Old Yesterday, 12:30 PM
Doc Austin is online now
Find More Posts by Doc Austin
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I signed up for the email restock notification on the Laser and I'll post here when I get it.
My current Laser has been a superb airplane. I built it from the beginning to use Hitec's new 7.4 volt servos, and those dropped right in with no modification. Of course, since I used an HS5087 on the elevator I had to modify that, but I plan to use a 5070MH on the next one, and that won't require any modification.
As far as power systems, I am not even going to worry about the new Torque motor because the old Torque motor is still kicking and hauling ass. Along with that I will use the Airboss ESC and a Castle 10 amp BEC set to 7.4 volts.
I am also going to keep using the racing wing tips from the 48" MXS. Initially I started playing around with them just because they look so cool, and then kind of lost interest in the because they tame the plane down a little too much. I tried them again on the laser because the color matched so well, and I learned how to fly the plane a little differently to take advantage of the tip's added stability and fly around that when I wanted the plane to span or spin violently. I still don't have it completely figured out, but I am getting there and it's simply another good challenge.
Doc Austin is online now Find More Posts by Doc Austin
Wanted Extreme flight 48 inch Extra EXP parts knifeedge63 Aircraft - Electric - Airplanes (FS/W) 5 Jun 23, 2014 11:10 PM
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Alert For sale Extreme flight 48 inch edge exp rtf cheap rudyhal Atlanta Area RC 7 May 28, 2011 12:32 PM
Sold Extreme Flight Extra EXP 48 inch w/ Airboss45 ESC- Torque2814/820 combo (Austin, TX) HKC3 Aircraft - Electric - Airplanes (FS/W) 17 Feb 05, 2011 10:49 PM
