Old Oct 12, 2011, 01:57 PM
closeflyby's Avatar
United States, CA
Joined May 2010
Adding transistor to Tx
So I have an esky tx that I like to use on the sim as it only takes 4 aa but its designed to work on 6v and when I use rechearables the light only goes up to the last green light(before it goes yellow then red) so it only lasts for about an hour. Would adding a transistor be the solution to the lower voltage?
closeflyby is offline Find More Posts by closeflyby
Latest blog entry: Christmas Day FPV Flight!
Old Oct 12, 2011, 03:35 PM
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
No.
srnet is offline Find More Posts by srnet
Old Oct 12, 2011, 04:29 PM
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
If used only for sim, a 6V DC adapter would replace the 4 Alkaline just fine, just mind the polarity!
coriolan is online now Find More Posts by coriolan
Old Oct 12, 2011, 06:15 PM
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
A good way to modify your radio to make it rechargeable might be to adapt it to a 5-cell AAA flat pack. A pack like that ought to fit where the four AA cells normally go, and all you'd have to do is hook it up.
CheapBatteryPacks.com could make an 800 mAH pack for you. Just go to this page and select
  • Cell count: 5
  • Flat Pack
  • CPB800AAA cell
  • 22 AWG wire
  • No Plug
and it should quote you a price of $13.50.
Miami Mike is offline Find More Posts by Miami Mike
Help! Main output transistor on TX burnt out -- C4735 equivalent? minifly DIY Electronics 23 Jun 29, 2014 09:36 PM
Discussion Adding AUX or Gear servo runway34r Electric Plane Talk 1 Sep 10, 2011 02:14 PM
Discussion Visual Transistor-level Simulation of the 6502 CPU MikeSt DIY Electronics 5 Aug 12, 2011 11:37 AM
Sold Elenco DT-100 Diode / Transistor Tester bob_nj Aircraft - General - Radio Equipment (FS/W) 0 Mar 28, 2011 02:06 PM
Main output transistor on TX burnt out. Need replacement chileno DIY Electronics 2 Oct 27, 2005 05:33 AM
