Old Apr 12, 2012, 05:11 PM
"Free" in Christ!
Free's Avatar
United States, CA, SF
Joined Jan 2012
Question
2 or 3 Blade Propellers?
Hi Guys,
I am wondering why everyone uses 2 blade propellers instead of 3 bladed on there F3P planes?
Wouldn't 3 blades lower amps and torque?
Free
Free is offline Find More Posts by Free
Old Apr 12, 2012, 06:16 PM
Senior to who? Member
crossup's Avatar
Annapolis, Maryland USA
Joined Feb 2001
Basic science: the most efficient prop has only one blade, therefore add blades wastes power.
2 blades is the engineering compromise to answer the dynamic balance issue. We see more than 3 blades to further address compromise, ie: 4 blades to allow the CV Corsair to have reasonable ground clearance without a long landing gear which would not hold up to carrier use. In multiengine planes more blades allow motors to be closer to fuselage and each other, reducing wing stress, and power out issues etc
Or in models, 3 blades in IMAC to limit prop noise.
So in F3P we go with the best 'available' efficiency since we dont need to compromise
much. Check out F1D to see single blade props in use
crossup is offline Find More Posts by crossup
Old Apr 12, 2012, 07:24 PM
"Free" in Christ!
Free's Avatar
Joined Jan 2012
Thank you Crossup,
Would a three blade prop reduce torque?
Free
P.S. If I use a 2 blade 8x4.3 prop, what would the three blade equivalent be?
Old Apr 13, 2012, 12:49 AM
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
That depends ...
Power is proportional to Torque x rpm. Using a less efficient prop, you would need to increase the power to achieve the same thrust.
This can either be achieved by an increase in torque, rpm or a bit of both.
This is also independent of the type of prop (2-, 3-, 4-blade) . You can achieve a certain amount of thrust bei either running a big prop at low rpm (high torque) or a smaller prop at higher rpm (low torque). A bigger prop is more efficient and it also helps to slow down the model in those vertical down figures.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Apr 13, 2012, 09:38 AM
"Free" in Christ!
Free's Avatar
Joined Jan 2012
Thank you Crossup and Jurgen,
Now I understand why people use 2 blade props!
Free
Found CF 2 blade 28-10 or 3 blade 27-10 or 12 rjstrickjr Aircraft - Fuel - Engines and Accessories (FS/W) 1 Apr 18, 2012 11:41 AM
Discussion Dumas Lil Swamp Buggy -2 or 3 blade prop? stanb112 Dock Talk 3 Mar 30, 2012 02:07 PM
Discussion Propellers: 2-Bladed vs 3-Bladed IvanoAV Multirotor Talk 5 Nov 11, 2011 06:51 AM
Wanted Spinner 3.25 inch, 84 mm 2 blade or 3 blade WesternFlyer Aircraft - Electric - Power Systems (FS/W) 0 May 07, 2011 11:04 PM
Discussion 2 blade, 3 blade, or 4 blade prop whats the difference? Ketsueki Beginner Training Area (Aircraft-Electric) 2 Jan 17, 2008 02:43 PM
