Old May 26, 2009, 01:56 PM
tvcasualty is offline
Find More Posts by tvcasualty
Erik with a K
tvcasualty's Avatar
Toledo, OH
Joined Aug 2007
Hey, in looking at other forums... I found this stuff:
http://www.industrialpolymers.com/st...FQyVFQodZ17y2Q
I don't think it's flexible, but it sure would dress up a foam model to a level par with any ARF.
More info from the seller (copied from the phlatforum.com)
Dear Frank,
We greatly appreciate your comments and suggestions.
We recently discovered that our product is being independently repackaged and sold on web sites for EPS foam airplanes. One of the sites and their videos can be viewed at http://www.wowplanes.com. The owner of the web site has also developed a water based sanding sealer for the foam made by mixing water putty, plaster of paris and our Styroprime sealer. He has several videos on the web site.
Pricing for the StyroSpray 1000 is $52. 38 per gallon. It is sold in 2 gallon kits, $104.76 for the 2 gallons. This product does not contain water or solvent, so your coverage will be much greater than other coatings you are using. A gallon of water based paint is usually about 40% water. A gallon of house paint which costs $35.00 actually costs $49.00 when you factor in the lost water which evaporates away. With StyroSpray nothing evaporates away. We do recommend a heavy coverage of 50 to 60 square feet per gallon for outdoor applications.
The weight of this product is 9.21 pounds per gallon. If you apply 1 gallon per 50 square feet of surface area as we recommend for high durability applications, you will cover 50 square feet, 32/1000 of an inch thick. If I divide 9.21 by 50, each square foot will have an additional coating weight of .1842 pounds. I think it is possible you will apply our coating thinner than this, so I will say this is likely the max amount of weight you will add. .1842 pounds is equal to 2.947 ounces of added weight, per square foot of surface area.
I do not know how many square feet of surface area one of your air planes has.
Thank you for inquiring about our products. Please let me know if you have more questions.
Best regards,
David Boddie
IPC USA 800-766-3832
david@industrialpolymers.com
tvcasualty is offline Find More Posts by tvcasualty
Old May 27, 2009, 01:22 PM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
I guess this could be acrylic hard coat, but that stuff is kinda heavy!
Harpye is offline Find More Posts by Harpye
Old May 27, 2009, 01:24 PM
Harpye is offline
Harpye's Avatar
Germany
Today I started with the gear mounts ... the mount came up a bit heavy overall but VERY solid ....
Hansjoerg
Old May 27, 2009, 01:37 PM
Erik with a K
tvcasualty's Avatar
Toledo, OH
Joined Aug 2007
Hansjerg, those look great! I'm so envious!
Does the EPP airframe absorb any shock on landing then?
Great job!
Old May 27, 2009, 01:58 PM
Harpye is offline
Harpye's Avatar
Germany
It is all reinforced with carbon and Aluminium...
Old May 27, 2009, 01:59 PM
Harpye is offline
Harpye's Avatar
Germany
as you can see the 2 slots in front and rear the retracts they are equiped with 2x 8mm carbon tubes... pretty solid!!!
... some more pics outside ...Weight is 680gram empty
200 gram accu
120 Gram Motor
100Gram Servos and RX
50 Gram ESC
30 gram color
1200 Gram AUW
Old May 27, 2009, 03:22 PM
electriceye is offline
Find More Posts by electriceye
Kiss the Sky
electriceye's Avatar
Dorking, Surrey, UK
Joined Jul 2006
This is model engineering in the true sense.
electriceye is offline Find More Posts by electriceye
Old May 27, 2009, 04:06 PM
Harpye is offline
Harpye's Avatar
Germany
E-Eye: Thanks again!
Hansjoerg
Old May 28, 2009, 01:11 PM
Harpye is offline
Harpye's Avatar
Germany
Retracts Testing
Ok ... I glued the inner wing sections to the fuse and pre installed the gear servo.. As this is real speed ( no retarder) I think I don't have to buy one...
Testing of DIY Retracts for My Hawker Typhoon Project! (0 min 28 sec)
Old May 28, 2009, 08:34 PM
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Hey Harp,
Awesome LG! Looks very cool. Is that real grass? Looks too perfect
Pete
mtflyr is offline Find More Posts by mtflyr
Old May 29, 2009, 01:39 PM
Harpye is offline
Harpye's Avatar
Germany
Hello Pete!
The grass is not my job... I got the " brown thumb " of my family as whatever plant I touch dies within some weeks ( I like those bonsais that much but as expensive as they are ...you wouldn't believe how fast I burry them....
BTW: I bought myself a new cam for Xmas and I'm very glad with it... the details you get using optical 12 MPIX are superb..
BTW.: not much progress on the plane today .... I hinged the ailerons and next I will cut the servo pockets for those....
It is rather time to choose the setup!
I put my eye on this Motor: 18T
http://www.parkflieger.eu/Scorpion-S..._1493_298.html
or on this ( here the 22 Turns version, for not to fry the controller)
http://www.parkflieger.eu/Dualsky-BL..._1178_167.html
and this controller
http://www.parkflieger.eu/Scorpion-C..._1635_305.html
But they are both rather expensive compared with the HC products
I also would need 4 mini servos 15..20 Gram ( usually I take HS82 for this issues but if there other recommendations... ( also for the motor and the ESC????))
Old May 29, 2009, 02:08 PM
tuppertn is offline
Find More Posts by tuppertn
Postcards From The Purple Edge
tuppertn's Avatar
United States, OK, Sand Springs
Joined May 2007
or on this ( the 22 Turns version, for not to fry the controller)
I have the Scorpion 3014-22 on a 45oz, 60" Me-109 foamie. It's well underpropped with a GWS 12x6. Really wants 4s. Nice motor though.
kendall
tuppertn is offline Find More Posts by tuppertn
Old May 29, 2009, 02:14 PM
Harpye is offline
Harpye's Avatar
Germany
Hi Kendall
Thanks for the hint! I guess I will try the 18T version on 11" ... 3S 2200 25C and a 45 A controller.... should move the 1.2 KG of weight......
Old May 29, 2009, 09:58 PM
Don McGill is offline
Find More Posts by Don McGill
Happy2ndChildhood
Don McGill's Avatar
London Ontario
Joined Aug 2005
Beautiful job on the retracts.
I have never gone near retracts since my club field breaks them on a regular basis. The pics of your fabricated retract system looks like they would survive even at our field!
Don McGill is offline Find More Posts by Don McGill
Old May 30, 2009, 02:56 AM
Harpye is offline
Harpye's Avatar
Germany
Don ... As the retracts are made from Aluminium and steel for bolts and screws it became rather heavy ( 48 Gram / Unit + Rod + Wheel..) but this would also keep a 2 to 3 KG plane on the wheels!!
Help! Retracts for Hawker Typhoon jhspring Scale Kit/Scratch Built 3 Sep 13, 2007 12:00 PM
Hawker Hunter for Midi fan Jones Boy Electric Ducted Fan Jet Talk 237 Oct 17, 2006 03:58 AM
FS: Stein Model 1/12 Hawker Typhoon JPHen Aircraft - Electric - Airplanes (FS/W) 2 Jan 17, 2005 10:20 PM
Just another Hawker Typhoon Helge Sondresen Scale Kit/Scratch Built 8 Nov 04, 2002 09:37 AM
18 cell Hawker Typhoon flies! Ron Daniels Scale Kit/Scratch Built 5 Jul 03, 2002 12:02 PM
