Old May 23, 2001, 01:28 PM
Ralph Weaver's Avatar
Indianapolis, IN USA
Joined Nov 2000
The circuit is easy, but you'll need some way to dissipate a lot of heat. That means multiple transistors and/or a large heat sink with a fan.
I have a schematic at home I'll try to dig up.
Ralph Weaver is offline Find More Posts by Ralph Weaver
Old May 23, 2001, 03:24 PM
Rhode Island
Joined Oct 2000
Yeah, I kinda figured something like this would need lots of big heat sinks. Not a problem.
As long as I don't need to install an HVAC system for it
Thanks!
BobK is offline Find More Posts by BobK
Old May 24, 2001, 12:32 AM
Rhode Island
Joined Oct 2000
Constant current load
Can anyone point me to a schematic for a constant current load? I'm mostly interested in something that draws ten amps with a source voltage of between 6 volts and 12 volts, and 20 amps with perhaps a bit wider voltage range.
TIA!
-Bob
Old May 24, 2001, 08:44 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I'd be curious about this too..
Old May 24, 2001, 10:16 AM
Electric Airplane Junkie
bhchan's Avatar
San Mateo, Ca , USA
Joined Jun 2000
heat dissipation is not a problem. I drop my resistor bank in a bucket of water and when the battery discharging is done, I can make tea!! Also big heat sink with a fan. I made one(not constant current) for discharging 27 cells, I have a 5V fan on the heatsink with a 5V regulator fed off the discharging pack. WHen the fan stop, it is done. Also great for warming the shop in winter.
Brian
bhchan is offline Find More Posts by bhchan
Old May 24, 2001, 01:34 PM
bhchan's Avatar
San Mateo, Ca , USA
Joined Jun 2000
I was just kidding about making tea, I use about 2-3 gallons of water in a bucket and it probably raised the temp from 65 degF to about 80 degF when it is done.
Brian
Old May 24, 2001, 06:19 PM
Austin, Texas USA
Joined Mar 2001
I came across a supply of 1.5 amp 12 volt automotive bulbs. Just wire them in parallel. Or, better yet, use the bases and you can add/delete bulbs to change the current draw.
Shawn
Eflightpower.com
sf_247 is offline Find More Posts by sf_247
Old May 24, 2001, 06:20 PM
Austin, Texas USA
Joined Mar 2001
I came across a cheap supply of 1.5 amp 12 volt automotive bulbs. Just wire them in parallel. Or, better yet, use the bases and you can add/delete bulbs to change the current draw.
Problem is that no, it is not a constant current as voltage drops.
Shawn
Eflightpower.com
Old May 25, 2001, 12:01 AM
Wilsonville, OR, USA
Joined Mar 2000
Bob Kopski talked about one he has in his MAN column several months ago. He sent me a copy of his schematic but it wasn't finalized at the time. I don't understand electronics so can't complete it myself. Electrons still fall in the category of "magic" to me. The dissipation components are put in cold water. And he cautions don't let the water boil because the heat transfer stops!
Keith
Keith Watson is offline Find More Posts by Keith Watson
Old May 25, 2001, 06:15 AM
england
Joined Jan 2001
Why not pulse the load?: say one second on nine seconds off. You can stress the battery in a realistic way at high current, without producing too much heat to dissipate.
Steve
steve glass is offline Find More Posts by steve glass
Old May 25, 2001, 07:43 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Voltage drop under constant load, as in flight, is the whole idea.. Pulsing it on and off will not be of much use (except when measuring battery performance for F5B-style flying, where the motor is only run for a few seconds at a time).
..a
Old May 25, 2001, 08:29 AM
Joined Nov 2000
Light bulbs, resistors etc. work OK to cycle the cells, but don't give repeatable results for serious testing. If you have the $$ you might check out the Competition Electronics Turbo 35+. It's what I use. 1, 6 and 7 cells up to 35A. http://www.competitionelectronics.com/trbothty.html
Building your own 10-40A will cost maybe $100-200 unless you can get a lot of the stuff surplus.
Anyone wants a schematic for a high current load? simingx DIY Electronics 20 Jan 27, 2008 10:28 AM
Discussion DIY analog constant-current discharger? meteor DIY Electronics 7 Jan 06, 2006 10:09 AM
Looking for constant current sink arneansper DIY Electronics 4 Jun 05, 2005 07:13 PM
LM317 constant current charger. thermite Batteries and Chargers 4 Jun 21, 2003 09:16 AM
Article Make a Constant Current Nicad Charger Red Bar Room Batteries and Chargers 0 Jun 01, 1996 12:00 AM
