Old May 13, 2014, 08:03 AM
Joined May 2014
Sky surfer motor problem
I bought a new sky surfer and noticed my motor is leaning alot to the left. My question is how do you straighten it? Is glued or do I have to seperAte my plane
Billyboy2 is offline Find More Posts by Billyboy2
Old May 13, 2014, 10:09 AM
Joined May 2014
Anybody have any idea as to what I'm supposed to do? Some guys must have upgraded this motor!!
Old May 13, 2014, 10:18 AM
...one of my nicer landings
United States, WA, Walla Walla
Joined Mar 2014
Do you mean the motor is secure but pointed left? How far left? If it troubles you, unscrew it from the firewall/motor mount and put a washer (within reason) or shim the firewall or make a new one to straighten it out.
suddenstop is offline Find More Posts by suddenstop
Old May 14, 2014, 12:34 AM
altitude adjustment
thumbhead's Avatar
USA, CA, Irvine
Joined Mar 2005
I'm pretty sure the Sky Surfer has a built in thrust angle to counter act the forces of a spinning prop. I would try flying it before making any adjustments. It probably faces up a lot also.
Mark
thumbhead is offline Find More Posts by thumbhead
Old May 14, 2014, 03:49 AM
Joined May 2014
well I'm still skeptical about it ...Yes the motor is secure and is pointing left when you look at it from the top angle , You can also see the motor crooked in the fuselage... I don't see any screws at all holding it in place either. wonder if it's only glued in there, but I will try what thumbhead suggested, I will give it a try first to see what it does...And post my results
Thanks for the tips
Old May 18, 2014, 09:48 AM
Joined May 2014
well today was the day for the maiden flight...I had trouble doing the first flight as we're getting a bunch of rain lately and when it's not raining it's too windy..
Anyhow, it did fly pretty descent .... All was going great 'til about 3 minutes of flight , then the prop broke off.Literally broke both ends at the core. I know they're pretty cheap but never would of thought it would break.
What's the best replacement? was thinking of going with a 6 x 4 APC prop....
Thanks a bunch
Poll sky hawk,bixler,or sky surfer Mopower71 Parkflyers 12 Mar 06, 2014 11:47 PM
Sold Extreme Surfer / Super Sky Surfer 2.4 meter (94 inches) Johnnymeg Aircraft - Electric - Airplanes (FS/W) 0 Mar 03, 2014 06:09 PM
Sold D3536-1250kv brushless outrunner super sky surfer motor XtremeWingRC Aircraft - Electric - Power Systems (FS/W) 2 Feb 27, 2014 12:35 PM
Discussion Mini Sky Surfer V2 Motor Spec's VincentCar Banana Hobby 2 Jan 11, 2014 05:38 PM
Video Sky Surfer video of motor problem ariesmars Electric Plane Talk 0 Nov 26, 2006 04:49 PM
