View Poll Results: When the frontend of your plane lifts during a Dive Test it means;
Your plane is Nose Heavy 49 96.08%
Your plane is Tail Heavy 2 3.92%
Voters: 51. You may not vote on this poll
Old Apr 16, 2014, 09:51 PM
chip.greely's Avatar
Carlsbad, Ca
Joined Mar 2007
Poll
The Dive Test
Back in the day when trimming out your new prize sailplane included collecting data for fine tuning your CG location, from your successful madien flight we all used the Dive Test.
The Dive Test was simply pointing your plane into a 45 degree dive (preferrably from altitude) and noting whether or not the frontend lifts or continues the 45 degree dive.
The problem seems to be that different people recall the meaning of a frontend, differently. I had learned that a lifting frontend meant you were Nose Heavy.
What do you recall?
Nose Heavy
Tail Heavy
Enjoy
chip.greely is offline Find More Posts by chip.greely
Old Apr 16, 2014, 09:58 PM
Just Toss It !!!
MATIN's Avatar
United States, CA, San Diego
Joined May 2004
Nose heavy.
MATIN is online now Find More Posts by MATIN
Old Apr 16, 2014, 10:01 PM
Feeling FrSky
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
From a 45* downline flown hands-off where the glider is allowed to gain significant speed, if the glider:
- Pulls Up... it's noseheavy and/or has too much positive decalage
- Stays on the line... it's neutral and probably 0/0 decalage (best decalage for slope use)
- Tucks (steepens dive)... it's tailheavy and/or has negative decalage
A plane can be just aft of neutral and not tuck, which is why it's important to follow up a 45* downline test with a level inverted flight test.
From level inverted flight at cruise speed, if the glider:
- Requires forward ("down") stick to maintain level flight, it's noseheavy
- Flies hands-off inverted, it's probably neutral
- Climbs when inverted, it's probably tailheavy
Plank flying wings like the Moth or Weasel will also show a noseheavy condition when you roll them. Because of the extra "up" trim they've got (due to noseheaviness) they will tend to barrel roll instead of axial roll. Once the CG is moved back the roll will get nice and axial.
With a new plane, it's always best to remember the old saying:
"Noseheavy flies poorly, tailheavy flies once"
For aerobatics you want a neutral plane. It should go where you point it, and not anywhere else. I assume this is the case with most other types of high performance flying.
Steve
surfimp is offline Find More Posts by surfimp
Old Apr 16, 2014, 10:04 PM
cityevader's Avatar
United States, CA, San Jose
Joined Mar 2012
^ Bam!
'nuff said!
Unless it's my Interceptor...then an inch fore or aft doesn't even matter.
cityevader is online now Find More Posts by cityevader
Old Apr 16, 2014, 10:06 PM
United States, CA, Carlsbad
Joined Nov 2007
I'd say the dive test is irrelevant in determining CG if you have a symmetrical airfoil and the plane is trimmed neutrally
JGAF is offline Find More Posts by JGAF
Old Apr 16, 2014, 10:14 PM
Feeling FrSky
surfimp's Avatar
Joined Feb 2003
Right, because if the balance is off, you won't be able to do level flight without adjusting the trim away from neutral
I'm sure pitching moments of the airfoil used come into play in determine exactly where the best CG position is, and a lot of other things.
I still use the dive test when dialing in aerobatics planes but mainly focus on the difference between upright and inverted flight. When there is no difference, then the plane is balanced properly
Old Apr 16, 2014, 10:21 PM
Carlsbad, Ca
Joined Mar 2007
It appears I failed to successfully post my Poll
Old Apr 16, 2014, 10:22 PM
Joined Nov 2007
oh shucks
Old Apr 16, 2014, 10:45 PM
Carlsbad, Ca
Joined Mar 2007
Chad,
I think you've got something else going on with that Interceptor,.....maybe an incedence misalignment between the wing and stab, or some artifact of the airfoil used on the recut wing.
