Old Oct 24, 2013, 05:21 PM
Lnagel is online now
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Originally Posted by sandydr View Post
Hi Larry
I'm stuck again
I have cut and shaped the wing tips so far to match the rib, but I am struggling to understand the plans regarding the wing tip edge. I don't quite understand what the curves and lines mean in reference to the variable wing tip height. Any light you can shed would be most appreciated.
Regards, Sandy
Those curved lines show the wing tip cross sections at the three points. When shaping my wing tip is I used those curves to make three templates. I then used those templates to shape the bottom of the wing tip. Note that the top of the wing tip is straight across in line with the top of the wing. When shaping the wing tip material is removed only from the bottom.
Your next task is to shape the top of the wing tip block to match the outline of the top of the wing tip drawing. Then remove material from the bottom of the wing tip to match the templates.
Larry
Lnagel is online now Find More Posts by Lnagel
Old Oct 25, 2013, 01:48 PM
Russell Bear is offline
Find More Posts by Russell Bear
Russell Bear's Avatar
Manvel, Texas
Joined Nov 2007
Description: Dynaflite Decathlon
Great flying plane....
Russell Bear is offline Find More Posts by Russell Bear
Old Oct 25, 2013, 04:32 PM
sandydr is offline
Find More Posts by sandydr
Need a bigger runway
sandydr's Avatar
Dominican Republic, Puerto Plata, Cabarete
Joined Mar 2008
Thanks Larry, I knew you would know the answer. You photo makes it so much easier to understand. They should include it in the manual
All the best, Sandy
sandydr is offline Find More Posts by sandydr
Sold Dynaflite Super Decathlon Giant Scale Kit spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 3 Jul 01, 2013 04:51 PM
Sold Dynaflite Super Decathlon MIKEYOUR Aircraft - Fuel - Airplanes (FS/W) 4 Mar 20, 2013 06:07 PM
Sold Dynaflite Decathlon MIKEYOUR Aircraft - Fuel - Airplanes (FS/W) 4 Mar 19, 2013 09:23 PM
Gallery Super Decathlon Dynaflite Tavinho Your Plane Photos 0 Apr 27, 2005 07:38 PM
Gallery Super Decathlon Dynaflite Tavinho Your Plane Photos 0 Apr 27, 2005 07:33 PM
