Old Feb 01, 2004, 02:24 PM
Brian T is offline
Find More Posts by Brian T
Brian T's Avatar
Langley B.C Canada
Joined Feb 2003
power system?
I have a scratch built biplane with a wing span of about 28". it's wieght is about 8 oz with covering. any idea's and a good motor & gearbox combo? I have a couple GWS 300c motor & gearbox combo's left from my many crashes and some speed 400's as well.
would any of these work or would they be too much ?any idea's?
Cheers Brain
Brian T is offline Find More Posts by Brian T
Old Feb 01, 2004, 02:52 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
If you need weight up front, then a lightly run big engine is electrically efficient, but power to weight is not good.
If its 80z bare, its likely to be 12-14oz with motor and pack, which is spot on 300 territory IMHO.
Can you weigh it all up with radio, and a 300, box prop, etc to get an all up weight?
If its over 16 oz, then a 400, but 300 would be better IMHO.
Old Feb 01, 2004, 04:16 PM
Brian T is offline
Brian T's Avatar
Langley B.C Canada
Joined Feb 2003
Power
ok with a 300c motor and a 9.6v 730mAh bat, it's about 13.5/14oz. here's a pic of the motor I flew it with it had no climb and no speed really to speak of .
Thanks Brian
Old Feb 01, 2004, 06:14 PM
mu2freighter is offline
Find More Posts by mu2freighter
easily confused
mu2freighter's Avatar
Nashville Metro, Tennessee, United States
Joined Sep 2003
That's an IPS motor...never mind climb or speed, I'm surprised it even stayed airborne...
I have an IPS with S2 gearing in my 7.4 oz. Northrop Alpha and it's fine but I'd hate to think of it trying to pull a 13.5 oz. airplane around.
Glenn
mu2freighter is offline Find More Posts by mu2freighter
Old Feb 01, 2004, 06:47 PM
Brian T is offline
Brian T's Avatar
Langley B.C Canada
Joined Feb 2003
That was the motor the fellow at the hobby shop said I should use, as the plane when finished weighted 8oz with the covering??? I suffer from not having enough experience I guess. but like I said it was up there but just barely..lol.. Since my last post I've put in the 300c with a 9070 prop I had kicking around, it went really much better climbed good and had some speed. but now it's just so much balsa smashed all over the feild weeeeeee.....
Back to the old drawing board
Cheers Brian
Old Feb 01, 2004, 10:54 PM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
I'll second the EPS-300 recommendation. Any brushless in that size would work as well. Which model is it? Got any pics?
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
hotliner on a low cost power system ? oded mazor Electric Sailplanes 12 May 07, 2002 03:42 PM
Ziln XIII Elektro Power System ? LNL Electric Plane Talk 1 Jul 23, 2001 06:30 PM
Airtronics Eclipse Power System? Brian Nixon Electric Sailplanes 7 Jul 06, 2001 12:17 AM
Astro 020 power system JohnM Power Systems 21 May 21, 2001 03:12 PM
Suggestions for Power System for Robbe K-rat TThroop Electric Sailplanes 1 May 10, 2001 05:47 PM
