Old Nov 15, 2011, 03:45 AM
Christchurch, New Zealand.
Joined May 2003
Question
Eflite 90-120 retract motor replacement.
I have a mildly used set of Eflite 90-120 sized retracts. While bench testing for install into a new model one of the retracts failed mid cycle and investigation revealed a piece of alloy swarf inside the motor had damaged the brushes and windings.
I would like to try and replace the motor which is easily removed from the housing and gearbox.
Anyone done this before? If so, were you able to source a replacement motor you could buy in a moderate quantity...say 5?
maXzim is offline Find More Posts by maXzim
Old May 20, 2013, 04:16 PM
Joined Aug 2012
I also do like to know if it is possible to replace only the electric motor of my 25-46 retract from e-flite.
Does anyone have ever tried this?
Guijs is offline Find More Posts by Guijs
Discussion Eflite NG retract Trunion Block Replacement LJE4357 Scale Kit/Scratch Built 4 Sep 05, 2011 01:00 AM
Discussion Is it possible to get a replacement retract? fenderbean Banana Hobby 2 Mar 15, 2011 08:08 PM
For Sale eflite 90-120 size nose e retract warbird_cowboy Aircraft - General - Miscellaneous (FS/W) 0 Feb 25, 2011 01:42 PM
Discussion Eflite NG retract Trunion Block Replacement LJE4357 Electric Ducted Fan Jet Talk 1 Nov 16, 2010 09:08 AM
Discussion Eflite NG retract Trunion Block Replacement LJE4357 Scale Kit/Scratch Built 0 Nov 16, 2010 08:57 AM
