Old Aug 07, 2007, 04:40 PM
Sir-Ipswich's Avatar
Joined Feb 2007
Where to get High % Nitro Fuel?
100% if possible, i live in the uk and i was wondering if a website sold it, is not a website that will sell high %. ty
Sir-Ipswich is offline Find More Posts by Sir-Ipswich
Old Aug 07, 2007, 04:48 PM
RC is Lekker!
nitroaddict's Avatar
Johnson City, TN
Joined Feb 2004
100% would be insane and would not run in the vehicle, as there would be no fuel.
Most cars are set to run on 15-20% from the factory, and you will need to shim the head of the engine if going any higher than that.
I run 30% in my Rody C5 engine with good results, but the engine was pre-shimmed during the mod per request. The 30% fuel I use is Odonnell.
Anything higher than that would likely be heli fuel and would not work well in a car. Even running 30% I have to richen the motor quite a bit to avoid temp meltdown.
Stick with 20% and you should be fine, any higher in a stock motor and you will damage the head. If you shim it, you will still likely have to richen the engine so much, that you will actually lose power rather than gain it.
Hope this helps.
nitroaddict is offline Find More Posts by nitroaddict
Old Aug 08, 2007, 09:31 AM
Joined Feb 2007
Of course i anit gonna use it by itself!
Old Aug 16, 2007, 10:37 AM
Joined Nov 2006
i bought a nitro star k-4.6 engine and the booklet recommends 25-35% in it but i can't get hold of it either. (i also live in the uk).
slopcier is offline Find More Posts by slopcier
Old Aug 20, 2007, 01:01 PM
Joined Feb 2007
you can get up to 35% on ebay, but i want higher so i can then water it down (with methanol and oil) so it'll work out cheaper.
Discussion Where to get high quality individual cells?? boa279 Batteries and Chargers 5 May 02, 2007 01:45 PM
Where to get high power (>100amp) wattmeter argarre High Performance 26 Jan 25, 2005 07:23 AM
Where to get Omega 15% fuel from rockettrike Dock Talk 1 Nov 27, 2004 09:21 AM
Where to get a high authority tail motor? hairy_llama Micro Helis 5 Jan 03, 2004 09:44 PM
Does anyone know where to get Panasonic "high voltage" 3000s in the UK? Ben C Electric Plane Talk 2 Jun 30, 2002 06:07 AM
