Old Feb 14, 2013, 10:31 PM
ggc
Joined Jan 2013
Elogger V4 on gas engine
Looking at moving an elogger V4 into a gas boat, will only be using GPS, Powerpanel and optical tacho at this stage.
Can I connect pretty much any battery pack over 6 volts to the battery leads of the elogger, and heatshrink and terminate the ESC leads so that they don't short against anything? Am I likely to run into any other problems?
ggc is offline Find More Posts by ggc
Old Feb 14, 2013, 11:59 PM
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I don't see any problems with that.
I have never tried to run the elogger as a stand alone unit, and I have never done any research on the functionality of the elogger as a standalone unit,
so I am not a wealth of resources in that aspect,
but I do not see any problems with the way that you want to power it.
m_beeson is offline Find More Posts by m_beeson
Old Feb 15, 2013, 12:02 AM
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
In fact, this would be worth looking in to;
I think you could log the throttle position and also the RPMs.
Like I said though, this is just preliminary thoughts, because I personally have never looked at the elogger as a standalone unit.
If I get a chance, I will look into it.
Old Feb 15, 2013, 02:12 AM
ggc
Joined Jan 2013
I'm surprised more people from outside the RC world haven't jumped onto some of the low-cost options from the world of RC electronics.
I doubt many people in the motorsport would know that you can get a 10Hz gps + logger + tacho + display+multiple sensors + telemetry and OSD for under $1000.
Now if the software had some laptiming options and maybe 0-100 and 1/4 timing options like Racechrono or Trackmaster, I think you'd have a very cost-effective package.
Old Feb 15, 2013, 06:57 AM
Saline, MI
Joined Jul 2006
I use several eloggers just like this. You can plug a standard receiver pack into one of the servo ports, but in your case I would plug it in to your existing reciver battery through the connectors normally used for the motor. That will let you monitor your receiver battery as well (always a good thing) and the receiver on/off switch will turn the logger on and off. The whole package you descried draws very little current.
dhares is offline Find More Posts by dhares
Discussion Elogger V4, driver install not successful on Window &7 kentli22 Eagle Tree Systems 5 May 30, 2014 07:28 AM
Sold Eagle Tree eLogger V4 rickfe101 Aircraft - General - Miscellaneous (FS/W) 0 Feb 12, 2013 12:04 PM
Sold Eagle Tree eLogger V4 rickfe101 Aircraft - General - Miscellaneous (FS/W) 0 Feb 12, 2013 11:48 AM
Discussion elogger v4 very hot on 12S Setup??? See Eagle Tree Systems 6 Nov 27, 2012 09:07 AM
Discussion Elogger V1/2 and V3/V4 on the same PC ? rojohn Eagle Tree Systems 1 Apr 28, 2011 06:23 AM
