Old Jun 09, 2011, 05:44 PM
Gone Insane .... Back Soon!!
Meebo's Avatar
Joined Dec 2010
Newbie - Common Sizes of Carbon ??
Heya guys,
I plan on placing a large order of EPP Foam, Carbon Tubes and or Carbon Rods but i don't really know what sizes of carbon to get.
I'm ordering 3mm, 6mm and 9mm EPP and will prolly build planes out of all, small ones for inside and larger ones for outside, standard fliers and VPP planes.
What diameter carbon do you commonly use for each thickness of foam and tube or rods??
Wing Spar
Elevator Spar
Fuselage Bracing
Servo Control Rods
etc etc
Cheers
Meebo is offline Find More Posts by Meebo
Old Jun 09, 2011, 05:47 PM
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
Wing Spar -- 3mm tube for 6mm foam. -- 3 or 6mm tube for 9mm foam.
Elevator Spar Same as wing, but no 6mm tube. Just 3mm
Fuselage Bracing Depends on how you want to do it. 1mm sticks to make a zig-jag pattern, or just 3mm tubes
Servo Control Rods Probley 1-2mm sticks or 3mm tubes. Depends on size of plane.
Hope this helped
PinkYakRC is offline Find More Posts by PinkYakRC
Old Jun 10, 2011, 06:25 PM
Meebo's Avatar
Joined Dec 2010
Yes Pinky that has helped, Thank You.
Are there any other sizes one should have on hand ??
Old Jun 10, 2011, 06:46 PM
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
Your welcome!
If you have some 1mm sticks, 3mm tubes and 6mm tubes and you should be set.
Old Jun 11, 2011, 01:27 AM
In Rc for a LONG TIME FFAA#1
laserman's Avatar
Canada, ON, Ottawa
Joined Jun 2004
and also get some carbon tow, flat strips allows for following curves
laserman is offline Find More Posts by laserman
Old Jun 11, 2011, 06:00 PM
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
Yeah. Flat strips are great to have on hand.
Old Jun 11, 2011, 06:06 PM
Meebo's Avatar
Joined Dec 2010
Would you use these as protection for the foam running along the edges so the foam doesn't crumble on impact ??
Old Jun 11, 2011, 06:27 PM
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
Yes
nylon banding strap works great also as does packing tape for leading edges
RogueTitan is offline Find More Posts by RogueTitan
Discussion Electric motor sizes V's Glow motor sizes woodsy Australia 9 Mar 23, 2011 09:37 PM
common carbon sizes for 3mm depron foamie Joa Foamies (Kits) 1 Sep 03, 2005 04:11 AM
Common metric sizes? Mr. Wiz Electric Plane Talk 16 Jun 13, 2003 06:39 AM
Most useful sizes of Carbon fiber rod? rick2048 Parkflyers 8 Sep 23, 2002 11:31 PM
Need carbon fiber sizes for the "Mini" Danny Troy Parkflyers 2 May 29, 2001 03:51 AM
