Old Mar 16, 2013, 06:38 PM
Joined Mar 2011
Originally Posted by Pontius_Pilot View Post
Will I be in trouble?
Photofields should run adequately (not great) in either sim.
jeffpn is offline Find More Posts by jeffpn
Old Mar 16, 2013, 06:44 PM
Joined Mar 2013
Thanks for the reply. Adequately as in it'll still feel like a sim or will frame rate drop to the extent of rendering it useless? Um, question 2 I guess: is there a demo for Phoenix as well as Real Flight?
I suppose I should just use google. I have been all weekend (hence my arrival here)
Pontius_Pilot is offline Find More Posts by Pontius_Pilot
Old Mar 16, 2013, 06:46 PM
Joined Mar 2011
Busy little poster, aren't you? RF has an interactive demo. I think Phoenix's demo is more of an infomercial. I could be wrong.
Old Mar 16, 2013, 06:57 PM
Joined Mar 2013
Fair point. Not meaning to come across as spammy. Just got the excitement of new gadgets on my mind. I'm sure it'll wear off a bit like it did with all those other gadgets gathering dust around the place. Although more questions need to be asked regarding this sort of stuff than an iPad or Novation Impulse USB controller keyboard etc. I'll give the RF demo a whirl to test performance.
Old Mar 18, 2013, 11:17 PM
Clarkston, MI
Joined Apr 2005
Originally Posted by rwpeek View Post
I am considering buying Real Flight to use on my laptop. Although the laptop has ATI Radeon HD 6320/6290 graphics, so it should handle the video, it does not have a disk drive.
I can use an external disk drive to load the software, but am wondering if the disk needs to be inserted when running the simulator...if so, I would need to always have the external drive available and connected...
Just fyi, you can create an image of a disc and use a disc drive emulator to run a program that requires the disc to be inserted. I used to use alcohol 120% to run Battlefield 2142 years ago. It worked perfectly.
imjony5 is offline Find More Posts by imjony5
Old Mar 19, 2013, 05:13 AM
Joined Mar 2011
Did you read post #2? Or are you just big on emulators?
Old Mar 19, 2013, 12:43 PM
Clarkston, MI
Joined Apr 2005
I was informing him about an option that he was not aware of. There may be a situation in the future where an emulator saves him from carting an external disc drive around, yes i did read post 2. Are you trying to be helpful, or do you just like being snotty to people on the internet?
Old Mar 19, 2013, 12:49 PM
Joined Mar 2011
Real Flight DOES NOT REQUIRE the disc to be inserted in order to run the sim. Your information is irrelevant to his question.
Old Mar 19, 2013, 12:52 PM
Clarkston, MI
Joined Apr 2005
removed
Old Mar 19, 2013, 01:04 PM
Joined Mar 2011
As seen in my post where I answered his question, I am being helpful.
Old Mar 21, 2013, 10:12 AM
United States, MN
Joined Feb 2011
I do believe earlier versions, maybe 3.5 and earlier had SecuROM and required the disc so don't go buying a really old used version. The Interlink functions as the copy protection now, so going to guess the disc has not been required since G4.
grimbeaver is offline Find More Posts by grimbeaver
Old Mar 21, 2013, 10:46 AM
Joined Mar 2011
I think it was early versions of G2 that required the disc from time to time. G3 and up never did.
Discussion Does Real Flight 6.5 have any Quad Copters? phalcon51 Simulators 7 Mar 26, 2013 06:33 AM
Discussion Does Real Flight Have a Sailplane and Hi-Start Launch? rwpeek Simulators 12 Mar 21, 2013 10:50 PM
Sold Real Flight Plus controller and Real Flight 4 Program Plus Expansion Programs hadawayj Aircraft - General - Miscellaneous (FS/W) 2 Feb 16, 2013 04:34 PM
FS:EBAY Real Flight G2/G3 Flight Simulator Addon Disk 1, 3 & 4 Voyager Aircraft - Electric - Airplanes (FS/W) 0 May 17, 2005 07:58 PM
Does Interlink Interface work on old Real Flight Versions or FMS? duganderson Simulators 1 Dec 20, 2003 10:31 AM
