Old Feb 03, 2013, 06:41 AM
Joined Feb 2013
Question
Understanding battery ...
Hi
Dont worry i will not ask you to explain all.
I have made my own researches on websites and forums
I gathered infos and I think I understood but I have some doubts
Can u confirm or correct the facts ?
Example : 3S 2100mAh 25C 2C
So what does this say ?:
1) How many amps maximum can be drawn : Amp*C*P
Amp = Capacity A (2,1A)
C = Discharge Rate (25)
P = number of parallele block ( 3S1P = 3S )
2.1*25*1 = 52.5 A
52.5 Amp maximum can be produced by the battery
Why is it useful?
We can check if the motors can be well supplied
ex : motor drawing 5A
For a quadricopter : 5*4 = 20 A
The battery can deliver 52.5 A, which is enough ( 52.5A > 20A)
2) The flying time when the battery discharges max
1 hour = 2.1A
we need 20A to supply 4 motors (5*4)
20/2.1 = 9.5 times more than the capacity per hour
meaning it consumes 9.5 times faster
60/(rmotors Amp / battery Ah) = 60/(20/2.1) = 6.30 min
the batttery will be empty after 6.30 min
is it correct ?? coz I have read another method which gives a different result
mAh : 2100 / 60 = 35mA per minute
35mA*C = 35*25 = 875
2100/875 = 2.4 min
the battery will be empty after 2.4 min
this is the original text :
"... a 20C rating on a 2000 mAh battery? 20 x 2000 = 40,000 milliamps or 40 amps. Time wise, a 40 amp draw on this pack would exhaust it in about 3 minutes (2000/60= 33.3 multiplied by 20c = 666 mAh per minute - divided into the packs capacity of 2000 mA = 3 minutes)
I understand that actually to calculate the flying time, it depends on Watts and weight , so it's more complicated ...
3) we have not to empty the battery at 100%, it would damage it
100% = 2100mAh , 80% = 1680mAh
Question bonus : if we have a battery : 3S2P 2100mAh 25C 2C
2P means parallele connexion = double capacity
so it means we multiplicate mAh by 2 ?? (4200mAh)
thanks for your help
toshfox is offline Find More Posts by toshfox
Old Feb 03, 2013, 06:52 AM
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
"52.5 Amp maximum can be produced by the battery "
The manufacturer/supplier claims that up to 52.5 amps can be delivered, not produced by the battery.
Manufacturer and supplier claims are not to be trusted.
25C is 2.4 minutes, which you figured out but simpler formula is 60 minutes / 25C = 2.4 minutes
Ken Myers is offline Find More Posts by Ken Myers
Old Feb 03, 2013, 07:10 AM
Joined Feb 2013
thanks Ken for you help
well, i am french, maybe i used the wrong english word
I understand what u mean.
About flight time, my method which for me was logic is not good then
it's the other formula that I have read which is the right one.
thanks
Old Feb 03, 2013, 08:05 AM
Staffs, UK
Joined Nov 2003
The first method you used for flight time is correct. When you say 20/2.1 is 9.5 times that's the same as saying the actual discharge rate you're using is 9.5C (not the full 25C that the battery COULD do).
The second one is working out the time if you discharge at the full 25C. If you notice, the real current you are using (20A) doesn't appear anywhere in the calculation which can't possibly make sense .
Steve
slipstick is offline Find More Posts by slipstick
Old Feb 03, 2013, 08:46 AM
Joined Feb 2013
Steve
Oh ok ! thanks
I guess it's not very smart actually to calculate with these formulas . As Ken said, if we can't trust the manufacturers about the discharge rate and that the autonomy of the drone depends how we use it
I have not a quadricopter yet, so i can't really realize with real experience
but it seems it's often less then 15 min
Discussion Understanding diffent 433mhz rx antennas heinduplessis FPV Talk 28 Feb 02, 2013 11:05 PM
Discussion Understanding RC LiPo cells bigheaded5 Batteries and Chargers 3 Jan 21, 2013 07:39 AM
Question Help understanding battery and battery teminology nickester Batteries and Chargers 1 Jan 20, 2009 08:34 AM
Understanding batteries ? Lammergier Batteries and Chargers 1 Oct 31, 2002 10:27 PM
Don't understand battery charging smithrl Electric Plane Talk 4 Aug 07, 2001 09:39 PM
