Old Apr 02, 2013, 03:03 PM
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Lockheed F-104 Starfighter in Tetris Bukvorez style construction
Lockheed F-104 Starfighter, also known as the Widowmaker is one of the best looking military jets. Very few kit choices available and they are generally heavy requiring very high performance EDF for power.
I am trying to convince the Russian Bukvorez model manufacturer to produce a foam Tetris F104 for sale. All we need is 10 interested in building one and they would consider producing it. My preference would be a kit in the 2.1 to 2.38M length to be powered with a moderately high powered 90mm fan (8-10S 90mm). Essential to keep weight down with the 104's small wing so I would plan no fiberglass but cover with vinyl. Perhaps chrome, to simulate the polished alloy finish that so many had.
If you think you would like to build one please post your desire on the last page of the link posted.
http://www.rcgroups.com/forums/showthread.php?t=1520445
Here is an Philip Avonds (by H. Van Dongen) model that is 2.38m (94") long with 1.11m (44") span including tanks to get some idea of the size for reference.
Also a picture of the XK104 prototype and test pilot Chuck Yeager
4stripes is online now Find More Posts by 4stripes
Old Apr 02, 2013, 07:53 PM
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
A 90mm fan on 8-10S is to small for an F104 in the Avonds size.
You may be on the right track if you follow this great thread:
http://www.rcgroups.com/forums/showthread.php?t=1454523
strictlyscale is offline Find More Posts by strictlyscale
Old Apr 02, 2013, 09:23 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
that is a pic of yeager in the NF-104 ...note the space suit he's wearing ...they did zoom flights up to 100,000 ft + with a small rocket motor built into the tail ...only built 2 one crashed and other is on pole here at Edwards out side the test pilot school. i think a 80" one would be better for 8-10s on a 90mm fan.
AIR SALLY is online now Find More Posts by AIR SALLY
Old Apr 02, 2013, 09:57 PM
4stripes's Avatar
Joined Jan 2009
Thanks for your input everyone!
Perhaps I'm thinking a 1.1m span would be ideal for 90mm. This brings the length to the Avonds size fuse of 2.3m. As long as the weight can be kept under 5kg a 90mm can do the job.
This is the whole reason I chose the Tetris foam build.
I am aware weight will make our break this build and any chance for decent flying qualities.
Old Apr 03, 2013, 07:53 PM
Philadelphia, PA
As a comparison point my Avonds on 12S, 127mm dynamax weighed 23lbs rtf.
Old Apr 04, 2013, 05:39 AM
4stripes's Avatar
Joined Jan 2009
Wow! must be a handful to fly at that weight.
Perhaps 2m length is a better starting point....
It's beginning to look like there isn't enough interest .
Thanks again.
Cheers Eric
Old Apr 04, 2013, 10:36 AM
sbritton's Avatar
USA, CA, El Dorado Hills
Joined Apr 2008
I hate to say it, but you might be better off compromising a bit on the scale wing and make it a little bigger to help with flight characteristics. Not talking cartoon large...just 15% or so bigger might make all the difference.
No one wants to build a 90mm plane that is going to be a handful to fly.
sbritton is offline Find More Posts by sbritton
Old Apr 04, 2013, 11:11 AM
Not Funny......
Mike Warren's Avatar
United States, CO, Redstone
Joined Dec 2010
104's are not "a handful to fly", they only look like they should be......
Mike Warren is offline Find More Posts by Mike Warren
Old Apr 04, 2013, 01:12 PM
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
+1 on that, the only people that say the F-104 needs a bigger wing are the ones that have not flown one.
Ralph
CRCJA is offline Find More Posts by CRCJA
Old Apr 04, 2013, 03:53 PM
Joined Apr 2004
This is what I did on my 1/10 104 if scale is an issue. The only issue is the wing. Scale air foil and size.
Go as close to 100% scale as possible, then adjust as little as possible to get good handling as an RC model for it's size and weight.
The point is to fly it and get it down safely........................... AND look right. Very right.
Or just build plastic or static models.
Steve
SCALECRAFT is offline Find More Posts by SCALECRAFT
Österreich, Stmk., Graz-Umgebung
Joined Sep 2011
You are on the right way!!
Think about a JePe Mirage with a longer fuselage ... 45cm longer nose and 45cm more at the tail No problem, or?!
George
GeorgeStyriaII is offline Find More Posts by GeorgeStyriaII
Old Apr 04, 2013, 05:20 PM
4stripes's Avatar
Joined Jan 2009
thanks George!
Perhaps the best thing to do is give it a try.
If it doesn't work, upgrade power till it does work.
My gut instinct is go bigger and keep all efforts in keeping it light. A lead sled is not fun to fly. Exciting, yes, but fun, no.
Old Apr 04, 2013, 06:36 PM
sbritton's Avatar
Joined Apr 2008
I'll admit, I haven't flown one for that exact reason...looks like a serious handful.
I mean...isn't this called the "widow maker"?
If I get one more plane my wife is gonna kill me...and live true to the "widow maker" moniker.
Old Apr 04, 2013, 07:46 PM
Not Funny......
Joined Dec 2010
Originally Posted by sbritton View Post
I'll admit, ?.............looks like a serious handful.
Yes, the German pilots did give it that nickname........it did have a notably high accident rate in Luftwaffe service.......but that was because of the mission and conditions it was flown in and not because it was inherently "a handful".
Spain, Norway, Netherlands, Belgium, Italy, Jordan, Japan, Taiwan, and more flew them too and it was no more known as a pilot killer than any other fighter at the time.
The plane really makes a very nice flying model; difficult only because of seeing its tiny shape in flight.
Is it a sunny afternoon thermal glider? No. Is it a 3D "Extra" or .40 sized trainer? No.
Even heavy, when set up right, the 104 is a stable, smooth, joy to fly with no more bad habits than any other jet.
........your wife may not be so easy to handle
-Mike
Old Apr 04, 2013, 09:05 PM
Joined Apr 2004
Mine flew under almost the worst edf configuration I could put into an air frame and it flew.
Just need air speed. And it a model, I'm not in it.
Steve
Discussion F-104 Starfighter- GIANT profile pusher jet greenseaships Foamies (Scratchbuilt) 15 Oct 15, 2014 08:37 PM
Build Log f 15 1800mm tetris from bukvorez build thread gianni sanchez Foamy EDFs 59 Feb 20, 2014 04:55 AM
Discussion Widowmaker! anyone interested in building a 90mm EDF F104 Tetris/Bukvorez foam style? 4stripes Scratchbuilt EDFs 27 Jul 14, 2013 07:51 AM
Wanted HET F-104 Starfighter jricchio Aircraft - Electric - Jets (FS/W) 3 Jan 16, 2013 03:52 PM
Sold HET 70mm F-104 Starfighter ARF/NIB -For Sale- flyinhigh025 Aircraft - Electric - Jets (FS/W) 7 Jan 03, 2013 04:18 PM
