Old Mar 12, 2012, 03:29 PM
Norge, Østfold, Fredrikstad
Joined Oct 2011
bixler motor uppgrade
hi, i was woundering to buy this motor http://www.hobbyking.com/hobbyking/s...idProduct=7993 for a bixler.
but i want the mounting the other way so i wont have to press the shaft to the other side. so i found this motor http://www.hobbyking.com/hobbyking/s...dProduct=18117. will it be good?
i want to use a 6*4e prop,
thx.
n00lesd is offline Find More Posts by n00lesd
Old Mar 14, 2012, 11:04 AM
Joined Oct 2011
noe one has any idea how this will work?
i badly want so hints on what to buy, dont want to buy a motor that will be al crap on plane.
Old Mar 14, 2012, 11:24 AM
Joined Feb 2012
To make a bigger/stronger/faster motor be able to be mounted on that air frame, your going to need a mount like this..... See bottom right pic of page.
http://fpvpilot.com/EasyStarMotormount.aspx
Specter72 is offline Find More Posts by Specter72
Old Mar 14, 2012, 01:20 PM
RVA
RVA's Avatar
United States, CA, Long Beach
Joined Jan 2011
I can't help you with your original suggestions but I did use an 2200kv inrunner with similar specs. 13 bucks. Works fine. I don't understand any need to reinvent the wheel unless you are looking for the challenge. Plenty of discussion on this elsewhere. Example: top post of Papo's bixler build log...too many options to list...http://www.rcgroups.com/forums/member.php?u=332365
As far as my $13, 2835, 2200kv inrunner...it just fits right in. No adjustments needed. Just a little hot glue. Is the nacelle strong enough? Has been so far. No additional mount needed.
BTW, my .2 cents, the aftermarket mounts are crucial if using an outrunner that is larger than the diameter of the internal nacelle or if one wants to use a larger than 6x4 prop. I may be wrong, but I don't see how the external mount will make the setup stronger. The nacelle stem is what I consider the weakest part and, as I see it, the mount does not address that.
RVA is offline Find More Posts by RVA
Old Mar 14, 2012, 06:41 PM
Joined Feb 2012
I agree with you RVA. :^)
I didn't intend to state that it provided a improvement in airframe mounting strength to handle the motor. That mount I linked, was just to easily allow his linked larger motor (& most likely a stronger motor)to be mounted with it's reverse shaft configuration issue.
Personally , I think it's a bonus though to have a bigger prop option as well . :^)
Old Mar 17, 2012, 01:46 PM
Joined Oct 2011
i have been looking at that motor mount, but dont think il use it.
dont realy need it, and i realy dont need bigger prop if im going to use any of the motors, 2200kv and bigger prop then 6*4 will just make alot of heat.
the other is 2500kv.
but will it be ok whit 6*4 prop and a 2500kv motor?
Video bixler gopro follow 2nd bixler Westwood Electric Plane Talk 0 Feb 25, 2012 08:28 PM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Discussion Bixler Upgrade Motor tomtom4867 Electric Plane Talk 1 Oct 09, 2011 06:44 PM
Question A Motor for the Bixler from HK ???!! Please help khaled_abobakr FPV Talk 13 Jun 01, 2011 09:59 AM
Is there anyone that has tried to uppgrade a Quick EP to 550 blades? nicco Electric Heli Talk 0 Mar 22, 2004 03:32 AM