That little bird originaly was a Bat-outta-Hell
Old Apr 16, 2014, 11:06 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Some people still get this backwards and will defend their opinion violently, albeit still wrongly.
The thing to remember is that the aircraft is supported by the lift generated by the main
wing, at roughly the center of pressure (aka "center of lift"). Any non-symmetrical airfoil
will generate a forward pitching moment which pulls the nose down plus nose
weight, which also pulls the nose down. To counter that, you have a horizontal stab,
and elevator surface that generates negative lift which pulls the tail down. When a
plane is "nose heavy" it means you have more weight pulling the nose down, and the
only way to counter it is with more up trim, and thus more negative lift from the
horizontal stab.
The basis of the dive test is simple. The weight pulling the nose down is static,
but as you increase air speed, the negative lift generated by the horizontal stab and
static up elevator trim increases, which causes the force pulling the tail down to increase, and
the nose to pitch up. If you remove some of the nose weight, then less static up elevator
trim is required to balance the nose (you must re-trim for the new CG), and it flies neutral.
Remove even more, and now the CG ends up at or behind the center of lift,either the
forward pitching moment of the airfoil dominates, or it actually requires down trim to
hold the tail up. Again, as you increase airspeed, the pitching moment and/or positive lift
of the tail increases, causing the nose to pitch down.
One more thing that confuses folks is the difference between Center of Pressure and
Mean Aerodynamic Center (MAC) which is usually in front of the center of pressure.
People often balance their planes at the MAC but for slope planes that usually results
in a plane that feels nose heavy. If you want maximum efficiency, you'll likely find
yourself moving the CG well back from the MAC, closer to the Center of Pressure, but
may find that the plane becomes more neutral at the top end of its speed range.
Daemon is offline Find More Posts by Daemon
Old Apr 16, 2014, 11:18 PM
Just Toss It !!!
MATIN's Avatar
Joined May 2004
^^^ Very concise explanation ^^^
Old Apr 16, 2014, 11:32 PM
Feeling FrSky
surfimp's Avatar
Joined Feb 2003
Old Apr 16, 2014, 11:40 PM
cityevader's Avatar
Joined Mar 2012
I should have clarified my own personal stance...I only start with a dive test, and probably 90% of my testing is inverted flight...except for my Passer.
And Chip, you are right...it's darn hard to trim a plane when one has no idea if the trailing edge is up/down/neutral without any sort of reference point other than "that seems close"...especially with it's particular planform.
My Interceptor isn't fully symmetrical either. Dunno if it's supposed to be. Wing was cut by prior owner 20+ years ago...so he said. He does lots of cutting/bagging, etc.
Old Apr 16, 2014, 11:45 PM
slopemeno's Avatar
Joined Jan 2003
Second the level inverted flight test.
slopemeno is offline Find More Posts by slopemeno
Old Apr 16, 2014, 11:46 PM
cityevader's Avatar
Joined Mar 2012
Another thing i've found is that cg is very personal preference-based.
I got my Spider60 from Lars...he likes nose heavy. I moved cg from 55mm to 80 and now it's almost perfect! BUT!!! If I were specifically doing higher altitude thermaling, I'd certainly, definitely want more nose heavy, as it can be hard to tell if the plane is pitching one way or the other until the speed becomes significantly faster/slower...and that porpoising that I HATE on the slopes becomes a valuable tool at altitude.
Just my .02
CG Dive test Magna High Performance 4 Oct 26, 2004 01:03 AM
CG Dive test Stuey Sport Planes 5 May 30, 2004 11:44 AM
Dive testing CG on flying wing? DeuceTrinal Foamies (Kits) 1 Oct 17, 2003 03:52 PM
"the dive test" tic Electric Sailplanes 24 Feb 11, 2002 11:51 AM
dive test confusion maciek Electric Sailplanes 29 Jul 07, 2001 12:33 AM
