Old Apr 11, 2013, 03:27 AM
marek rokowski's Avatar
Poland
Joined Aug 2009
Build Log
Pfalz D XII
hi to all
I present you my new kit
1 version with Polish cammuflage
second with German camuflage
I made SEVERAL picture speaks more than words
mounting fusselage:
I have cutt a small piece of epp in the front, in part after the "cooler"
to strengthen fusselage I glue the grid plate (glass ribbon) which can buy in DIY store (for reliecolle plasterboard)
I also strengthen the cover (next to the motor)
to paste coverage should put temporarily fill the gap of the horizontal stabilizer
I glue coverage with UHU Por
well can finish a crevasse with CA. I use etui for documents to push crrevasse , because the CA cannot glue with this
I shoot with the tweezers the temporary element and cut the crevasse for stabiliser
I cut a stabilizers (the hinges are already cut with CNC)
I renforce element with carbon:
in may finisser flat wings&stabilisers surfaces:
pour glue:
glue CA et spray-accélérateur
important: max 2-3 cm for one time!
I cut with knife remnants of glue
to be continued...
Marek
www.napolskimniebie.pl
marek rokowski is offline Find More Posts by marek rokowski
Old Apr 12, 2013, 07:43 AM
Flying Low
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
Looks cool.
cbarnes0061 is offline Find More Posts by cbarnes0061
Old Apr 13, 2013, 11:47 AM
This is kid stuff.
Mazzepa1's Avatar
USA, AR, Harrison
Joined Aug 2010
Some of these teshniques used for EPP construction are new to me. In particular the fuselage structure and "skinning". Also removal of material from the interior of the control surface perimeter, then gluing the remainng external material together to shape the edge. Quite clever in concept and skilfully executed.
I'm sure you get many requests to do this or that model, but I cannot resist making one, for the Bristol M1c, the Gina Lollabrigida of WWI planes. Perhaps lengthen the nose a bit, maybe lengthen the ailerons some.
Were kits to become available to be constructed as the Pfalz DXII, or as your PZL P11c, I would order two immediately.
Mazzepa1 is online now Find More Posts by Mazzepa1
Old Apr 18, 2013, 04:29 PM
Poland
Joined Aug 2009
reinforce the wings
i made place for servos
montage of small elements:
first assemblage
i glue the struts
for top wings i used stencil(?)
chassis:
ici en vais coller l'element du plastic pour renforcer ca
montage off equipement:
ESC i placed vertically behind the radiator
ufff...
t.b.continued
Marek
PS Bristol M1c - ... ok no problem i think i can cut this kit in Monday...
Old Apr 18, 2013, 05:28 PM
This is kid stuff.
Mazzepa1's Avatar
USA, AR, Harrison
Joined Aug 2010
Wow
You're blowing me away w/this thing. I have questions and comments.
1. Struts are made of CF strip?
2. Very clever means of attaching struts to wing. Pointed ends that just stab into the EPP, easy to make small adjustments to align wings.
3. Does the foam wing alignment template (stencil) come with the kit?
4. Using a paper template to locate the cabane struts then cutting the template free should be effective.
5. How in the heck did you paint the lozenge camouflage?
6. I very much like the idea of a tube through the fuselage to support the landing gear.
On to the Bristol.
1. Are we talking ESA specification?
2. I much prefer the P11c style 2-piece, hollow fuselage.
3. Seems as though the nose would need to be extended (15mm or so?)
4. Do you think the ailerons should be lengthened a bit?
This conversation can be continued by e-mail if you wish. I don't want to detract from your Pflaz build log with my pet project.
Old Apr 18, 2013, 06:00 PM
Poland
Joined Aug 2009
Hi Mazzepa1
ad1) Struts are made of CF strip (4x1mm)
ad3) stencil come with the kit
ad5) its my secret hehe - UV printer with flatbed
Bristol:
yes, similar to P11 with fuselage like "O" -look my last project: I 16 Rata
the nose would need to be extended (minimum 20-max 30mm)
best regards
Marek
Old Apr 18, 2013, 06:20 PM
This is kid stuff.
Mazzepa1's Avatar
USA, AR, Harrison
Joined Aug 2010
Originally Posted by marek rokowski View Post
Hi Mazzepa1
Bristol:
best regards
Marek
ad5) Ahh, printed directly on to the EPP, hence the need to remove material from the inside and fold over the external (printed) material. In order to extend the camouflage across the rounded edge. Excellent.
Bristol M1c - I looked over the Rata build log photos a few days ago, I think that method should work splendidly for the Bristol. Amazes me that you could develop and cut a kit so quickly. While I'm excited at the prospect of this endeavor, please don't rush. I will gladly wait for you to take the time necessary to do it up right.
If the cost per kit is close to that of the P11c, please provide quote for 2 kits shipped by post here, PM or e-mail as you prefer.
Old Apr 23, 2013, 04:54 AM
Poland
Joined Aug 2009
yes, the price is similar/some
you can make preorder by e-mail
ps. in saturday i go to Palu for looking planes.. hmmm.. wreck planes underwater
i come back in two weeks
after we can make this kit with calmness
best regards
Marek
Old Apr 23, 2013, 11:39 AM
This is kid stuff.
Mazzepa1's Avatar
USA, AR, Harrison
Joined Aug 2010
best regards
Marek
Sounds like a great trip you have planned. I hope you have a good time. That sure is a lo-o-ong flight isn't it?
I'll check back in a couple of weeks.
Old Nov 10, 2013, 11:36 PM
Poland
Joined Aug 2009
uff!
finally i made short film with my Pfalz...
pfalz d 13 (1 min 57 sec)
best regards
Marek
Build Log Aerodrome R/C Pfalz D.VII/D.VIII vonJaerschky Scale Kit/Scratch Built 149 Dec 10, 2010 07:20 PM
Manual for Simprop Pfalz D III kchamp33 Electric Plane Talk 3 May 19, 2010 02:52 AM
Free XII of XII and that is just it. No $'s what so ever plus Odd yet nice 13th later jcstalls Non R/C Items (FS/W) 58 Jan 08, 2009 05:55 PM
Discussion Pfalzing Matilda, Pfalzing with you! Pat Daily Electric Plane Talk 0 Jul 10, 2006 12:02 PM
