Old Jul 17, 2013, 09:41 PM
JTerrori is offline
Find More Posts by JTerrori
Joined Jun 2013
Help!
Aileron mixing for high alpha
I want to know what setup could be used to mix the ailerons? So that they go up to allow more air while flying high alpha. If I get any I deas on how to do it I will do it on my RcPowers F22
JTerrori is offline Find More Posts by JTerrori
Old Jul 18, 2013, 02:56 PM
jirkajiranek is offline
Find More Posts by jirkajiranek
dzejdzej
jirkajiranek's Avatar
Czech Republic, Pardubice
Joined Oct 2008
Hi,
This is possible using flaperons. You need servo for each flaperon / airleron.
With this setup You can activate elevator to flaps mixing. Some Tx already has this function preprogrammed.
I'm using this setup, but I'm activating flaps using switch, not the mix with elevator. This function is normally used for sharper up/down plane movement.
JJ
jirkajiranek is offline Find More Posts by jirkajiranek
Old Jul 18, 2013, 09:28 PM
JTerrori is offline
Joined Jun 2013
I just realized I need a better transmitter ._. form the DX5E to an DX6i for more channels
Old Jul 19, 2013, 04:49 PM
dzejdzej
Joined Oct 2008
Hi,
I've checked dx5 manual and You are right. I have DX7 for 6 years now, I'm very satisfied. Consider DX7 or DX8. I think dx6 will not be enough sooner or later.....
JJ
Old Jul 20, 2013, 10:12 AM
JTerrori is offline
Joined Jun 2013
Well I'm on a really low budget right now. I don't have $300 + for a DX7 considering it comes with it's receiver. I think the DX6i will do for now, I don't need to go crazy on all those channels. I just need to add some spoilerons for high alpha and I'm satisfied with just that Thanks for replying BTW
Old Jul 23, 2013, 01:54 PM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
HK 9xR
http://www.hobbyking.com/hobbyking/s...?strSearch=9xr
Grejen is offline Find More Posts by Grejen
Old Jul 24, 2013, 08:52 AM
JTerrori is offline
Joined Jun 2013
Nope, i don't trust this people for radio systems. I trust Spektrum better.
Old Jul 24, 2013, 01:27 PM
milk00069 is offline
Find More Posts by milk00069
Joined Sep 2010
just link your ailerons to your tailerons, one servo per side. so when full up is give all 4 control surfaces will move together (http://static.rcgroups.net/forums/at...90-coupled.jpg). and no additional channels are needed and you'll high alpha all day
milk00069 is offline Find More Posts by milk00069
Old Jul 24, 2013, 04:36 PM
JTerrori is offline
Joined Jun 2013
Thanks for the advice, I will try this with my new F18
Discussion Aileron/Rudder mixing on a Quad or Hex brinnus Multirotor Talk 10 Sep 21, 2014 07:29 AM
Question High Wing Trainer or Archer for Aileron Training?? Gimpdiggity Beginner Training Area (Aircraft-Electric) 11 Jul 15, 2013 04:53 AM
Discussion Y-harness or mixing for ailerons xzodiackxs Radios 5 Jun 19, 2013 09:13 AM
Question Independently controlled stabs mixed w/ailerons for high roll rate? CactusJackSlade 3D Flying 11 Mar 05, 2004 05:29 AM
