Old Dec 27, 2006, 06:39 PM
booke23 is offline
Find More Posts by booke23
Joined Dec 2004
50 size 4 stroke...on a Seagull PC-9?
Hi all.
I have just started building my seagull PC-9 and would like to use a 4 stroke motor in it.
I am thinking of an OS FS-52 surpass, or Magnum 52rfs..maybe a thunder tiger 54.
However all these engines are quoted as producing around 0.9 bhp......quite a bit less than say an os 46ax 2 stroke (1.5bhp)
So i am curious if any of you are flying a Pc-9 with one of the above 4 strokes......what is the performance like?
booke23 is offline Find More Posts by booke23
Old Dec 27, 2006, 06:48 PM
blizzardwarrior7 is offline
Find More Posts by blizzardwarrior7
In Massive Debt
Northampton Massachussetts
Joined Jun 2005
I flew mine with a magnum .52 four stroke, and a Evolution .46. Both of them require you to dremel out the mount to get them to fit. You get more speed with the 2 stroke definitely. And the four stroke sticks out the bottom of the cowl quite a bit. I think youll have more fun if you go the 2 stroke route.
blizzardwarrior7 is offline Find More Posts by blizzardwarrior7
Old Dec 29, 2006, 10:01 AM
rheumatical is offline
Find More Posts by rheumatical
United States, IL, Naperville
Joined Sep 2005
flew mine with magnum 52 4stroke and 12x5 prop. Couldnt be happier with the performance.
rheumatical is offline Find More Posts by rheumatical
Old Aug 31, 2009, 04:35 PM
TSmith4UA is offline
Find More Posts by TSmith4UA
Pull up, unless inverted!
Lincoln, AL
Joined Jul 2009
I had an old Enya .40SS in mine and it pulled the mess out of it. Floated in for a landing very nicely with a lighter engine.
TSmith4UA is offline Find More Posts by TSmith4UA
Old Aug 31, 2009, 04:54 PM
lucasavaitor is offline
Find More Posts by lucasavaitor
Joined Aug 2008
In my opinion, the horsepower ratings are next to useless. How do you know if it was even tested? It could just be an estimate, or a biased test. Go by displacement size. The 4 strokes will definitely give you enough power.
lucasavaitor is offline Find More Posts by lucasavaitor
Old Sep 01, 2009, 07:14 AM
I TOBOR is offline
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
Amen Lucas, I think of fourstrokes in terms Flying Power rather than HP and they have it in spades. An OS .52, Saito .56 or an Enya .53 will fly your plane just fine.
I TOBOR is offline Find More Posts by I TOBOR
Discussion 4 stroke on a hangar 9 P51 trainer? stashu Beginner Training Area (Fuel) 5 Apr 27, 2006 09:38 AM
Opinions on ultrafly PC-9 flight characteristics? microflite Electric Plane Talk 2 Oct 22, 2004 02:29 AM
WTB: Good, used .30 size 4 stroke thomer Aircraft - Fuel - Airplanes (FS/W) 0 Sep 13, 2003 12:56 PM
Need advice on Seagull PC-9 pgjoh1 Fuel Plane Talk 0 Aug 28, 2002 03:38 PM
