Old Feb 23, 2012, 07:31 AM
Joined Dec 2011
Walkera V400D02 Help
I recently purchased the V400D02, and already had a Devo-8 transmitter, I was curious if when I turn on the heli and then the transmitter for the main blades rotate on an angle? I think the go bade to a horizontal orientation once the blades start to rotate, but didn't know if I need to adjust the rods manually or if there was a way of doing this on the transmitter? Thanks for any help.
MarathonRock is offline Find More Posts by MarathonRock
Old Mar 01, 2012, 03:07 PM
Tom
United States, AZ, Tucson
Joined Dec 2011
Mine do. They pitch into the L setting for my pitch curve (about -2 degrees) that I've programmed into the transmitter. The pitch of the blades will change as you give it throttle/collective with the throttle stick and there should be some correlation between your throttle and pitch curves (in normal flight). You use the mechanical adjustments to work out any change in pitch and blade height between the two. Programming the pitch curve in your transmitter is what gets you up in the air but won't correct any mechanical (setup) issues for you.
tom4416 is offline Find More Posts by tom4416
Discussion Need some help. Walkera V400D02 won't take off. bigo66 3D Electric Heli Flying 23 Mar 20, 2012 09:37 AM
Help! Is the Walkera v400d02 OK for a novice/intermediate FishFingerDigits Electric Heli Talk 6 Oct 23, 2011 06:06 PM
Discussion Need help replacing walkera v400d02 servos! bigo66 Beginner Training Area (Heli-Electric) 2 Mar 17, 2011 07:09 AM
Sold Brand New Walkera V400D02 RTF W\ aluminum case AND additional V400D02 (not flyable) Conner Dain Aircraft - Electric - Helis (FS/W) 0 Jan 17, 2011 11:16 AM
Question Transport devices for 2x Walkera V400D02 & 2x Walkera V200D02 JumboA5 Electric Heli Talk 2 Dec 13, 2010 08:22 AM
