Old Aug 18, 2010, 08:07 AM
cvandenb is offline
Find More Posts by cvandenb
cvandenb's Avatar
Manchester
Joined Jul 2008
Originally Posted by Niall View Post
Could this also be the issue that Charl is seeing, or is it more likely clock fuses are messed up?
Hi Niall,
I have a standard JR PPM receiver and with the ESC's directly connected, the ESC's arms immediately.
I used to have a Corana RX, and yes, they do take a while to start up. This is generally the case with PCM receivers... PCM receivers do take longer as they need to look for a "good" signal... PPM ones just take what they get
My JR is immediate.
BR
cvandenb is offline Find More Posts by cvandenb
Old Aug 18, 2010, 08:25 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
Originally Posted by Scorpia View Post
Looking at the website, it looks like its being setup as a full shop.
www.multicopter.kr
Does anyone know if the files etc for this version of the board will be available to DIY?
i like the look of the pictures , looks like the frame could be quiet nice.
Also i couldnt see any mention of Rolfe or Kaptainkuk there anywhere
wish i could read what ever language the website is in, theres probably a link there somewhere.
yes it looks like a shop. the schematic of the pcb is the same but he added pads for the LYPR540 and the small version of the enc-03r piezo gyros.
try the google translater to read parts of the site..
warthox is offline Find More Posts by warthox
Old Aug 18, 2010, 08:33 AM
jjk77 is offline
Find More Posts by jjk77
No, it's the same plane ...
jjk77's Avatar
Deutschland, Nordrhein-Westfalen, Bochum
Joined Jul 2010
Hi there,
i got a question as i had the ccw and cw props here. Well, it is obviously a dumb question, do the moter of the ccw prop also turns ccw? I have wired it so that this happens, but perhaps my understanding is wrong and only the prop has to be ccw but the motor turns cw ...
Jens
jjk77 is offline Find More Posts by jjk77
Old Aug 18, 2010, 08:50 AM
dt8666 is offline
Find More Posts by dt8666
Joined Oct 2005
Guys... anyone have good luck with the HK Blue or Mystery ESC? those 12A range version?
Plush series no stock for some time already.
dt8666 is offline Find More Posts by dt8666
Old Aug 18, 2010, 09:14 AM
F.O.D is offline
Find More Posts by F.O.D
Joined Feb 2010
Hey!
Im building a quad and it need to lift aboute 400-600g. Im getting GWS hd0905 3blade ccw cw props. Can u help me with a good motor??? Pleace!! All my tricopter have 750-860kv and SF props, but now i need more power, and getting a quad i the way i want to go. I need more kv for the HD props right? I have 3s and 4s batterys. Help! hehehe. Motors form HK pleace.
thanks a 1,000,000!!
Alex
F.O.D is offline Find More Posts by F.O.D
Old Aug 18, 2010, 09:22 AM
coda vex is offline
Find More Posts by coda vex
Kansas, USA
Joined Aug 2010
Originally Posted by jjk77 View Post
Hi there,
Jens
Jens, I'm just starting my project so someone else with more experience can comment, but yes I believe those two motors with spin in a CCW motion.
coda vex is offline Find More Posts by coda vex
Old Aug 18, 2010, 09:46 AM
Jakub J is offline
Find More Posts by Jakub J
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
Originally Posted by F.O.D View Post
Hey!
Im building a quad and it need to lift aboute 400-600g. Im getting GWS hd0905 3blade ccw cw props. Can u help me...
No problem - if you want to fly with 600g payload think
about sexy or octo not quad... My 2 cents
J.
Jakub J is offline Find More Posts by Jakub J
Site Sponsor
Old Aug 18, 2010, 09:48 AM
F.O.D is offline
Joined Feb 2010
J.
but my tricopter can do it with SF props.
Alex
Old Aug 18, 2010, 10:45 AM
Jakub J is offline
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
Alex
How long?
If you want fly longer than a few minutes, and safe
do not excess 350-400g / motor...
Jakub
Site Sponsor
Old Aug 18, 2010, 11:01 AM
pabmadi is offline
Find More Posts by pabmadi
pabmadi's Avatar
Joined Feb 2009
93 US Dolar for a complete board?
pabmadi is offline Find More Posts by pabmadi
Old Aug 18, 2010, 11:45 AM
Niall is offline
Find More Posts by Niall
Joined May 2010
Looks good... I will be very interested in seeing how these ST gyros work out. They will knock a third off the build cost for the controller.
Niall is offline Find More Posts by Niall
Old Aug 18, 2010, 12:08 PM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
Niall, Kaptein,
I'm unfortunately having EXACTLY the same issues as cvandenb?? I'm using a carona rx and jr tx, I can't get it to "listen"???
Please help,
Dion
rcimports is offline Find More Posts by rcimports
Old Aug 18, 2010, 12:13 PM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
V6 Through Hole 5 x 5 cm double sided PCB
For the caps can we resume this?
C1,2,3,4,9,10,11: 100nF ceramic capasitor. no polarization (small caps)
C7: electrolyte or tantalum with a value of 10uF and upwards.
C5,6,8: 0.68uF Tantalum.
manuLRK
Originally Posted by kapteinkuk View Post
I was using Elfa's capacitors when making the layout
10uF, 2.54 spacing and 5mm diametre: https://www.elfa.se/elfa3~no_en/elfa/init.do?shop=ELFA_NO-EN#item=67-714-21;
33uF, 2.54 spacing and 6mm diametre. https://www.elfa.se/elfa3~no_en/elfa/init.do?shop=ELFA_NO-EN#item=67-714-23;
So they exists!
You can carefully straighten the legs of the 5.08mm to make them fit into 2.54 spacing. The max diameter of the caps exept C7 and C9 is 5mm. C7 and C9 is 6mm.
Also alternative values of the caps is:
C1,2,3: 0.68uF to ca 100uF. Or 100nF ceramic cap.
C5,6,8: 0.68uF.
C7,9: I have done a bit of reading on decoupling caps, as I should have done before Until now I have used my design practice ("Tantalums is the st, ceramic caps not needed", "Larger is better" and "what do I have in my box?")
The correct value and type of the C9 cap is 100nF ceramic cap. The C7 can be a electrolyte or tantalum with a value of 4.7uF and upwards.
C4,10,11: 100nF ceramic cap.
The 100nF is available in 2.54 spacing
So this chaos boils down to:
Looks good?
alll is offline Find More Posts by alll
Old Aug 18, 2010, 12:16 PM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
Just finalized my build - Great board KapteinKUK!!!! So Stable - And what a great match with Jakub's frame - Still tweaking settings and added a Fy20a (not that this board really needs it!) Anyway - I am using 11x3.8 cw & ccw props (12x3.8 cut down) - Getting about 9 minutes of flight time on a 3s2200 pack - video later -
cdi3d is offline Find More Posts by cdi3d
F.O.D is offline
Joined Feb 2010
How long?
Jakub
Yes theat is right my tri dont fly more then 5min. My quad wil be 1650 with 4 70g motores. So that vil be 412g / motor. Then i need 650-700g max pr motor. Do u know any motor for GWS hd0950 3 balde that gives 650-700g??
Alex
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
