Old Apr 24, 2010, 11:10 AM
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
A4 64mm EDF at Nitroplanes
I just got in an A4 64mm EDF from Nitroplanes.
A4 Review Info and links
OMG! was this an easy build.
It came with EVERYTHING needed. Servos are pre mounted and glued in. Wires are run and the landing main langing gear has a snap in cover. The nose wheel needs a grub screw (1.5mm hex) and it came with the too. I elected to pull the nosegear off totally cause I'm hand launching at a grass field. The Epoxy in the instructions said 5-10 minute drying time but the working time is like 3-5 minutes. So you have to use like a dollar coin size amount for each wing. Pour and mix more than you think you will need cause you may not have time to go back and mix more. They give you twice the amount of epoxy you need. I did the wings seperatly so I could cover it with a thin coat then hold the wing together for a few minutes till it set up. You only have one chance so you better trial fit everything. I taped the elevator servo junction before putting the vertical stab in. You can 't get to that junction once the vertical stab goes in. Only thing I did extra was to put some foam around the Rx to hold it snug and foam the back of the battery to keep it forward. I'm gonna need a little bit of nose weight cause without the landing gear it's about 4-8mm tail heavy from the CG they give you in the instructions. I poked a hole and ran the antenna out the top. The nose cone is plastic instead of foam so I like that it will flex insted of dent. I had to hold the nose cone on by hand the entire set time of the epoxy. When gluing the horizonatal stab, it was easier to put the thin coat on the inside of the vertical stab then slide the horizontal stab in and hold it a couple minutes till it set up.
Total build time was only an hour. There is no wall wart power supply for the charger, just alligator clips to a 12V sourse. No worries cause I have a computer charger. IT has the 4mm bananna connectors on the esc and battery like the BlueLipos or Turnigy batteries. I'll replace with deans or just make an adaptor cause I have lots of other 1300mAh batteries.
Rx battery connector is the same type and polarity of JR/Spektrum so I used my spare DX7 battery to power it.
No flight yet, but I'll post video of that when I get to it.
Melnic is offline Find More Posts by Melnic
Old Apr 24, 2010, 11:11 AM
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Pictures
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Video comming
Old Apr 24, 2010, 12:27 PM
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
This will get moved to "foamies". Betcha! Got to love the A-4!
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Apr 24, 2010, 12:45 PM
FlyBoyTha1's Avatar
The Greater Bay Area
Joined Sep 2008
Nitro Planes 64MM A-4 SkyHawk "High Wind Flight"
But Can You Fly It Like This In The High Winds J.K.
Check Out The Video
Nitro Planes 64MM A-4 SkyHawk "High Wind Flight" (6 min 9 sec)
FlyBoyTha1 is offline Find More Posts by FlyBoyTha1
Old Apr 25, 2010, 08:43 AM
tungym's Avatar
Planet Earth
Joined Jul 2005
This A4 is not small and 64mm EDF does not provide sufficient speed for this beautiful bird. Some buddy in my field then modifies it to 70mm EDF with doubling the power system. Then it flies over 180kph . The exit nozzle is 55mm, which is a dart throw for a high power 70m EDF.
tungym is offline Find More Posts by tungym
Old Apr 25, 2010, 08:52 AM
Were..is..my..Super..Suit ..
j3tman's Avatar
United States, NE, Papillion
Joined Sep 2009
have you done any mods or going to do any mods after the maiden?
j3tman is offline Find More Posts by j3tman
Old Apr 25, 2010, 11:49 AM
wine country wing nut
BlueSkyRiderX's Avatar
United States, CA, Sonoma
Joined Mar 2005
Check Out The Video
http://www.youtube.com/watch?v=BBmTEUsg6Qg
[edit post at request from moderators]
Yep, it sure was windy that day. The A-4 seemed to handle it OK. Shame the video was cut short, why not show us how it lands.
BlueSkyRiderX is offline Find More Posts by BlueSkyRiderX
Last edited by BlueSkyRiderX; Apr 26, 2010 at 10:25 AM. Reason: edit post at request from moderators
Old Apr 26, 2010, 06:36 AM
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
No mods for me that I plan. About only thing I added was a little foam to secure the battery and Tx a little better.
I pulled the landing gear off so I can belly land on the grass after hand launch. I did not install those drop tanks either.
Old Apr 26, 2010, 06:58 AM
FlyBoyTha1's Avatar
Joined Sep 2008
Originally Posted by blueskyrider View Post
Whatever.
Lol, I Love You Man
You Know What They Say, Any Attention Is Better Than No Attention And I Get Alot From You
Old Apr 26, 2010, 02:35 PM
Joined Mar 2005
Lol, I Love You Man
Whatever you say there Marv. Save the lovin' for your better half, I do not crave it, desire it, nor need it.
Old Apr 26, 2010, 03:05 PM
FlyBoyTha1's Avatar
Joined Sep 2008
I Go To Chruch It's My Job To Love You, Love Thee Eniemn.
Not To Post Negitive, Cause You Don't Like My "Taste It's That What You Quoted? Stick To The Thread Who Cares If You Like Me Or Not.
Stop Wrecking Everyone's Thread, Cause You Don't Like Me Nor Have The Product That The Threads On.
Or Maybe It's Cause My Skin Much Darker Than Yours?
Whats The Real Reason Here? You Don't Know. Is Cause Of All My Planes? Just Say What It Is And Be Done With It
Old Apr 26, 2010, 03:29 PM
JGuilty13's Avatar
United States, MI, Royal Oak
Joined Nov 2005
Wow....getting a little off topic here boys.
FlyBoyTha1....was that a stock Airfield A4 in the "windy" video?
JGuilty13 is online now Find More Posts by JGuilty13
Old Apr 26, 2010, 03:33 PM
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Can we get off the personal stuff please.
thx
Oh, and I ask also for the rain and wind to leave me alone this week
Old Apr 26, 2010, 03:43 PM
FlyBoyTha1's Avatar
Joined Sep 2008
Yeah, I Just Got A Bigger Battery, 3 Cell 2600mAH.
I Have The ARF One, It Only Has The Servo's EDF Fan And Motor, No Charger Or Battery. I Had To Cut The Old Esc Battery Connector That Came With The A-4. And Soilder On A Deans Plug. Thats The Only Thing That Sucks If You Don't Order There Battery You'll Be Doing Some Soildering
New Product F4D Skyray 64mm EDF by FMS Model Joe 1320 Foamy EDFs 978 Aug 15, 2014 02:51 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 02:46 AM
Article NitroPlanes and Exceed RC's F-35 64mm EDF RC Jet Review 78dave Foamy EDFs 193 Jul 27, 2011 10:47 PM
Sold EDF 4500kv Outrunner Brushless Motor (NEW).64mm EDF Motor Tamiya10 Aircraft - Electric - Jets (FS/W) 1 Apr 14, 2010 03:28 AM
