Old Feb 01, 2012, 06:03 AM
Joined May 2010
Question about motor 450 heli size
I had searched but nothing that solve my question, i would like to know if i can build a outriiger, like 40 cm and put on it a turnigy typhoon of a 450 heli size, thank you...
axskin is offline Find More Posts by axskin
Old Feb 01, 2012, 06:24 AM
Australia, VIC, Blackburn North
Joined Feb 2011
Motor specs?
ESC?
Batteries/Voltage?
Something water cooled would be better or a water cooled mount perhaps?
mozzyrocks is offline Find More Posts by mozzyrocks
Old Feb 01, 2012, 06:29 AM
Joined May 2010
http://www.hobbyking.com/hobbyking/s...idProduct=9021
Specifications:
Dimension: 35mm x 28mm, 51mm(with shaft)
Weight: 63g (kv3550) (not including connectors)
Voltage: 2-4S
Max current: 20~28A
Diameter of shaft:3.17mm
Length of front shaft:16mm
ESC: 40A
I would use a ESC with 50A, batteries some 3s 2200 ...i don't want it to run very fast and go around limits, only for fun in a lake..
Really i had this electronics in a box, and i would like to build a boat from the plan, in balsa wood.
Old Feb 01, 2012, 06:40 AM
Joined Feb 2011
Hahahaaa, for fun alright! :-D That motor will be revving hard on 3S.
Small prop?
I'd run one of these & run a large prop.
http://www.hobbyking.com/hobbyking/s...er_2500KV.html
Old Feb 01, 2012, 06:49 AM
Joined May 2010
I don't know anything about boats, i am a quadcopter builder , what you think? what plan is good for a begginer? should i use a 2s ? or i can't use this motor? what size of prop you consider?
Old Feb 01, 2012, 07:41 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
The kv is a bit high for running on 3s. It would put no load prop speed around 41k. 2s would get you down into the 29k no load range.
It would need to be a small prop, probably 36-38 mm range.
bill34207 is online now Find More Posts by bill34207
Old Feb 01, 2012, 08:03 AM
Joined May 2010
OK, very thanks for your help, i could run it on 2s, i had another question, the motor shaft is 3.17mm diameter, what i need to adapt it to a flex shaft or so, can anyone help me on hardware setup for this? i am client from hobbyking, if anyone can help what i have to bought to start up, i know the rudder, the servo, but i am little confused about the shaft and its acessories,...
Old Feb 01, 2012, 08:38 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
OSE has quite a few couplers listed depending on your chosen cable size. They don't really show one for 3.17 mm but think that the 1/8" listed there would most likely work if you do the metric to SAE conversion.
http://www.offshoreelectrics.com/pro...Motor+Couplers
You can find most of the other items you'll be wanting there too if you browse the site.
Old Feb 01, 2012, 08:52 AM
Joined May 2010
I prefer to do orders at hobbyking, $20 of shipping is to must for my needs, and material in this site looks like a little expensive, i want only the basic to have a little fun..
Old Feb 02, 2012, 12:38 PM
Joined Dec 2011
I am currently building a Mini outrigger that is 17 inches long..Here is the motor Im using on 3s..Rpm will be 38850 and is a proven setup..Its between a 450 and 500 size..http://www.hobbyking.com/hobbyking/s...er_3500KV.html
Pair it with a good 55a esc and youll be good..I will be using a octura x430 on 3s..It will fly..
Also..Be sure to use the highest C rating you can get..Especially on 2s..Thats another reason I want to run 3s with a smaller prop..40c 2s pack would have 80 amps on tap where as a 3s 40c pack will have 120amps on tap..
pyroMIKE is offline Find More Posts by pyroMIKE
Old Feb 02, 2012, 03:32 PM
Joined Dec 2011
Heres one on 3s 3800kv..But Im gonna use a 3500kv..
JAE Zippkits Mini Sprint Fast Electric Hydro (0 min 51 sec)
Old Feb 13, 2012, 04:42 AM
Joined May 2010
can i use this shaft and sleeve?
http://www.hobbyking.com/hobbyking/s...set%5F4mm.html
rigid sleeve and shaft? on an outrigger?
Discussion What size motor for 450 Heli old4570 Beginner Training Area (Heli-Electric) 4 Dec 31, 2011 12:41 PM
Question 450 heli motor/pinion/weight question. js32257 Mini Helis 5 Dec 28, 2011 01:47 PM
Sold WALKERA 450 size electric heli (450 size) $50.00 shipped. crosby Aircraft - Electric - Helis (FS/W) 4 Nov 15, 2011 06:14 PM
Sold 450 Size Heli - Frame w/ Brushless Motor hochoco Aircraft - Electric - Helis (FS/W) 1 Oct 01, 2011 04:59 PM
Sold Turnigy 2836 Brushless 450-Size Heli Motor 3700kv snoshoe62 Aircraft - Electric - Power Systems (FS/W) 5 Sep 24, 2011 07:27 PM
