Old Apr 03, 2012, 07:05 PM
United States, WI, Hayward
Joined Oct 2011
AXN Pusher Jet Plans
Was hoping to find some plans similar the HK's AXN Floater-Jet. Ran a search with out any success. Does anybody have any ideas, or has seen anything similar?
Thanks in advance.
Bent Props is offline Find More Posts by Bent Props
Old Apr 03, 2012, 08:43 PM
Crash Test Engineer
United States, MN, Maple Grove
Joined Nov 2011
Check this out. The Axon (one of the more recent in his series of videos) is a pusher style, larger wing span (60"). Although not exactly like the AXN, it's a start...
http://www.rcgroups.com/forums/showthread.php?t=1587275
RC Dad
RC Dad is online now Find More Posts by RC Dad
Old Apr 04, 2012, 10:19 AM
Power-line attraction pilot
United States, MA, Natick
Joined Jun 2011
Are there any monoblock-type fuselage pusher plane plans to build out of polystyrene insulation foam (the blue kind from lowes)?
its only 12-14 bucks for a 4' by 8' sheet at 1/2" thick. I was thinking of layering the cut outs from the sheet to make my fuselage. i plan to build a plane slightly larger than the XEN Skywalker (bigger fuselage and 2m wingspan), and will FPV with it.
any pointers are much appreciated. this will by my first foam build.
caall99 is offline Find More Posts by caall99
Old Apr 04, 2012, 12:19 PM
Psalms 23:4
Goshen, IN, USA
Joined Nov 2010
Check out the Nova at MyGeekShow.com. He has a complete construction guide, and plans, as well as several videos showing construction and setup. It's close to your 2m wingspan as well. He uses 3/4" foam instead of 1/2", but I'm sure you could adapt the plans to 1/2"if you need to.
http://www.mygeekshow.com/theairplanes
miniprinter96 is offline Find More Posts by miniprinter96
Old Apr 04, 2012, 12:20 PM
Joined Jun 2011
Awesome! this is great! Thank you!
Old Apr 17, 2012, 06:35 PM
Joined Jun 2011
Are there any other pusher style plans i should look into. I am also interested in twin boom configurations
Old Apr 18, 2012, 01:34 AM
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Check the bottom of the page, "Similar Threads"
Redi-Jet pusher
Shuttle-jet pusher
Plan Suggestions -jet style pusher
rick.benjamin is offline Find More Posts by rick.benjamin
Build Log Redi-Jet pusher with plans! billwhit Foamies (Scratchbuilt) 72 Jan 16, 2013 12:29 AM
Discussion AXN floater jet jamiek123 Beginner Training Area (Aircraft-Electric) 4 May 13, 2012 07:10 PM
Build Log Shuttle-Jet pusher with plans - Maiden Video Added! billwhit Foamies (Scratchbuilt) 20 Nov 24, 2011 11:56 AM
Discussion Plan Suggestions for Airplane - Jet Style Pusher Prop highamperage Electric Plane Talk 2 Nov 15, 2011 11:29 AM
