Old Apr 08, 2015, 07:32 AM
kevmeist is offline
Find More Posts by kevmeist
United States, FL, Rockledge
Joined Oct 2011
Connector types
From looking at connectors recently, I ran across this site:
http://www.tjinguytech.com/reviews/rc-connectors
Maybe many of you have seen this before? As a noob to boating but have run a SC truck for a few years (all with Deans connectors)...I thought that this URL might help some others?
Do bullet connectors exist with "shrouds", so that shrink wrap is NOT necessary?
K
kevmeist is offline Find More Posts by kevmeist
Old Apr 08, 2015, 08:08 AM
rbachmann is offline
Find More Posts by rbachmann
speed-boater
rbachmann's Avatar
Stuttgart, Germany
Joined Apr 2010
Hi K.
A good knowledge about connectors is the general basis of all battery/esc/motor systems.
Unfortunately a lot of the users donŽt have this knowledge.
Therefore the linked page is interesting and instructive.
Most of the national raceboaters have similar "experts" oder pages -> this is the german version -> CLICK.
Question 2:
yes, they exist - one example here -> CLICK.
You can get them for a wide range of applications and loads.
Roland
rbachmann is offline Find More Posts by rbachmann
Old Apr 08, 2015, 08:17 AM
kevmeist is offline
Joined Oct 2011
Hi Roland,
The URL for protected connectors is for 4mm, HK do not seem to have the same for 5.5mm bullets.
Regards,
Kevin
Originally Posted by rbachmann View Post
Hi K.
Question 2:
Roland
Old Apr 08, 2015, 08:49 AM
speed-boater
rbachmann's Avatar
Stuttgart, Germany
Joined Apr 2010
Hello Kevin.
YouŽre right, but you didnŽt mention that you are looking for 5.5mm connectors.
6mm would be possible -> CLICK.
And 5mm would also be possible -> CLICK
Do you need exactly 5.5mm connectors?
Roland
Old Apr 08, 2015, 08:52 AM
kevmeist is offline
Joined Oct 2011
My bad....5.5mm were recommended upgrades for an Proboat Impulse 31 boat. My son and I currently use Deans on everything. I'll check out your link. Thanks.
I suppose 6 mm would do...maybe these would also do:
Progressive RC has EC5 connectors with plastic shrouds. See here:
http://www.progressiverc.com/ez-sold...onnectors.html
They are rated at 120A.
K
Hello Kevin.
Roland
Old Apr 08, 2015, 08:55 AM
speed-boater
rbachmann's Avatar
Stuttgart, Germany
Joined Apr 2010
.. see post above.
Take 6mm or 5mm EC5 and youŽll be fine.
Good luck
Roland
Old Apr 08, 2015, 08:59 AM
kevmeist is offline
Joined Oct 2011
Thanks Roland.....
Regards,
K
.. see post above.
Good luck
Roland
Old Apr 11, 2015, 08:10 AM
spiro_1 is offline
Find More Posts by spiro_1
spiro_1's Avatar
United States, NY, Sodus
Joined Feb 2013
I have a question
my batterys are 12 guage 4mm conectors and esc and motor are 10 guage and 5mm connectors, will this be alright or should i have gotton bigger batts that have 10 guage wires. I have 2 4s in series to get 8s, esc is 200 amp and motor is1280 kv or 730kv and im running at 730kv
thanks Alan
spiro_1 is offline Find More Posts by spiro_1
Old Apr 11, 2015, 09:13 AM
hangtheman is offline
Find More Posts by hangtheman
Kid at heart..
United States, TX, Houston
Joined Apr 2014
You need to know the amp draw of your motor/ESC and make sure your battery can handle the load.
hangtheman is offline Find More Posts by hangtheman
Old Apr 12, 2015, 06:28 AM
spiro_1 is offline
spiro_1's Avatar
Joined Feb 2013
Ok here is my motor, esc, batterys im gonna try and run it today if i can find a nice spot. I was just worried about the wires being to small, whats the worst that can happen, FIRE
Motor
Max Current: 128A @ "Y" 730kv / 229A @ "Δ" 1280kv, set @ 730kv
ESC
Motor Type: Brushless, sensorless motors only
Input Voltage: NIMH 15-33 cell, Lipo 6-12 cell
Operation Current: 200A Cont, 250A peak
Battery
Capacity: 5000mAh
Voltage: 4S1P / 4 Cell / 14.8V
Discharge: 65C Constant / 130C Burst
Old Apr 12, 2015, 08:59 AM
Kid at heart..
Joined Apr 2014
I think you should be fine. Those batteries are rated over 300amps constant. I am surprised they only come with 4mm connector. Usually those come with 5.5mm connectors. But based on the specs it should be fine. Have a good time running the boat..
Discussion Blade MCX2 & MCPX2 Heli connector types BARSALB Batteries and Chargers 0 Mar 16, 2015 03:59 PM
Discussion Advice on New type EC3 connector, rear side cut FixedPitch Batteries and Chargers 3 Jan 10, 2015 11:53 AM
Question Connector type for IBCrazy / Bluebeams? xoxota FPV Talk 3 Jan 06, 2015 10:38 PM
Question Connector type for IBCrazy / Bluebeam Antennas? xoxota FPV Equipment 0 Jan 05, 2015 10:22 PM
Question Crius multiwii AIOP board connectors type ? MarLi Multirotor Electronics 0 Dec 29, 2014 11:40 AM
