Old Jan 08, 2013, 05:33 PM
Joined Jan 2013
need help with powering a dumas TC
HI GUYS
i'm new , never done an R/C model before need some advice
i am building the Tuner Clipper i have the hull done am just trying to work out what motor i'm going to need
i want to spin a 60cm 4xb prop with out a nozzel or 50CM 4XB in a steering nozzel
with a big reduction , what motor in 12v do i need ?
and witch ESC is the best for getting the rpm down low for positive manoeuvring (docking )
i don't want it start at 500rpm and jump forward , like some of the models Ive seen on
U -TUBE
i was think of a 540 motor with a big reduction and slow rpm ? i assume the bigger reduction the easier it will be on the motor ( SAME AS A REAL BOAT ) and if the props big enough it will push it along to scale 18 knots
what is the difference between an in runner and out runner motor ?
i want to mount the motor back over the top of the shaft as these boat needs LOTS of ballast by what Ive read in this thread
so as much room for 12v rechargeable batteries as possible ? (types brands ?)
all so any RX TX brands names and sizes would be great as i have no idea what to by
is a water cooled motor best ? do you need a extra pump to circulate the water through the jacket ?
will the mounting plates except the water cooled motors ?
looking forward to some replies
i have step by step build pic of the hull up to now
cheers bob
OLD SHRIMPER is offline Find More Posts by OLD SHRIMPER
Old Jan 08, 2013, 11:43 PM
Tollytime's Avatar
United States, MI, Macomb
Joined Nov 2006
The high torque belt drive comes to mind. I think they use these on th Mr. Darby tug.
http://www.harbormodels.com/site08/motors.htm
Tollytime is offline Find More Posts by Tollytime
Help! need help with power harness wvteacooker Beginner Training Area (Heli-Electric) 1 Dec 22, 2012 02:29 PM
Discussion i need some help with power setups Looking_Up Racing Boats - Electric 5 Oct 10, 2012 07:16 PM
Discussion I need help with the power supply for hobbico accu-check charger chrisorbics Batteries and Chargers 13 Aug 15, 2012 12:48 PM
Help! Need Help With Dual Switch Dual Battery Power System unclecrash Power Systems 3 May 14, 2012 03:37 PM
Discussion Need some help with my power system copperbricks Power Systems 1 Mar 03, 2012 10:20 AM
