now
Find More Posts by freechip
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
That's cause you are using throttle out.
If he's using throttle (stick) then using 10% means the timer will start/stop at 10%
freechip is online now Find More Posts by freechip
Old Jan 13, 2013, 12:45 AM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
Thanks all...It works perfect Very cool little option...this will perhaps extend my flight time too....as on some planes I get high..and just power off glide around
Weed89 is offline Find More Posts by Weed89
Old Jan 13, 2013, 02:37 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Originally Posted by aerocal View Post
Ok I see what your doing.Im not exactly sure if playing with the TCurve will give you a 2 stage ramp speed.Ill have to play with it some more and see.You are on the right track.
Originally Posted by Arcteryxxx View Post
That is right. I want to have the throttle on the trainer button operated as an on/off switch, but still have a delayed spool-up. What I want to achieve and the reason why is best described in this blog: http://www.rcgroups.com/forums/showthread.php?t=1664669
So if I disable the stick (thr->thr mix), assign the trainer button to a free channel and enable servo delay on it and mix it back to throttle channel, I would achieve the same as if I just put the esc wire in the free channel on the rx, right? But: if throttle curve settings are active with the throttle as slave channel I might be getting close to what I'm after. I'm thinking a second of delay along something like a 0-50-75-90-100 throttle curve.
Will the throttle curve settings be active in this scenario?
Well. Been trying to find a way to program this, but there are a few obstackles making it impossible:
1) When servo speed is adjusted (delayed) the servo input does NOT follow the throttle curve.
2) The delay set is identical in both directions and not adjustable separately. I want ramping with throttle on and immediate action when turning off again.
3) When flying high power applications like hotliners, the count down timer is essential. Typical you have 30 sec of motor-on time during a flight and you use that time to climb +/- 10 times during a single flight. The timer can be set to count-down on the throttle switch (as I have been using with start set to 10%). When I assign the trainer button to start the timer, I have to press two times (start and stop), which is not good for this application. I would like the count-down to run while I was pressing the button and to stop upon release.
@Andy: Any chance of adding a motor menu in future AirWare releases?
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Jan 13, 2013, 02:48 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Check out the DX18 sailplane features. They sound like what you want.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Jan 13, 2013, 02:56 PM
Arcteryxxx's Avatar
Joined Feb 2010
Andy
I was afraid of that answer.
Was hoping to get my 8 to provide this rather basic function.
Old Jan 13, 2013, 03:01 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
That rather basic special class of glider function. The DX8 is not a sailplane radio by any stretch.
Andy
Site Sponsor
Old Jan 13, 2013, 03:04 PM
Arcteryxxx's Avatar
Joined Feb 2010
LOL! I rest my case
If anyone has made a workaround, please let me know.....
Old Jan 13, 2013, 05:57 PM
Barry2020 is offline
Find More Posts by Barry2020
United States, CA, Camarillo
Joined Jul 2012
LOL! I rest my case
I've noticed firmware errors that affect DX8 functionality also. You can't be sure the DX18 doesn't have the same kind of problems as well.
What you could do instead, is to use a hardware solution. This web site has a servo recorder/player..
http://www.bpesolutions.com/rcequip.html
Unfortunately, those items are not inexpensive. Did you try using another channel for throttle control?
Barry2020 is offline Find More Posts by Barry2020
Old Jan 13, 2013, 07:19 PM
Fig Jam is offline
Find More Posts by Fig Jam
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
LOL! I rest my case
The DX8 was never and has never been promoted as a glider transmitter, if you had performed your due diligence you would have known that.
Fig Jam is offline Find More Posts by Fig Jam
Old Jan 13, 2013, 08:12 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
hmmmmmmm the worlds most advanced 8 channel radio doesn't offer sailplane programming but the futaba 8fg super does? that doesn't make sense to me, or perhaps I'm just confused. for those of you that say well the 8fg is really 14 channels, well when it was 8 channels it still had glider programming, i personally don't fly gliders however I wouldn't be calling my dx8 the most advanced 8 channel radio in the world if it doesn't offer at least the same options as the competitors. I will tell you this, if it had just a little more software features (channel mapping and sailplane support) then it may just be worthy of that title. That being said, I do like my dx8 and it has been reliable.
keithy4129 is offline Find More Posts by keithy4129
Old Jan 13, 2013, 08:20 PM
Fig Jam is offline
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
It doesn't make sense to me either but they never hid the fact that it only has Air and Heli programming. Buyer reads the Specs and then makes his choice.
Old Jan 13, 2013, 09:04 PM
Joined Jul 2012
Andy
Here's mine. You mean its not a sailplane after all?
http://en.wikipedia.org/wiki/Glider_(sailplane)
Maybe you mean a 'full house' motor glider with E/R/A/F/S.
Old Jan 14, 2013, 12:09 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Could you put a servo slower on the throttle? They cost only a few bucks.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Foamie Resurrection
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
