Old Dec 28, 2014, 06:13 PM
LADDIE is offline
Find More Posts by LADDIE
DUNDAS CANADA
Joined Feb 2006
Laddie's DYKE DELTA
This is my third Dyke Delta I built since 1970. At that time I drew the plans and built 50” Dyke Delta. I was unlucky with it. On maiden, during take off, strong gust of wind from one side, flipped the model on it’s back. The damage was extensive so I scrapped the model.
Approximately, 20 years later I built smaller 40” Dyke Delta for electric/glow power. I used ASTRO 15 geared motor or O.S. .26 four stroke engine. RCM magazine in Oct. of 1997 published the plans for it.
This year in Fall, I was looking what to build. I remembered small version of Dyke Delta. I decided to build Dyke Delta again, but using original plans for 50” version.
So, here it is. The model is of all balsa construction except the cowl which is a foam. The model is powered with TURNIGY D2826/10 and 3S-5000mA LiPos. The model has electric retracts. The maiden will be done in Spring. I do not fly in cold weather.
LADDIE is offline Find More Posts by LADDIE
Old Dec 28, 2014, 08:30 PM
Dennis Sumner is offline
Find More Posts by Dennis Sumner
Wanted for breaking Ohm's Law
Dennis Sumner's Avatar
United States, MI, Canton
Joined Sep 2002
Looks like you've been quite busy...lots of new models to maiden in the Spring.
I like the Dyke Delta. Good luck on all your maidens.
Denny
Dennis Sumner is offline Find More Posts by Dennis Sumner
Old Dec 28, 2014, 09:11 PM
BlazerB52 is offline
Find More Posts by BlazerB52
BlazerB52's Avatar
Fenton,MO USA
Joined Aug 2005
I like the looks of that plane. Hope she flies great. Are plans still avilable for that plane?
Blazer
BlazerB52 is offline Find More Posts by BlazerB52
Old Dec 28, 2014, 09:20 PM
Steve Merrill is offline
Find More Posts by Steve Merrill
Steve Merrill's Avatar
USA, IL, St Charles
Joined Nov 2002
Looks nice Laddie. Question: What do you use for adding monokote over monokote? (I am assuming you used Monokote covering). I don't see any bubbles, nice job!! - Do you just use heat, or solvent, or Windex??
Steve Merrill is offline Find More Posts by Steve Merrill
Old Dec 28, 2014, 09:27 PM
GAANDAHL is offline
Find More Posts by GAANDAHL
GAANDAHL's Avatar
Red Wing, MN
Joined Aug 2000
Laddie,
Good to see this one! I bought the MAN plans a couple of years back and cut some parts. I have not built it yet. Maybe I'll finish it in 2015!
GAANDAHL is offline Find More Posts by GAANDAHL
Old Dec 29, 2014, 05:57 AM
LADDIE is offline
DUNDAS CANADA
Joined Feb 2006
I used Ultrakote to cover the model, except cowl which was painted.
I set the temperature on high.
Laddie.
Old Apr 30, 2015, 09:14 AM
LADDIE is offline
DUNDAS CANADA
Joined Feb 2006
Laddie's R/C DYKE DELTA (3 min 11 sec)
Old Apr 30, 2015, 09:22 AM
LADDIE is offline
DUNDAS CANADA
Joined Feb 2006
This text was supposed to accompany the video, but it did not work for me. I am having difficulty posting the videos from my picture files to this tread. Finally I maiden the Dyke Delta. As you can see on a video, it flies great. Only thing I need to master is the landing. I have to come in at flatter angle so that the nose gear does not hit the ground hard and then pushes the nose up causing a stall. My model has electric retracts but they failed to work after two or three cycles when testing them in my workshop.
Old Apr 30, 2015, 03:42 PM
Lnagel is online now
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Nice flying airplane and a good job on the video. I found the plans for your 40" Dyke Delta on outerzone. Other than size is there any difference in the design of the 40" version and the 50" version?
Larry
Lnagel is online now Find More Posts by Lnagel
Old Apr 30, 2015, 05:24 PM
LADDIE is offline
DUNDAS CANADA
Joined Feb 2006
There is not much difference between them.
Discussion micro Dyke Delta MichaelConnally Scratchbuilt Indoor and Micro Models 18 Oct 31, 2010 09:31 PM
Question Dyke Delta (possible future project) Aerobatics Man Scale Fuel Planes 2 Jun 06, 2006 07:33 PM
Dyke Delta #2 pbotto Scale Fuel Planes 2 Aug 02, 2003 12:42 PM
Dyke Delta pbotto Scale Fuel Planes 5 Jul 04, 2003 10:42 AM
