Old Oct 08, 2003, 03:01 AM
KenKnapp@webtv.net
Guest
n/a Posts
Wood Glue or CA...
I find I get a better blond with wood glue that CA...Stronger and easier
sanding...the only thing CA has got going for it is speed, even though I
have to wait over night for drying with the wood glue. Definately a
better plywood bond. In put please, thanx, ken
S. Boucher
Guest
n/a Posts
Re: Wood Glue or CA...
If wood glue will get me a better "blond" (blonde) then I'm all for it. ;-)
Anthony R
Guest
n/a Posts
Whatever works. Some people swear by alphatic as opposed to CA. Apparently
you can build lighter with it.
For me, CA has always worked fine and I'm not allergic to it...yet. If you
do get allergic there is always odor free CA, which is more expensive.
<KenKnapp@webtv.net> wrote in message
news:13795-3F836F93-40@storefull-2235.public.lawson.webtv.net...
Old Oct 10, 2003, 03:00 AM
The Natural Philosopher
Guest
n/a Posts
Never heard that glue was a babe magnet...you live and learn...
careful, you might get 'stuck' with her
Dr1Driver
Guest
n/a Posts
>Stronger and easier
>sanding.
Easier to sand - yes. Stronger - no. Check the specs. If your joint is
mechanically sound (no gaps, tight fit, etc.) then CA will be MUCH stronger
than any wood glue available to us commercially. Use thin CA for balsa, and
thick for plywood or hardwood.
Dr.1 Driver
"There's a Hun in the sun!"
MJC
Guest
n/a Posts
I'd argue the point that aliphatic builds lighter than CA, however, the
difference makes no difference.
At the same time, I agree that CA is stronger than aliphatic (IF the joint
is fit super tight with no gaps. If it's not a nicely fit joint, aliphatic
will be stronger). But just like with the weight difference, the strength of
a joint as opposed to aliphatic is irrelevant because it both cases, the
final strength is more than any design calls for. For example, if one glue
joint will withstand 300 pounds of stress and the other will withstand 250
pounds of stress, what does it matter if the applied stress is only going to
be 50 pounds?
MJC
"Anthony R" <junk999{nospam}@shaw.ca> wrote in message
news:LmMgb.43787$9l5.12382@pd7tw2no...
Apparently
you
Paul McIntosh
Guest
n/a Posts
It is a rather moot point since virtually all glues are much stronger than
balsa!
Paul McIntosh
Desert Sky Model Aviation
http://fly.mcintoshcentral.com
"Dr1Driver" <dr1driver@aol.com> wrote in message
news:20031008070424.29032.00000423@mb-m06.aol.com...
> >Stronger and easier
> >sanding.
stronger
and
> Dr.1 Driver
Pé Reivers
Guest
n/a Posts
In a wood bond with aliphatic glue, the wood will fail before the bond line
does.
It seems to me that this question of strength is purely academic, and leads
nowhere.
The only advantage I see is that CA can <harden> soft balsa, and will stand
up against aging much better.
However, the thus hardened wood will be brittle, and break next to the join,
so strengthwise there is nothing gained, wood being the limiting factor.
Rgds,
From Arcen, South-East in the Netherlands
preivers
mvvs-nl.com
http://mvvs-nl.com/
www.prme.nl
> >Stronger and easier
> >sanding.
stronger
and
> Dr.1 Driver
John R. Agnew
Guest
n/a Posts
dr1driver@aol.com (Dr1Driver) wrote in message news:<20031008070424.29032.00000423@mb-m06.aol.com>...
> >Stronger and easier
> >sanding.
> Dr.1 Driver
I use a lot of aliphatic resin because it's cheap and easy to work
with. Properly applied (good fit, clamped, etc.) all of the adhesives
we use result in a bond that's stronger than the wood, anyway, so use
what you like.
MJC
Guest
n/a Posts
With the notable exception of glue gun adhesive.
MJC
> what you like.
Paul McIntosh
Guest
n/a Posts
Even glue gun adhesive, IF USED PROPERLY, will be stronger than needed.
Problem is, people use it improperly and then complain about it.
Paul McIntosh
"MJC" <nospam@noway.com> wrote in message
news:bm1rq6$khb@library1.airnews.net...
> MJC
> > what you like.
Morgans
Guest
n/a Posts
"Paul McIntosh" <paul@mcintoshcentral.com> wrote in message
news:bm22r7$2m3$1@sparta.btinternet.com...
> Paul McIntosh
What would the proper way to use it? It has been unsuitable for me.
Jim in NC
Fred McClellan
Guest
n/a Posts
On Wed, 08 Oct 2003 04:27:23 GMT, "Anthony R"
Take it from someone who managed to develop a severe allergy to the
original variety,"odor free CA" is oxymoronic with respect to allergic
reactions.
Cheers,
Fred McClellan
the dash plumber at mindspring dot com
Fred McClellan
Guest
n/a Posts
>be 50 pounds?
Or, what does it matter if the wood on either side of the joint fails
before the joint itself ?
Cheers,
Fred McClellan
Fred McClellan
Guest
n/a Posts
On Wed, 8 Oct 2003 20:24:38 -0400, "Morgans"
>> Paul McIntosh
There is no proper way to use the old types of hot melt glue; just
won't work.
According to the heavy hitters in the woodworking list, there are
some new types of 'hot melt glue' on the market, purportedly very much
better than the garden variety rubbery stuff.
Haven't tried them myself, mind you. A bit pricey for the hobby
budget right now.
Cheers,
Fred McClellan
Discussion Using wood glue over CA? Tram Electric Plane Talk 15 Jun 16, 2007 08:44 PM
Gorilla Glue, or CA? Nethole Beginner Training Area (Aircraft-Electric) 8 Feb 03, 2006 09:04 AM
white wood glue or epoxy resin??? Masterpiece Composites Fabrication 2 Sep 14, 2005 08:24 AM
Discussion Wood Glue vs. CA Arrow The Builders Workshop 3 Jun 03, 2003 11:48 PM
Discussion Wood Glue -vs- CA Arrow Scale Kit/Scratch Built 13 May 22, 2003 04:47 PM
