Old Nov 27, 2013, 09:02 PM
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
Build Log
Fiat CR-32 from Manzano
So I'm starting my first build log of a Fiat CR-32 from Manzano and inspired by the build thread by Bill Bradley. http://www.rcgroups.com/forums/showthread.php?t=1326207
The kit included lots or laser cut parts and 4 pages of plans but minimal written instructions. If anyone has experience building this kit, their input would be much appreciated
David
dno264 is offline Find More Posts by dno264
Latest blog entry: Alfa Airacobra
Old Nov 27, 2013, 09:20 PM
Heads up...
RMCCOR7737's Avatar
United States, VA, Stafford
Joined Jun 2009
Sub'd.....
RMCCOR7737 is offline Find More Posts by RMCCOR7737
Old Nov 30, 2013, 01:21 AM
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
Some pictures of latest progress. If anyone has thoughts about the need for the battery tray in the fuselage (see last photo) please comment. I'm thinking it isn't necessary given the revised battery tray is located in combination with the motor mount.
David
Old Nov 30, 2013, 07:34 AM
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
Hey David,
Nice start on what looks like a nice kit.
Steve
Steve85 is offline Find More Posts by Steve85
Old Nov 30, 2013, 08:03 AM
Heads up...
RMCCOR7737's Avatar
Joined Jun 2009
David
Does the battery load from behind or is it permanently installed. It seem there would be a hatch at the point it shows the floor?
Edit: It looks like the cockpit is the hatch, The floor may be necessary to slide the battery to the front?
Old Nov 30, 2013, 11:18 AM
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
I think you are right about the battery floor being a continuation of the tray under the motor mount. On the other hand, if the battery is loaded through the cockpit hatch, that's a long distance to place the battery. Have to think this through before I seal up the fuselage.
David
Old Nov 30, 2013, 05:09 PM
B. Bradley's Avatar
Houston, Texas
Joined Sep 2007
Battery Floor
Dave, when you install the battery floor make sure the front edge is even with the engine mount floor. Only reason for this floor is to make the battery slide smooth to the full front position. It also stiffens the lower fuselage for that goofy landing gear spear.
Really looking good....
Bill B.
B. Bradley is offline Find More Posts by B. Bradley
Old Nov 30, 2013, 07:15 PM
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
Thanks for the clarification Bill. And, it's possible to slide the battery all the way to the front from the cockpit? Thanks.
David
Old Nov 30, 2013, 07:38 PM
Heads up...
RMCCOR7737's Avatar
Joined Jun 2009
Just saying.....
Old Nov 30, 2013, 09:34 PM
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
Originally Posted by RMCCOR7737 View Post
Just saying.....
Yup, my best friend is CA debonder
Old Nov 30, 2013, 09:35 PM
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
This website has some nice camo schemes for the CR-32.
http://www.silverwings.pl/edc_media/...instrukcja.pdf
Old Dec 01, 2013, 07:20 PM
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
I have finished adding the stringers and gear box/battery box to the fuselage. I'm still not certain about the how practical it will be to load the battery through the hatch. Will open up the front of the battery box to give me the option of loading the battery by removing the cowl.
David
Old Dec 01, 2013, 08:51 PM
Heads up...
RMCCOR7737's Avatar
Joined Jun 2009
David
I made a hatch right behind the cowl and load from the front. Different design though. Just a thought....
Edit: Looking at the girth of the tail of your model it may be necessary to have the battery forward the motor to avoid 4 oz. of lead in the front. Once I replaced the motor on mine from the 2228 to a 3010 I only needed 1.25 oz. of counter balance.
Old Dec 01, 2013, 10:58 PM
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
Wow, nice build. How big is that model? Who kitted it? The forward hatch makes sense. On my kit, the hatch would need to come from below, or taking off the cowl, or possibly the bottom half of the cowl.
David
Old Dec 02, 2013, 07:21 AM
Heads up...
RMCCOR7737's Avatar
Joined Jun 2009
David
Scratch built. Designed by Ruggero Pantini. Here is my build log...
http://www.rcgroups.com/forums/showthread.php?t=1830594
Contest Scratch Build Off 3 Fiat CR-32 ScottN3N Scale Kit/Scratch Built 43 May 12, 2011 11:04 PM
FIAT Cr-20, Cr-32, Cr-42 BaZsiX Scale Kit/Scratch Built 14 Jan 10, 2010 04:58 PM
Help! Fiat Cr-32 fudi50 Scale Kit/Scratch Built 10 Jul 17, 2008 02:42 AM
Idea Fiat CR 32 - Design W@CC0 Scale Kit/Scratch Built 31 Jun 09, 2008 05:37 AM
Discussion Fiat CR-32 fudi50 Scale Fuel Planes 0 Nov 22, 2007 01:04 AM
